- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] plingen in MPI mode
- Date: Tue, 22 Jan 2019 13:17:26 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=sara.hendrix@engineer.com; spf=Pass smtp.mailfrom=sara.hendrix@engineer.com; spf=None smtp.helo=postmaster@mout.gmx.com
- Importance: normal
- Ironport-phdr: 9a23:2mu5aRaidQ6Wh8QifTR/t1//LSx+4OfEezUN459isYplN5qZr86ybnLW6fgltlLVR4KTs6sC17KG9fi4EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6arXK99yMdFQviPgRpOOv1BpTSj8Oq3Oyu5pHfeQpFiCa+bL9oMBm6sRjau9ULj4dlNqs/0AbCrGFSe+RRy2NoJFaTkAj568yt4pNt8Dletuw4+cJYXqr0Y6o3TbpDDDQ7KG81/9HktQPCTQSU+HQRVHgdnwdSDAjE6BH6WYrxsjf/u+Fg1iSWIdH6QLYpUjul86llSAHlhD4eOzMk6m7Yl9F+g7xdoBK6phx/34/UYJ+UNPpifqLWYNcWSXRdUspUUSFKH4GyYJYVD+cZMulWrInzqUUToxSiCwejB/nhxyRIhnPqx6A2z/gtHR3E0QEmAtkAsG7UrNLwNKoKX+y117PHzS/ZYPhL2Tfy9o7IfQ07ofGNUrN8f9faxE40FwzflFWfs5bpPzOL2eQLrmeb9etgVO20hmE5rQFxrTmvxsEyhYbXnIIZ0EzL9SJ8wIssI9CzVU11Yca8HZZSuCyWLZV6Tt8hTm1ytys20KMKtYKmcCQSzJkqyATTZ+GJfoSU+B7vSfidLDZiiH9hdr+ygQu5/1K6xe3mTMa01U5HripbndnIsXAAzxnT6s+aSvth5Euh1jOP1g/J5u5YJkA0kLLXK58nwrEuipoeqUbOEyDslEnokKObdV8o9+ey5+j5frnqu4eQN4puhQH/NqQulNa/AeM9MgUWRGiU4/6826f58U35XrpKiOA5krPYsJHVPskUuKi5AwBU0oYl9RmwES2m3M4EknkAKVJJYAiHgJTxO1HSPPD4Cu+yjEi2nzh2wPDKJ7vhApvWLnTajbjhfK195FJByAoo1tBS/JZUCrAaIPLvQU/9rtPYDhE+MwyuzOboFs9x1oIYWWKVA6+WKrnesVGS5rFnH+7Zb4YZv3P7JeNg6//1hmIigncZfLK1xt0YZneiEfkgIkODYHOqjM1SP30Nu190V+XwgRWCXDhffXeiFepo/TghAcSmAIHPXIG9qLGH0ya9E5BMIGtBDwbfQj/Ta4yYVqJUO2qpKch7n2leDeHwGb9k7gmnsUrB85QiK+PV/iMCspe6iIp44eLSkxw/73p/CMHPijjRHVExpXsBQnoN5I46uVZ0kwvR3K53gvpVGMYV7PRMAF9jaMzsitdiAtW3YTrvO9eETFH/HoejBiwtCN0005kFZEMvQ9g=
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
- Sensitivity: Normal
Hi all,
Is it the right way to use "plingen_pz" in MPI mode instead using "lingen"?
When I run "plingen_pz" in mpi mode, an error will be occurred.
In the following, you can find the command and the error.
Can anyone explain me the reason please?
Does anyone have any idea to better running the "lingen"?!
Thanks,
Sara
Sara
/usr/bin//mpiexec -machinefile /tmp/hosts --mca orte_rsh_agent ssh --mca btl_tcp_if_exclude lo,virbr0 -n 1 ./plingen_pz n=256 prime=2 wdir=/tmp/bwc/ interval=100 m=512 split-output-file=1 afile=/tmp/bwc/A0-256.0-2000 mpi=2x1 thr=5x5
Successfully initialized MPI with MPI_THREAD_SERIALIZED
MPI library follows [MPI-2.1]
When using plingen, you must either supply --random-input-with-length, or provide a rhs, or possibly provide rhs=none
MPI_COMM_WORLD rank 0: debian
size=1 mpi=2x1 thr=5x5
code BUG() : condition size == mpi[0] * mpi[1] * thr[0] * thr[1] failed in main at /mnt/cado-nfs-2.3.0/linalg/bwc/plingen.cpp:2963 -- Abort
[debian:04920] *** Process received signal ***
[debian:04920] Signal: Aborted (6)
[debian:04920] Signal code: (-6)
[debian:04920] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0xf8d0) [0x7f3b528df8d0]
[debian:04920] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x37) [0x7f3b51342067]
[debian:04920] [ 2] /lib/x86_64-linux-gnu/libc.so.6(abort+0x148) [0x7f3b51343448]
[debian:04920] [ 3] ./plingen_pz(main+0xf8c) [0x40f7ac]
[debian:04920] [ 4] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f3b5132eb45]
[debian:04920] [ 5] ./plingen_pz() [0x40f96f]
[debian:04920] *** End of error message ***
mpiexec noticed that process rank 0 with PID 4920 on node debian exited on signal 6 (Aborted).
- [Cado-nfs-discuss] plingen in MPI mode, sara hendrix, 01/22/2019
- Re: [Cado-nfs-discuss] plingen in MPI mode, Emmanuel Thomé, 01/22/2019
