- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] [Error Help] stagnant sieving process
- Date: Tue, 26 Jun 2018 10:34:28 +0700
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=cannysiska@gmail.com; spf=Pass smtp.mailfrom=cannysiska@gmail.com; spf=None smtp.helo=postmaster@mail-ua0-f181.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi, sorry for bothering. I've tried enlarging the parameter (I). But
it only work up to c90. When I tried using the same trick (enlarge the
I value) on c95, just like this:
root@ubuntu:/home/chunnie/Desktop/Math/cado-nfs# ./cado-nfs.py
12738422648719292141327547835264494089254325514157934481190929328131291383802905189936841392203
tasks.polyselect.import=c95_nonlinear.poly tasks.sieve.I=13
it's fine until lattice sieving (adding workunits) and it shows
something like this:
Info:Generate Free Relations: Finished
Info:Generate Free Relations: Total cpu/real time for freerel: 27.3/190.717
Info:Lattice Sieving: Starting
Info:Lattice Sieving: We want 2355895 relation(s)
Info:Lattice Sieving: Adding workunit c95_sieving_200000-210000 to database
Info:Lattice Sieving: Adding workunit c95_sieving_210000-220000 to database
Info:Lattice Sieving: Adding workunit c95_sieving_220000-230000 to database
Info:Lattice Sieving: Adding workunit c95_sieving_230000-240000 to database
Info:Lattice Sieving: Adding workunit c95_sieving_240000-250000 to database
Info:Lattice Sieving: Adding workunit c95_sieving_250000-260000 to database
Info:Lattice Sieving: Adding workunit c95_sieving_260000-270000 to database
Info:Lattice Sieving: Adding workunit c95_sieving_270000-280000 to database
Info:Lattice Sieving: Adding workunit c95_sieving_280000-290000 to database
Info:Lattice Sieving: Adding workunit c95_sieving_290000-300000 to database
Info:HTTP server: 127.0.0.1 Sending workunit c95_sieving_200000-210000
to client localhost+2
Info:HTTP server: 127.0.0.1 Sending workunit c95_sieving_210000-220000
to client localhost
it works fine until this step, then shows up like this:
Warning:HTTP server: 127.0.0.1 Connection error: [Errno 32] Broken pipe
Info:Lattice Sieving: Adding workunit c95_sieving_300000-310000 to database
Info:Lattice Sieving: Adding workunit c95_sieving_310000-320000 to database
I'm not sure what broken pipe notification means, but what happens
after this notification is that, it's stuck after that notification's
given. I mean, I waited long enough for this step to continue further
but unfortunately it doesn't. So, it's stagnant.
Also, after I tried changing the command:
tasks.polyselect.import=c95_nonlinear.poly tasks.sieve.I=12
tasks.sieve.lpb0=25
to client localhost
Error:Lattice Sieving: Program run on localhost failed with exit code 134
Error:Lattice Sieving: Stderr output follows (stored in file
/tmp/cado.zix0sv66/
and the error notification becomes like this again:
/tmp/cado.zix0sv66/c95.upload/c95_sieving_200000-210000.j384vn22.stderr0):
b'# redoing q=200003, rho=60661 because buckets are full\n# Fullest
level-1s bucket #108, wrote 8201/7824\n# Maybe you have too many
threads compared to the size of the factor bases.\n# Please try less
threads, or a larger -bkmult parameter (at some cost!).\n# The code
will now try to adapt by allocating more memory for buckets.\ncode
BUG() : condition u1 != 0. failed in lognorm_fill_rat_smart_inner at
/home/chunnie/Desktop/Math/cado-nfs/sieve/las-norms.cpp:555 --
Abort\nAborted (core dumped)\n'
Info:Lattice Sieving: Resubmitting workunit c95_sieving_200000-210000
as c95_sieving_200000-210000#2
Error:Lattice Sieving: Program run on localhost+2 failed with exit code 134
/tmp/cado.zix0sv66/c95.upload/c95_sieving_210000-220000.bzb4pycb.stderr0):
b'# redoing q=210019, rho=42734 because buckets are full\n# Fullest
level-1s bucket #126, wrote 8366/7824\n# Maybe you have too many
- [Cado-nfs-discuss] [Error Help] stagnant sieving process, canny georgina, 06/26/2018
- Re: [Cado-nfs-discuss] [Error Help] stagnant sieving process, paul zimmermann, 06/26/2018
