cado-nfs - Re: [Cado-nfs-discuss] Too many timed out work units error
  • To: "sara hendrix" <sara.hendrix@engineer.com>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Too many timed out work units error
  • Date: Tue, 09 Apr 2019 09:41:21 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi Sara,
what probably happens is that the value of adrange is too large with respect
to the timeout limit (2 or 3 hours). You should decrease adrange in
parameters/factor/params.c195.
Which version of cado-nfs are you using?
Paul Zimmermann
> From: "sara hendrix" <sara.hendrix@engineer.com>
> Date: Tue, 9 Apr 2019 08:44:21 +0200
> [1:text/html Hide Save:noname (2kB)]
> Hi,
> I have a desktop with AMD 1950X processor (16 cores and 32 thread). When I
> ran cado-nfs to factor large number (c.195), I got the following error:
> Error:Polynomial Selection (size optimized): Exceeded maximum number of
> timed
> out workunits, maxtimedout=100
> Traceback (most recent call last):
> File "./cado-nfs.py", line 122, in <module>
> factors = factorjob.run()
> File "./scripts/cadofactor/cadotask.py", line 5429, in run
> last_status, last_task = self.run_next_task()
> File "./scripts/cadofactor/cadotask.py", line 5504, in run_next_task
> return [task.run(), task.title]
> File "./scripts/cadofactor/cadotask.py", line 1862, in run
> self.submit_one_wu()
> File "./scripts/cadofactor/cadotask.py", line 2111, in submit_one_wu
> self.submit_command(p, "%d-%d" % (adstart, adend), commit=False)
> File "./scripts/cadofactor/cadotask.py", line 1505, in submit_command
> self.wait()
> File "./scripts/cadofactor/cadotask.py", line 1577, in wait
> self.resubmit_timed_out_wus()
> File "./scripts/cadofactor/cadotask.py", line 1629, in
> self.cancel_wu(entry["wuid"], commit=False)
> File "./scripts/cadofactor/cadotask.py", line 1497, in cancel_wu
> raise Exception("Too many timed out work units. Please increase
> tasks.maxtimedout (current value is %d)" % maxtimedout)
> Exception: Too many timed out work units. Please increase tasks.maxtimedout
> (current value is 100)
> I increased the "tasks.maxtimedout" in c.195 from 100 to 1000, however I got
> the same error.
> Can anyone help me with that?
> Regards,
> Sara
> [2:text/plain Hide]
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
