cado-nfs - Re: [Cado-nfs-discuss] Arguments to produce hintfile
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Arguments to produce hintfile
  • Date: Mon, 30 Jul 2018 09:37:09 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Yes, hintfile-helper.py is unmaintained, and unnecessary now. It should
not be in the repository, in fact.
E.
On Mon, Jul 30, 2018 at 08:10:03AM +0200, Pierrick Gaudry wrote:
> Hi,
> Tools and documentation for the hint-file are more or less all obsolete,
> because the descent binary is now much more clever than before.
> If I remember correctly, the hint files were written by hand, except for
> the columns 2 and 3 for which the helper script was run. But setting 1.0
> and 1.0 for these two columns shouldn't hurt much in terms of
> performance.
> I might work on this in the not too far future : I wouldn't be surprised
> if nowadays this hint file can be reduced to almost nothing. In the
> meantime, I suggest you try to imitate what's in the other hint files.
> Regards,
> Pierrick
> On Mon, Jul 30, 2018 at 06:01:44AM +0000, He Xiaoou wrote:
> > Dear Zimmermann,
> > Thank you for your advice. After replacing fb1 by fb, there is neither
> > error nor response after the command line.
> > I’m wondering if there’s some alternative way or tricks to generate a
> > hint file.
> > Best regards.
> > Xiaoou He
> > _______________________________________________
> > Cado-nfs-discuss mailing list
> > Cado-nfs-discuss@lists.gforge.inria.fr
> > https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
