- To: sara hendrix <sara.hendrix@engineer.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Run bwc.pl with mpi mode
- Date: Sun, 6 Jan 2019 11:24:14 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi,
Please provide:
- complete build log (both "make cmake" and "make bwc_full")
- the full command line to bwc.pl
- complete bwc.pl output
- the output of "grep Cpus_allowed_list /proc/self/status" (or maybe
replace "self" by the pid of a running bwc program).
There are many reasons which could cause symptoms similar to what you
observe.
E.
On Sun, Jan 06, 2019 at 10:24:32AM +0100, sara hendrix wrote:
> Hi all,
> I compiled cado-nfs in MPI mode. Now, I am going to run linear algebra step
> (for RSA-512 bits) on multiple machines. I use ./bwc.pl in mpi mode running
> on
> 1 server and 1 client each have 6 cores, 12 threads and connecting with
> 10Gib
> ethernet cable. I set different parameters for mpi and threads based on
> readme file in bwc folder. For some parameters all threads on my 2 machines
> are
> full load. However, when I run ./bwc.pl on one machine it is faster?
> Can anyone explain me the reason please?
> Thanks,
> Sara
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] Run bwc.pl with mpi mode, sara hendrix, 01/06/2019
- Re: [Cado-nfs-discuss] Run bwc.pl with mpi mode, Emmanuel Thomé, 01/06/2019
