- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] SIGSEGV sur le test full_c30
- Date: Mon, 29 Apr 2019 16:18:13 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=thomas@bailleux.me; spf=Pass smtp.mailfrom=thomas@bailleux.me; spf=Pass smtp.helo=postmaster@bailleux.me
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Bonjour, J'ai compilé CADO-NFS avec Clang 8, et ASAN activé. Le test "full_c30" échoue à cause d'une segfault. Voici la trace ASAN: Debug:Polynomial Selection (root optimized): Return code is: 1 Debug:Polynomial Selection (root optimized): stderr is: b'AddressSanitizer:DEADLYSIGNAL ================================================================= ==2902==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000004 (pc 0x564a173fb330 bp 0x7ffed0fa8e10 sp 0x7ffed0fa8c60 T0) ==2902==The signal is caused by a READ memory access. ==2902==Hint: address points to the zero page. #0 0x564a173fb32f in cpuid2 /home/zadig/LORIA/travail/cado-nfs/utils/cachesize_cpuid.c:80:5 #1 0x564a173fef85 in update_intel_byte /home/zadig/LORIA/travail/cado-nfs/utils/cachesize_cpuid.c:450:6 #2 0x564a174004d5 in print_intel_cache /home/zadig/LORIA/travail/cado-nfs/utils/cachesize_cpuid.c:491:5 #3 0x564a173ff2cb in cachesize_cpuid /home/zadig/LORIA/travail/cado-nfs/utils/cachesize_cpuid.c:562:13 #4 0x564a1731971e in ropt_L1_cachesize /home/zadig/LORIA/travail/cado-nfs/polyselect/ropt_io.c:20:22 #5 0x564a172e876c in main /home/zadig/LORIA/travail/cado-nfs/polyselect/ropt_main.c:832:3 #6 0x7f153daf1ce2 in __libc_start_main (/usr/lib/libc.so.6+0x23ce2) #7 0x564a171ceb0d in _start (/tmp/cado.r228 b2pr/client/download/polyselect_ropt+0x5cb0d) AddressSanitizer can not provide additional info. SUMMARY: AddressSanitizer: SEGV /home/zadig/LORIA/travail/cado-nfs/utils/cachesize_cpuid.c:80:5 in cpuid2 ==2902==ABORTING Error:Polynomial Selection (root optimized): Program run on localhost failed with exit code 1 Error:Polynomial Selection (root optimized): Stderr output (last 10 lines only) follow (stored in file /tmp/cado.r228b2pr/c30.upload/c30_polyselect2_0#2.hvcfzhz8.stderr0): Error:Polynomial Selection (root optimized): #3 0x564a173ff2cb in cachesize_cpuid /home/zadig/LORIA/travail/cado-nfs/utils/cachesize_cpuid.c:562:13 Error:Polynomial Selection (root optimized): #4 0x564a1731971e in ropt_L1_cachesize /home/zadig/LORIA/travail/cado-nfs/polyselect/ropt_io.c:20:22 Error:Polynomial Selection (root optimized): #5 0x564a172e876c in main /home/zadig/LORIA/travail/cado-nfs/polyselect/ropt_main.c:832:3 Error:Polynomial Selection (root optimized): #6 0x7f153daf1ce2 in __libc_start_main (/usr/lib/libc.so.6+0x23ce2) Error:Polynomial Selection (root optimized): #7 0x564a171ceb0d in _start (/tmp/cado.r228b2pr/client/download/polyselect_ropt+0x5cb0d) Error:Polynomial Selection (root optimized): Error:Polynomial Selection (root optimized): AddressSanitizer can not provide additional info. Error:Polynomial Selection (root optimized): SUMMARY: AddressSanitizer: SEGV /home/zadig/LORIA/travail/cado-nfs/utils/cachesize_cpuid.c:80:5 in cpuid2 Error:Polynomial Selection (root optimized): ==2902==ABORTING Error:Polynomial Selection (root optimized): J'utilise la dernière version, disponible sur le git (bf5ba257b86ff4765d2bc1e5b5caa42ca0d63d62). Output de make cmake: -- Looking for waitpid -- Looking for waitpid - found -- Looking for ctime_r -- Looking for ctime_r - found -- Looking for realpath -- Looking for realpath - found -- Looking for mmap -- Looking for mmap - found -- Looking for sysconf -- Looking for sysconf - found -- Testing whether RUSAGE_THREAD can be used -- Trying to compile with RUSAGE_THREAD -- Success -- Testing the existence of __sync_fetch functions -- Testing the existence of __sync_fetch functions -- Success -- Testing the existence of asprintf/vasprintf functions -- Testing the existence of asprintf/vasprintf functions -- Success -- Checking for MinGW -- Checking for MinGW -- no -- Testing if rand() gives true alea -- Testing if rand() gives true alea -- Probably -- Testing if srand() yields a deterministic sequence -- Testing if srand() yields a deterministic sequence -- Yes -- HWLOC_INCDIR=/usr/include -- HWLOC_LIB=/usr/lib/libhwloc.so -- GMPECM_INCDIR=GMPECM_INCDIR-NOTFOUND -- GMPECM_LIB=GMPECM_LIB-NOTFOUND -- /usr/bin/python3 --version returned: Python 3.7.3 -- Importing module sqlite3 in Python succeeded. -- Perl version is 5.28.2 -- Testing whether C++11 alignas() can be used -- Testing whether C++11 alignas() can be used -- yes -- Testing whether C++11 glibc vector internals can be used -- yes -- Building with static libraries (ENABLE_SHARED="") -- Looking for pthread_create -- Looking for pthread_create - found -- Looking for pthread_barrier_wait -- Looking for pthread_barrier_wait - found -- MPI is not enabled -- Could NOT find OpenMP_C (missing: OpenMP_C_FLAGS OpenMP_C_LIB_NAMES) -- Could NOT find OpenMP_CXX (missing: OpenMP_CXX_FLAGS OpenMP_CXX_LIB_NAMES) -- Could NOT find OpenMP (missing: OpenMP_C_FOUND OpenMP_CXX_FOUND) -- Using libs: (math) (pthreads) -- GF(p) implementations enabled for DL linear algebra: p_1, p_2, p_3, p_4, p_5, p_6, p_7, p_8, p_9, p_10, p_11, p_12, p_13, p_14, p_15, pz -- GF(p) SpMV backends for DL linear algebra: basicp, zone -- GF(2) implementations enabled for linear algebra: u64k1, u64k2, u64k3, u64k4 -- GF(2) SpMV backends for linear algebra: bucket, basic, sliced -- Main scripts will go to /home/zadig/LORIA/travail/cado-nfs/installed/bin -- Libraries and binaries will go to /home/zadig/LORIA/travail/cado-nfs/installed/lib/cado-nfs-3.0.0 -- Data will go to /home/zadig/LORIA/travail/cado-nfs/installed/share/cado-nfs-3.0.0 -- Configuring done -- Generating done -- Build files have been written to: /home/zadig/LORIA/travail/cado-nfs/build/vannes Je vous joins mon local.sh. J'utilise clang8: $ clang++ --version clang version 8.0.0 (tags/RELEASE_800/final) Target: x86_64-pc-linux-gnu Thread model: posix InstalledDir: /usr/bin Bien à vous, Thomas |
local.sh
Description: application/shellscript
signature.asc
Description: OpenPGP digital signature
- [Cado-nfs-discuss] SIGSEGV sur le test full_c30, Thomas Bailleux, 04/29/2019
- Re: [Cado-nfs-discuss] SIGSEGV sur le test full_c30, Emmanuel Thomé, 04/29/2019
- Re: [Cado-nfs-discuss] SIGSEGV sur le test full_c30, Thomas Bailleux, 04/29/2019
