cado-nfs - [Cado-nfs-discuss] opal error on cado-nfs(3.0.0)
  • To: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
  • Subject: [Cado-nfs-discuss] opal error on cado-nfs(3.0.0)
  • Date: Tue, 19 Jun 2018 07:41:21 +0000
  • Accept-language: zh-CN, en-US
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=showeryhe@hotmail.com; spf=Pass smtp.mailfrom=showeryhe@hotmail.com; spf=Pass smtp.helo=postmaster@APC01-SG2-obe.outbound.protection.outlook.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear all,
I’ve followed instructions in opal-test/readme to install nomad and opal, and it works well with opal/examples/fd/fd_optimize.py. However, to execute
$ ./optimize.sh params.c60 c60.poly
in cado-nfs(3.0.0)/scripts/opal-test, with parameter(polynomial) files copied from cado-nfs/parameters/factor(polynomials), the program would always have errors (pasted below).
I don’t know what to do and any advice would be helpful.
Thank you for your time!
Xiaoou He
Jun 19, 2018
Using parameters I:10 qmin:61961 bkthresh1:0 lim0:78682 lim1:111342 lpb0:18 lpb1:19 mfb0:18 mfb1:38 ncurves0:10 ncurves1:10
Running: /home1/hxo/cado-nfs/sieve/makefb -lim 111342 -poly c60.poly -maxbits 10 -t 4 -side 1 -out factorbase111342.roots1.gz
Traceback (most recent call last):
  File "las_run.py", line 274, in <module>
    measures = run(param_file, problem)
  File "las_run.py", line 222, in run
    subprocess.check_call(makefb_cmd_line)
  File "/usr/lib64/python2.7/subprocess.py", line 537, in check_call
    retcode = call(*popenargs, **kwargs)
  File "/usr/lib64/python2.7/subprocess.py", line 524, in call
    return Popen(*popenargs, **kwargs).wait()
  File "/usr/lib64/python2.7/subprocess.py", line 711, in __init__
    errread, errwrite)
  File "/usr/lib64/python2.7/subprocess.py", line 1308, in _execute_child
    raise child_exception
OSError: [Errno 2] No such file or directory
Exception in thread blackbox.data generator:
  File "/usr/lib64/python2.7/threading.py", line 811, in __bootstrap_inner
    self.run()
  File "/home1/hxo/.local/lib/python2.7/site-packages/opal/core/mafrw.py", line 281, in run
    self.handle_message(msg)
  File "/home1/hxo/.local/lib/python2.7/site-packages/opal/core/mafrw.py", line 198, in handle_message
    self.message_handlers[cmd](info)
  File "/home1/hxo/.local/lib/python2.7/site-packages/opal/core/datagenerator.py", line 229, in get_result
    measureValues = self.algorithm.read_measure(outputFile)
  File "/home1/hxo/.local/lib/python2.7/site-packages/opal/core/algorithm.py", line 151, in read_measure
    f = open(fileName)
IOError: [Errno 2] No such file or directory: 'LAS_TESTPROB_67c9be31e050acddecb3905ae3a50db92bd4c2ea.measure'
$ /home1/hxo/cado-nfs/sieve/makefb -lim 111342 -poly c60.poly -maxbits 10 -t 4 -side 1 -out factorbase111342.roots1.gz
-bash: /home1/hxo/cado-nfs/sieve/makefb: No such file or directory
Since opal was not tested with python 3.x [1], opal was built and .py programs in opal-test were run under Python 2.7.5.
OS: Red Hat 4.8.2-13
gcc version 4.8.3 20140911
and cado-nfs.py is run with Python 3.6.5
[1] https://github.com/PythonOptimizers/opal
