cado-nfs - Re: [Cado-nfs-discuss] C180 Issues
  • To: Emmanuel Thomé <Emmanuel.Thome@inria.fr>, cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] C180 Issues
  • Date: Wed, 7 Mar 2018 03:41:04 -0500 (EST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=rjd1212@cox.net; spf=Pass smtp.mailfrom=rjd1212@cox.net; spf=None smtp.helo=postmaster@eastrmfepo202.cox.net
  • Importance: Medium
  • Ironport-phdr: 9a23:ZooD0xzfqlLQKuXXCy+O+j09IxM/srCxBDY+r6Qd2u0UIJqq85mqBkHD//Il1AaPAd2Araocw8Pt8InYEVQa5piAtH1QOLdtbDQizfssogo7HcSeAlf6JvO5JwYzHcBFSUM3tyrjaRsdF8nxfUDdrWOv5jAOBBr/KRB1JuPoEYLOksi7ze+/94HdbglSmDaxfa55IQmrownWqsQYm5ZpJLwryhvOrHtIeuBWyn1tKFmOgRvy5dq+8YB6/ShItP0v68BPUaPhf6QlVrNYFygpM3o05MLwqxbOSxaE62YGXWUXlhpIBBXF7A3/U5zsvCb2qvZx1S+HNsDtU7s6RSqt4LtqSB/wiScIKTg58H3MisdtiK5XuQ+tqwBjz4LRZoyaM+ZwcKPDcN8DXGZMQ9xeWDFCDIO5d4sPCPABPfpCoIn7u1QBswa1CQ2yCO/zzzNFgGL9068n3OQ7CQzI0gwuH8gQvnrXrtr1OrocXu+pw6fSzjrNaPJW1Czn54TUaB0uuuuBUa5yfMfX1EIhFxnFjlKVqYH9Iz2bz/kAvWeH4eR+SOmhhWAoph9zrDWz2MkihZXEiYwIwV3D7yV5wps6KcCmREJmf9KpC4dftyaVNodsRMMtXX1otT88x7YbupC7ZDAHxZUkyhLFdfCKfZSE7gj9WOuePDt0nmxpdK+9ihqq8EWtyffwWteq3FtJtCZIkcTAumoQ2xDP98SLUuZx80ig1DqVyQzf9vtILV0pmabFMZIsw7w9m5wOukrZBCD2gl/5jKqOe0Uk5Oeo7+Pnb634qZCGLI90lhv+MqEgmsOhGeQ4NRYCU3SF9eimyLLj+kL4TK9MjvIojqnVqJHaJcIFqa6lGwJY04Uu5wyhAzqozNgUh2cLIV1YdB6dkYTlJlPDLOj9DfilglSslDlrx+rBPr3kGpjNNHrDn6r8cbpj9kJQ1hE+wsxY55NbEL0BJuz8WlPpuNzCEhA5KxC0w/rgCNhlyowRQ3+AAqiAPKPUv1+I/fsjLPSNZI8OpDn9NuMl5+X1gH89mF8dZrWp3YANZHC3EPRmJF+ZYXXyjdsbEGcKuBA+TO3wh1GYXz5TfSX6Y6VpyzQ+AYS7AIP0eoCqhT3JiAq+G5RQe21CTGyMFnLlX4SCQfYFLiyIdIspmTUIUv2nRZRk2RC1vxLh0JJjL/HI4WsXu5X529Uz5uvJlBh0+yYnNcmF13CxSDROuUklfQN+8J1UgWVB536+mfxigfABT4UJz/hOQkE8OIKKnMJgDNWnYCXrU+21AHqbafWPPRwYc5pl2d0COhwkQf2piQCF2Se2VexG34eXDYA5p/qPl0P6INxwnjOWjPBw3WljedNGMCidvoA68gHSA4DTlEDIxa2tZeIa0TKfrT7fn1rLh1lRVUtLaYuARWoWNxndqsS/4E7eHef3VOYXdzBZwMvHEZNkL93kiVIcH6XuMc/CeWe/ln+3X07SgLiLfMzsdnlPhCg=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Interesting info. Whatever the result, I'll keep you & Paul posted on the final result.
Best Regards,
RJD
> On March 7, 2018 at 2:58 AM Emmanuel Thomé <Emmanuel.Thome@inria.fr> wrote:
> On Wed, Mar 07, 2018 at 08:55:06AM +0100, Paul Zimmermann wrote:
> > About issue 2), this is normal. What happens is that the bkmult parameter is
> > dynamically adjusted if too small. Maybe the warning message is too verbose.
> Yes.
> It's true that ending up with bkmult that high is an indication that
> something fishy is going on. But that's not something peculiar with your
> experiment right now. It's an oddity we observe on other occasions.
> (Theoretically, we would hope that bkmult close to 1 would be enough: 2.5
> seems clearly way off.)
> E.
