- To: paul zimmermann <paul.zimmermann@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] Nohup is not guilty
- Date: Mon, 11 Mar 2019 09:03:53 +0100 (CET)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=eric.jeancolas@free.fr; spf=None smtp.mailfrom=eric.jeancolas@free.fr; spf=None smtp.helo=postmaster@smtp6-g21.free.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul
It occured that I lose a process even without nohup.
Maybe because my server is not dedicated and run other GPU calculations in
the same time.
Anyway I need more investigation.
The good news is I have been always able to recover and get results by
restarting from the step that was interrupted.
I will not bother you any longer as long as I have not determined what are
the circumstances of these interrupts.
Best regards.
Éric
- [Cado-nfs-discuss] Nohup is not guilty, eric . jeancolas, 03/11/2019
