[Cado-nfs-discuss] [Help] Some problem regarding factoring using importe polynomial
- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] [Help] Some problem regarding factoring using importe polynomial
- Date: Thu, 14 Jun 2018 14:22:41 +0700
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=cannysiska@gmail.com; spf=Pass smtp.mailfrom=cannysiska@gmail.com; spf=None smtp.helo=postmaster@mail-vk0-f47.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi,
When i try to do some test sieving using guideline suggested in
README.nonlinear,
i've tried imported the polynomial, works well sieving until about 70%
then this error appear:
Error:Lattice Sieving: Program run on localhost failed with exit code 1
Error:Lattice Sieving: Stderr output follows (stored in file
/tmp/cado.q_tpoqwj/c60.upload/c60_sieving_524000-526000.glyey27r.stderr0):
b'# redoing q=524047, rho=205396 because buckets are full\n# Fullest
level-1s bucket #5, wrote 8839/8720\n# Maybe you have too many threads
compared to the size of the factor bases.\n# Please try less threads,
or a larger -bkmult parameter (at some cost!).\n# The code will now
try to adapt by allocating more memory for buckets.\n# redoing
q=524197, rho=22706 because buckets are full\n# Fullest level-1s
bucket #1, wrote 9262/9168\n# Maybe you have too many threads compared
to the size of the factor bases.\n# Please try less threads, or a
larger -bkmult parameter (at some cost!).\n# The code will now try to
adapt by allocating more memory for buckets.\n# redoing q=524197,
rho=454641 because buckets are full\n# Fullest level-1s bucket #4,
wrote 10638/10176\n# Maybe you have too many threads compared to the
size of the factor bases.\n# Please try less threads, or a larger
-bkmult parameter (at some cost!).\n# The code will now try to adapt
by allocating more memory for buckets.\nERROR: The special q (20 bits)
is larger than the large prime bound on side 1 (19 bits).\n You
can disable this check with the -allow-largesq argument,\n It is
for instance useful for the descent.\n'
Have tried once more and happens to be the same error.
Thank you.
- [Cado-nfs-discuss] [Help] Some problem regarding factoring using importe polynomial, canny georgina, 06/14/2018
- Re: [Cado-nfs-discuss] [Help] Some problem regarding factoring using importe polynomial, Pierrick Gaudry, 06/15/2018
