cado-nfs - Re: [Cado-nfs-discuss] Duplicate removal issue at end of sieving RSA-200
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Duplicate removal issue at end of sieving RSA-200
  • Date: Sat, 30 Jun 2018 09:45:06 -0400 (EDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=rjd1212@cox.net; spf=Pass smtp.mailfrom=rjd1212@cox.net; spf=None smtp.helo=postmaster@eastrmfepo202.cox.net
  • Importance: Medium
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
I am having an issue where the program aborts at the filtering/duplicate removal stage & gives the following error message in the attached log file. Any help would be greatly appreciated.
Best Regards,
RJD
PID3087 2018-06-30 01:54:09,816 Debug:Command: Process with PID 697 finished successfully
PID3087 2018-06-30 01:54:09,861 Debug:Filtering - Duplicate Removal, splitting pass: Output file names: {'/opt3/c200.dup1//0/dup1.0.0000.gz': 0, '/opt3/c200.dup1//1/dup1.0.0000.gz': 1, '/opt3/c200.dup1//0/dup1.0.0001.gz': 0, '/opt3/c200.dup1//1/dup1.0.0001.gz': 1, '/opt3/c200.dup1//0/dup1.0.0002.gz': 0, '/opt3/c200.dup1//1/dup1.0.0002.gz': 1, '/opt3/c200.dup1//0/dup1.0.0003.gz': 0, '/opt3/c200.dup1//1/dup1.0.0003.gz': 1, '/opt3/c200.dup1//0/dup1.0.0004.gz': 0, '/opt3/c200.dup1//1/dup1.0.0004.gz': 1, '/opt3/c200.dup1//0/dup1.0.0005.gz': 0, '/opt3/c200.dup1//1/dup1.0.0005.gz': 1, '/opt3/c200.dup1//0/dup1.0.0006.gz': 0, '/opt3/c200.dup1//1/dup1.0.0006.gz': 1}
PID3087 2018-06-30 01:54:09,862 Debug:Filtering - Duplicate Removal, splitting pass: Newly arrived stats: {'stats_dup1_time': '1141.4'}
PID3087 2018-06-30 01:54:09,862 Debug:Filtering - Duplicate Removal, splitting pass: Combined stats: {'stats_dup1_time': '1141.4'}
PID3087 2018-06-30 01:54:13,546 Info:Filtering - Duplicate Removal, splitting pass: Relations per slice: 0: 227678448, 1: 227661997
PID3087 2018-06-30 01:54:13,546 Debug:Filtering - Duplicate Removal, splitting pass: Exit Duplicates1Task.run(duplicates1)
PID3087 2018-06-30 01:54:13,548 Info:Filtering - Duplicate Removal, splitting pass: Total cpu/real time for dup1: 2325.02/1141.53
PID3087 2018-06-30 01:54:13,548 Info:Filtering - Duplicate Removal, splitting pass: Aggregate statistics:
PID3087 2018-06-30 01:54:13,548 Info:Filtering - Duplicate Removal, splitting pass: CPU time for dup1: 1141.4s
PID3087 2018-06-30 01:54:13,548 Info:Filtering - Duplicate Removal, removal pass: Starting
PID3087 2018-06-30 01:54:13,548 Debug:Filtering - Duplicate Removal, removal pass: duplicates2.run(): Task state: {}
PID3087 2018-06-30 01:54:13,599 Command:Command: /home/rjd/cado-nfs-f5f8cd5/build/home9/filter/dup2 -nrels 227678448 -renumber /opt3/c200.renumber.gz /opt3/c200.dup1//0/dup1.0.0000.gz /opt3/c200.dup1//0/dup1.0.0001.gz /opt3/c200.dup1//0/dup1.0.0002.gz /opt3/c200.dup1//0/dup1.0.0003.gz /opt3/c200.dup1//0/dup1.0.0004.gz /opt3/c200.dup1//0/dup1.0.0005.gz /opt3/c200.dup1//0/dup1.0.0006.gz > /opt3/c200.dup2.slice0.stdout.1 2> /opt3/c200.dup2.slice0.stderr.1
PID3087 2018-06-30 01:54:13,769 Warning:Command: Process with PID 1535 finished with return code -6
PID3087 2018-06-30 01:54:13,785 Error:Filtering - Duplicate Removal, removal pass: Program run on server failed with exit code -6
PID3087 2018-06-30 01:54:13,785 Error:Filtering - Duplicate Removal, removal pass: Command line was: /home/rjd/cado-nfs-f5f8cd5/build/home9/filter/dup2 -nrels 227678448 -renumber /opt3/c200.renumber.gz /opt3/c200.dup1//0/dup1.0.0000.gz /opt3/c200.dup1//0/dup1.0.0001.gz /opt3/c200.dup1//0/dup1.0.0002.gz /opt3/c200.dup1//0/dup1.0.0003.gz /opt3/c200.dup1//0/dup1.0.0004.gz /opt3/c200.dup1//0/dup1.0.0005.gz /opt3/c200.dup1//0/dup1.0.0006.gz > /opt3/c200.dup2.slice0.stdout.1 2> /opt3/c200.dup2.slice0.stderr.1
PID3087 2018-06-30 01:54:13,785 Error:Filtering - Duplicate Removal, removal pass: Stderr output follows (stored in file /opt3/c200.dup2.slice0.stderr.1):
b'antebuffer set to /home/rjd/cado-nfs-f5f8cd5/build/home9/utils/antebuffer\ncode BUG() : condition renum->nb_bits <= 8 * sizeof(p_r_values_t) failed in renumber_read_first_line at /home/rjd/cado-nfs-f5f8cd5/utils/renumber.c:306 -- Abort\n'
