cado-nfs - Re: [Cado-nfs-discuss] Fwd: return code -6 , exit code -6
  • To: paul zimmermann <Paul.Zimmermann@inria.fr>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Fwd: return code -6 , exit code -6
  • Date: Fri, 1 Mar 2019 04:05:28 +0100 (CET)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=eric.jeancolas@free.fr; spf=None smtp.mailfrom=eric.jeancolas@free.fr; spf=None smtp.helo=postmaster@smtp5-g21.free.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul,
I reran the factorization outside the nohup function and it worked. I did it
because I suspected nohup.
Nohup was used to let the process run even if the session is lost. But it may
have an impact on the gzip process. I can't be sure as I made the test only
once, but this is a track I will investigate.
I had a similar incident on another factorization at the very end process.
Here are the lines about this incident:
Warning:Command: Process with PID 20664 finished with return code
-6
Error:Square Root: Program run on server failed with exit code -6
Error:Square Root: Command line was:
/home/ng/cado-nfs-2.3.0/build/ng-All-Series/sqrt/sqrt -poly
/tmp/cado.2du2886j/c135.poly -prefix /tmp/cado.2du2886j/c135.dep.gz -purged
/tmp/cado.2du2886j/c135.purged.gz -index /tmp/cado.2du2886j/c135.index.gz
-ker /tmp/cado.2du2886j/c135.kernel -dep 0 -t 8 -side0 -side1 -gcd >
/tmp/cado.2du2886j/c135.sqrt.stdout.2 2> /tmp/cado.2du2886j/c135.sqrt.stderr.2
I simply reran the last command - thanks to your previous advices - and I got
the result into c135.sqrt.stdout.2.
Well, I'll carry on running factorizations without nohup. I changed the way I
access to my "cado" computer, and I don't need nohup any longer.
Best Regards.
Eric
----- Mail original -----
De: "paul zimmermann" <Paul.Zimmermann@inria.fr>
À: "eric jeancolas" <eric.jeancolas@free.fr>
Envoyé: Vendredi 22 Février 2019 15:20:28
Objet: Re: [Cado-nfs-discuss] Fwd: return code -6 , exit code -6
Eric,
> I've just checked these files. gzip -t returns no error.
> I know /tmp/cado.qnpox55b/c140.dup1//1/dup1.0.0000.gz was corrupted, but
> when I issued the command you gave me, it was no longer corrupted.
then my advice would be to import the already computed relations in a new
working directory. See section "Importing relations" in
scripts/cadofactor/README. First change in read-only mode all data you have
in the current working directory.
Best regards,
Paul
  • Re: [Cado-nfs-discuss] Fwd: return code -6 , exit code -6, eric . jeancolas, 03/01/2019
