[Cado-nfs-discuss] I need to create a parameter file for CADO NFS. How do I do this?
- To: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: [Cado-nfs-discuss] I need to create a parameter file for CADO NFS. How do I do this?
- Date: Wed, 27 Jun 2018 05:30:53 +0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=thewill@aliyun.com; spf=Pass smtp.mailfrom=thewill@aliyun.com; spf=None smtp.helo=postmaster@out30-38.freemail.mail.aliyun.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
I need to factorise a large number of 250 bits,but when I imput the command in the terminal like this:
./cado-nfs.py 765467679654377986857432645365476
and the program return a bug.
So,I create a parammter file : params.c250,and setting some parameters by myselves,but the program became this:
The program get stuck in there.
Above all,I can't create a right parameter file for 250-bit's number.
Or help me how to factorise a 250-bit's number.
Could you help me?
(Forgive me my bad english grammer)
- [Cado-nfs-discuss] I need to create a parameter file for CADO NFS. How do I do this?, thewill, 06/26/2018
- Re: [Cado-nfs-discuss] I need to create a parameter file for CADO NFS. How do I do this?, paul zimmermann, 06/27/2018
