cado-nfs - [Cado-nfs-discuss] CmakeError.log
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] CmakeError.log
  • Date: Mon, 10 Jun 2019 04:29:55 -0400 (EDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=rjd1212@cox.net; spf=Pass smtp.mailfrom=rjd1212@cox.net; spf=None smtp.helo=postmaster@omta013.useast.a.cloudfilter.net
  • Importance: Medium
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi Paul,
Here is the Cmake-error.log , file with much more pertinent, accurate info as compared to the Cmake output file.
Previously, I tried to  apply various compiler patches to no avail.
Regards,
RJD
Performing C++ SOURCE FILE Test UINT64_T_IS_UNSIGNED_LONG_LONG failed with the following output:
Change Dir: /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp
Run Build Command(s):make cmTC_fe069/fast
make[1]: Entering directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
make -f CMakeFiles/cmTC_fe069.dir/build.make CMakeFiles/cmTC_fe069.dir/build
make[2]: Entering directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
Building CXX object CMakeFiles/cmTC_fe069.dir/src.cxx.o
/usr/bin/c++    -std=c++11 -g -W -Wall -O2  -Wno-literal-suffix -DUINT64_T_IS_UNSIGNED_LONG_LONG   -o CMakeFiles/cmTC_fe069.dir/src.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/src.cxx
/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/src.cxx: In function ‘int main()’:
/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/src.cxx:7:63: error: static assertion failed: not this type
    7 |     static_assert(std::is_same<uint64_t, unsigned long long>::value, "not this type");
make[2]: *** [CMakeFiles/cmTC_fe069.dir/build.make:66: CMakeFiles/cmTC_fe069.dir/src.cxx.o] Error 1
make[2]: Leaving directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
make[1]: *** [Makefile:121: cmTC_fe069/fast] Error 2
make[1]: Leaving directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
Source file was:
#include <type_traits>
#include <stdint.h>
#include <stdio.h>
int main()
    return 0;
Determining if the function strlcpy exists failed with the following output:
Run Build Command(s):make cmTC_b1432/fast
make -f CMakeFiles/cmTC_b1432.dir/build.make CMakeFiles/cmTC_b1432.dir/build
Building C object CMakeFiles/cmTC_b1432.dir/CheckFunctionExists.c.o
/usr/bin/cc   -std=c99 -g -W -Wall -O2  -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=strlcpy   -o CMakeFiles/cmTC_b1432.dir/CheckFunctionExists.c.o   -c /usr/share/cmake/Modules/CheckFunctionExists.c
Linking C executable cmTC_b1432
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_b1432.dir/link.txt --verbose=1
/usr/bin/cc -std=c99 -g -W -Wall -O2  -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=strlcpy    -rdynamic CMakeFiles/cmTC_b1432.dir/CheckFunctionExists.c.o  -o cmTC_b1432
/usr/bin/ld: CMakeFiles/cmTC_b1432.dir/CheckFunctionExists.c.o: in function `main':
/usr/share/cmake/Modules/CheckFunctionExists.c:17: undefined reference to `strlcpy'
collect2: error: ld returned 1 exit status
make[2]: *** [CMakeFiles/cmTC_b1432.dir/build.make:87: cmTC_b1432] Error 1
make[1]: *** [Makefile:121: cmTC_b1432/fast] Error 2
Determining if the function strlcat exists failed with the following output:
Run Build Command(s):make cmTC_bc6a1/fast
make -f CMakeFiles/cmTC_bc6a1.dir/build.make CMakeFiles/cmTC_bc6a1.dir/build
Building C object CMakeFiles/cmTC_bc6a1.dir/CheckFunctionExists.c.o
/usr/bin/cc   -std=c99 -g -W -Wall -O2  -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=strlcat   -o CMakeFiles/cmTC_bc6a1.dir/CheckFunctionExists.c.o   -c /usr/share/cmake/Modules/CheckFunctionExists.c
Linking C executable cmTC_bc6a1
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_bc6a1.dir/link.txt --verbose=1
/usr/bin/cc -std=c99 -g -W -Wall -O2  -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=strlcat    -rdynamic CMakeFiles/cmTC_bc6a1.dir/CheckFunctionExists.c.o  -o cmTC_bc6a1
/usr/bin/ld: CMakeFiles/cmTC_bc6a1.dir/CheckFunctionExists.c.o: in function `main':
/usr/share/cmake/Modules/CheckFunctionExists.c:17: undefined reference to `strlcat'
make[2]: *** [CMakeFiles/cmTC_bc6a1.dir/build.make:87: cmTC_bc6a1] Error 1
make[1]: *** [Makefile:121: cmTC_bc6a1/fast] Error 2
Performing C SOURCE FILE Test HAVE_GMPECM failed with the following output:
Run Build Command(s):make cmTC_3a227/fast
make -f CMakeFiles/cmTC_3a227.dir/build.make CMakeFiles/cmTC_3a227.dir/build
Building C object CMakeFiles/cmTC_3a227.dir/src.c.o
/usr/bin/cc   -std=c99 -g -W -Wall -O2  -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAVE_GMPECM -L/usr/local/lib   -o CMakeFiles/cmTC_3a227.dir/src.c.o   -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/src.c
Linking C executable cmTC_3a227
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_3a227.dir/link.txt --verbose=1
/usr/bin/cc -std=c99 -g -W -Wall -O2  -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAVE_GMPECM -L/usr/local/lib    -rdynamic CMakeFiles/cmTC_3a227.dir/src.c.o  -o cmTC_3a227 -lecm
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `base2mod_2':
/home/rjd/ecm-7.0.4/mpmod.c:165: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:155: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `ecm_redc_n':
/home/rjd/ecm-7.0.4/mpmod.c:199: undefined reference to `__gmpn_mullo_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:204: undefined reference to `__gmpn_mul_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:211: undefined reference to `__gmpn_add_nc'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:219: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `REDC':
/home/rjd/ecm-7.0.4/mpmod.c:247: undefined reference to `__gmpz_tdiv_r_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:248: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:249: undefined reference to `__gmpz_tdiv_r_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:250: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:251: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:252: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:237: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `ecm_sqrredc_basecase_n':
/home/rjd/ecm-7.0.4/mpmod.c:647: undefined reference to `__gmpn_sqr'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:648: undefined reference to `__gmpn_redc_1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:666: undefined reference to `__gmpn_sqr'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:668: undefined reference to `__gmpn_addmul_1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:669: undefined reference to `__gmpn_add_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:683: undefined reference to `__gmpn_sqr'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:653: undefined reference to `__gmpn_sqr'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:654: undefined reference to `__gmpn_redc_2'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `ecm_mulredc_basecase_n':
/home/rjd/ecm-7.0.4/mpmod.c:588: undefined reference to `__gmpn_mul_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:589: undefined reference to `__gmpn_redc_1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:607: undefined reference to `__gmpn_mul_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:609: undefined reference to `__gmpn_addmul_1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:610: undefined reference to `__gmpn_add_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:624: undefined reference to `__gmpn_mul_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:594: undefined reference to `__gmpn_mul_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:595: undefined reference to `__gmpn_redc_2'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `mpres_mpz_mod':
/home/rjd/ecm-7.0.4/mpmod.c:1366: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1369: undefined reference to `__gmpn_mul'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__gmpn_add':
/home/rjd/ecm-7.0.4/./gmp.h:2135: undefined reference to `__gmpn_add_n'
/home/rjd/ecm-7.0.4/mpmod.c:1371: undefined reference to `__gmpn_mul'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_isbase2':
/home/rjd/ecm-7.0.4/mpmod.c:63: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:64: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:65: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:66: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:67: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:68: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:69: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:76: undefined reference to `__gmpz_scan1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:78: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:79: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:82: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:84: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:85: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:86: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:98: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:99: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:91: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:92: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:93: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:94: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:95: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_clear':
/home/rjd/ecm-7.0.4/mpmod.c:807: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpmod_init_MPZ':
/home/rjd/ecm-7.0.4/mpmod.c:816: undefined reference to `__gmpz_init_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:823: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:824: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:825: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:826: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:828: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpmod_init_BASE2':
/home/rjd/ecm-7.0.4/mpmod.c:843: undefined reference to `__gmpz_init_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:850: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:851: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:853: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:854: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:858: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:859: undefined reference to `__gmpz_divisible_p'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:856: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:863: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:864: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:865: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpmod_init_MODMULN':
/home/rjd/ecm-7.0.4/mpmod.c:897: undefined reference to `__gmpz_init_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:904: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:905: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:908: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:909: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:910: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:911: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:914: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:915: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:916: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:919: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:920: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:921: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:923: undefined reference to `__gmpz_cdiv_q'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:924: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:927: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:928: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:931: undefined reference to `__gmpz_invert'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:932: undefined reference to `__gmpz_sub'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpmod_init_REDC':
/home/rjd/ecm-7.0.4/mpmod.c:945: undefined reference to `__gmpz_init_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:953: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:954: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:955: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:957: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:958: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:961: undefined reference to `__gmpz_invert'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:963: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:967: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:974: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:975: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:976: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:977: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:980: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:981: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:982: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:985: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:986: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:987: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:989: undefined reference to `__gmpz_cdiv_q'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpmod_clear':
/home/rjd/ecm-7.0.4/mpmod.c:997: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:998: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:999: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1004: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1005: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o):/home/rjd/ecm-7.0.4/mpmod.c:1006: more undefined references to `__gmpz_clear' follow
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpmod_init_set':
/home/rjd/ecm-7.0.4/mpmod.c:1024: undefined reference to `__gmpz_init_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1025: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1026: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1038: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1039: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1041: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1029: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1030: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1031: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1032: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1033: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1034: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_init':
/home/rjd/ecm-7.0.4/mpmod.c:1057: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_is_zero':
/home/rjd/ecm-7.0.4/mpmod.c:1244: undefined reference to `__gmpz_mod'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_mul_ui':
/home/rjd/ecm-7.0.4/mpmod.c:1557: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_mul_2exp':
/home/rjd/ecm-7.0.4/mpmod.c:1569: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_mul_z_to_z':
/home/rjd/ecm-7.0.4/mpmod.c:1640: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1653: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1654: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1656: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1675: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1677: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1678: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1682: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1664: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1666: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1667: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1672: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1629: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1635: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1637: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1632: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1642: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1645: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1681: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1670: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1593: undefined reference to `__gmpn_fft_best_k'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1617: undefined reference to `__gmpn_mul_fft'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1621: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1649: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1592: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1643: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_div_2exp':
/home/rjd/ecm-7.0.4/mpmod.c:1755: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1764: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1762: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1751: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1752: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_add_ui':
/home/rjd/ecm-7.0.4/mpmod.c:1777: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1778: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1783: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1784: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1785: undefined reference to `__gmpz_add'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_sub_ui':
/home/rjd/ecm-7.0.4/mpmod.c:1821: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1827: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1828: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1829: undefined reference to `__gmpz_sub'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_set_z':
/home/rjd/ecm-7.0.4/mpmod.c:1893: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1894: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1888: undefined reference to `__gmpz_mod'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_get_z':
/home/rjd/ecm-7.0.4/mpmod.c:1911: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `redc_basecase_n':
/home/rjd/ecm-7.0.4/mpmod.c:269: undefined reference to `__gmpn_redc_2'
/home/rjd/ecm-7.0.4/mpmod.c:1912: undefined reference to `__gmpz_realloc'
/home/rjd/ecm-7.0.4/mpmod.c:269: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_set_ui':
/home/rjd/ecm-7.0.4/mpmod.c:1940: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1945: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1946: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_set_si':
/home/rjd/ecm-7.0.4/mpmod.c:1958: undefined reference to `__gmpz_set_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1963: undefined reference to `__gmpz_set_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1964: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__gmpz_neg':
/home/rjd/ecm-7.0.4/./gmp.h:1809: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_invert':
/home/rjd/ecm-7.0.4/mpmod.c:1993: undefined reference to `__gmpz_invert'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1998: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2009: undefined reference to `__gmpz_mul'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_pow':
/home/rjd/ecm-7.0.4/mpmod.c:1159: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `mpres_pow_mul':
/home/rjd/ecm-7.0.4/mpmod.c:1108: undefined reference to `__gmpz_mul'
/home/rjd/ecm-7.0.4/mpmod.c:1178: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `mpres_pow_sqr':
/home/rjd/ecm-7.0.4/mpmod.c:1086: undefined reference to `__gmpz_mul'
/home/rjd/ecm-7.0.4/mpmod.c:1206: undefined reference to `__gmpz_scan1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1108: undefined reference to `__gmpz_mul'
/home/rjd/ecm-7.0.4/mpmod.c:1228: undefined reference to `__gmpz_set'
/home/rjd/ecm-7.0.4/mpmod.c:1100: undefined reference to `__gmpz_mul'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_realloc':
/home/rjd/ecm-7.0.4/mpmod.c:1065: undefined reference to `__gmpz_realloc'
/home/rjd/ecm-7.0.4/mpmod.c:1078: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1100: undefined reference to `__gmpz_mul'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_set_z_for_gcd_fix':
/home/rjd/ecm-7.0.4/mpmod.c:1717: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1721: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1726: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_ui_pow':
/home/rjd/ecm-7.0.4/mpmod.c:1327: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1290: undefined reference to `__gmpz_set_ui'
/home/rjd/ecm-7.0.4/mpmod.c:1316: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1317: undefined reference to `__gmpz_mod'
/home/rjd/ecm-7.0.4/mpmod.c:1310: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1311: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1312: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1257: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1293: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1294: undefined reference to `__gmpz_mod'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpresn_pad':
/home/rjd/ecm-7.0.4/mpmod.c:2235: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpresn_mul_ui':
/home/rjd/ecm-7.0.4/mpmod.c:2319: undefined reference to `__gmpn_mul_1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2321: undefined reference to `__gmpn_mul_1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2323: undefined reference to `__gmpn_add_nc'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2329: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `mulredc_1':
/home/rjd/ecm-7.0.4/mpmod.c:560: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpresn_add':
/home/rjd/ecm-7.0.4/mpmod.c:2366: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2371: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2352: undefined reference to `__gmpn_add_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2358: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpresn_sub':
/home/rjd/ecm-7.0.4/mpmod.c:2402: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2391: undefined reference to `__gmpn_add_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2394: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2407: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpresn_addsub':
/home/rjd/ecm-7.0.4/mpmod.c:2456: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2464: undefined reference to `__gmpn_add_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2467: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2461: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2435: undefined reference to `__gmpn_add_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2438: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2443: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:2448: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `mulredc':
/home/rjd/ecm-7.0.4/mpmod.c:409: undefined reference to `__gmpn_sub_n'
/home/rjd/ecm-7.0.4/mpmod.c:257: undefined reference to `__gmpz_sub'
/home/rjd/ecm-7.0.4/mpmod.c:648: undefined reference to `__gmpn_sub_n'
/home/rjd/ecm-7.0.4/mpmod.c:589: undefined reference to `__gmpn_sub_n'
/home/rjd/ecm-7.0.4/mpmod.c:1382: undefined reference to `__gmpz_mod'
/home/rjd/ecm-7.0.4/mpmod.c:830: undefined reference to `__gmpz_mod'
/home/rjd/ecm-7.0.4/mpmod.c:936: undefined reference to `__gmpn_copyi'
/home/rjd/ecm-7.0.4/mpmod.c:990: undefined reference to `__gmpz_mul'
/home/rjd/ecm-7.0.4/mpmod.c:1048: undefined reference to `__gmpn_copyi'
/home/rjd/ecm-7.0.4/mpmod.c:1057: undefined reference to `__gmpz_init2'
/home/rjd/ecm-7.0.4/mpmod.c:1559: undefined reference to `__gmpz_mod'
/home/rjd/ecm-7.0.4/mpmod.c:1571: undefined reference to `__gmpz_mod'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_set_z_for_gcd':
/home/rjd/ecm-7.0.4/mpmod.c:1697: undefined reference to `__gmpz_mod'
/home/rjd/ecm-7.0.4/mpmod.c:1743: undefined reference to `__gmpz_set'
/home/rjd/ecm-7.0.4/mpmod.c:1779: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1786: undefined reference to `__gmpz_mod'
/home/rjd/ecm-7.0.4/mpmod.c:1823: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1830: undefined reference to `__gmpz_mod'
/home/rjd/ecm-7.0.4/mpmod.c:1885: undefined reference to `__gmpz_mod'
/home/rjd/ecm-7.0.4/mpmod.c:1919: undefined reference to `__gmpz_mod'
/home/rjd/ecm-7.0.4/mpmod.c:1947: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1947: undefined reference to `__gmpz_mod'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o):/home/rjd/ecm-7.0.4/mpmod.c:1965: more undefined references to `__gmpz_mod' follow
/home/rjd/ecm-7.0.4/mpmod.c:1126: undefined reference to `__gmpz_powm'
/home/rjd/ecm-7.0.4/mpmod.c:1258: undefined reference to `__gmpz_powm'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_gcd':
/home/rjd/ecm-7.0.4/mpmod.c:2041: undefined reference to `__gmpz_gcd'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `base2mod':
/home/rjd/ecm-7.0.4/mpmod.c:117: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:118: undefined reference to `__gmpz_tdiv_r_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:122: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:125: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:127: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:128: undefined reference to `__gmpz_tdiv_r_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:132: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:130: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:120: undefined reference to `__gmpz_add'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_mul':
/home/rjd/ecm-7.0.4/mpmod.c:1465: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1461: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1418: undefined reference to `__gmpn_fft_best_k'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1442: undefined reference to `__gmpn_mul_fft'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1453: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1457: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1412: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_sqr':
/home/rjd/ecm-7.0.4/mpmod.c:1528: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1524: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1516: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1520: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_add':
/home/rjd/ecm-7.0.4/mpmod.c:1797: undefined reference to `__gmpz_add'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpmod.o): in function `__ecm_mpres_sub':
/home/rjd/ecm-7.0.4/mpmod.c:1868: undefined reference to `__gmpz_sub'
/home/rjd/ecm-7.0.4/mpmod.c:1802: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1804: undefined reference to `__gmpz_add'
/home/rjd/ecm-7.0.4/mpmod.c:1873: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpmod.c:1875: undefined reference to `__gmpz_add'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-rho.o): in function `rhoexact':
/home/rjd/ecm-7.0.4/rho.c:313: undefined reference to `log'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:315: undefined reference to `log'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-rho.o): in function `dilog':
/home/rjd/ecm-7.0.4/rho.c:280: undefined reference to `log'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:280: undefined reference to `log'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-rho.o):/home/rjd/ecm-7.0.4/rho.c:290: more undefined references to `log' follow
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-rho.o): in function `brentsuyama':
/home/rjd/ecm-7.0.4/rho.c:550: undefined reference to `pow'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:550: undefined reference to `exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:551: undefined reference to `pow'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:551: undefined reference to `exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:552: undefined reference to `pow'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:552: undefined reference to `exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-rho.o): in function `prob':
/home/rjd/ecm-7.0.4/rho.c:594: undefined reference to `exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:613: undefined reference to `log'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-rho.o): in function `dickmanmu_sum':
/home/rjd/ecm-7.0.4/rho.c:501: undefined reference to `log'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:502: undefined reference to `log'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:507: undefined reference to `log'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-rho.o):/home/rjd/ecm-7.0.4/rho.c:621: more undefined references to `log' follow
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-rho.o): in function `pm1prob':
/home/rjd/ecm-7.0.4/rho.c:660: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:662: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:663: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:665: undefined reference to `__gmpz_divisible_ui_p'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:669: undefined reference to `log'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:672: undefined reference to `__gmpz_tdiv_q_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:671: undefined reference to `__gmpz_divisible_ui_p'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:676: undefined reference to `__gmpz_get_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/rho.c:676: undefined reference to `log'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `ntt_coeff_mem':
/home/rjd/ecm-7.0.4/pm1fs2.c:217: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:218: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:219: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:223: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:224: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:221: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `test_P':
/home/rjd/ecm-7.0.4/pm1fs2.c:382: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:384: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:386: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:387: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:388: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:389: undefined reference to `__gmpz_fdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:390: undefined reference to `__gmpz_fdiv_q_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:394: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:395: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:396: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:397: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:398: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:399: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:405: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:406: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:407: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:408: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:409: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:412: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:414: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:415: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `V':
/home/rjd/ecm-7.0.4/pm1fs2.c:1142: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1183: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1106: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1117: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `scale_by_chebyshev':
/home/rjd/ecm-7.0.4/pm1fs2.c:1346: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o):/home/rjd/ecm-7.0.4/pm1fs2.c:1347: more undefined references to `__gmpz_set' follow
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `make_S_1_S_2':
/home/rjd/ecm-7.0.4/pm1fs2.c:2311: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2312: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2315: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2316: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2317: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `gfp_ext_pow_norm1_sl':
/home/rjd/ecm-7.0.4/pm1fs2.c:3216: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3217: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `ntt_sqr_reciprocal':
/home/rjd/ecm-7.0.4/pm1fs2.c:2485: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2435: undefined reference to `__gmpz_mul'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `list_sqr_reciprocal':
/home/rjd/ecm-7.0.4/pm1fs2.c:858: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:860: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:890: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:894: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:895: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:900: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `pm1_sequence_h':
/home/rjd/ecm-7.0.4/pm1fs2.c:2237: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2247: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2248: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2249: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2251: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2252: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2263: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2274: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2192: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2197: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `pm1_sequence_g':
/home/rjd/ecm-7.0.4/pm1fs2.c:2036: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2060: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2070: undefined reference to `__gmpz_set_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2072: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2073: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2076: undefined reference to `__gmpz_set_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2077: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2081: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2082: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2083: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2099: undefined reference to `__gmpz_set_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2112: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2149: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `ntt_gcd':
/home/rjd/ecm-7.0.4/pm1fs2.c:2584: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2600: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2612: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2613: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2615: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `gfp_ext_print':
/home/rjd/ecm-7.0.4/pm1fs2.c:3091: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3092: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3097: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3098: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `pp1_sequence_g':
/home/rjd/ecm-7.0.4/pm1fs2.c:3479: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3511: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3512: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3513: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `gfp_ext_pow_norm1':
/home/rjd/ecm-7.0.4/pm1fs2.c:3266: undefined reference to `__gmpz_init'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `__gmpz_abs':
/home/rjd/ecm-7.0.4/./gmp.h:1711: undefined reference to `__gmpz_set'
/home/rjd/ecm-7.0.4/pm1fs2.c:3268: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3271: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3272: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3278: undefined reference to `__gmpz_tstbit'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3285: undefined reference to `__gmpz_clear'
/home/rjd/ecm-7.0.4/pm1fs2.c:3677: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3620: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3637: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3653: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3658: undefined reference to `__gmpz_clear'
/home/rjd/ecm-7.0.4/pm1fs2.c:3290: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3294: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `print_CRT_primes':
/home/rjd/ecm-7.0.4/pm1fs2.c:197: undefined reference to `log'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:201: undefined reference to `log'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `list_scale_V':
/home/rjd/ecm-7.0.4/pm1fs2.c:1403: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1450: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1455: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1509: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1510: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1511: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1536: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1540: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1626: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1627: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1628: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1630: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1631: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1635: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1636: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1637: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1638: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1643: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1644: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1645: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1648: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1649: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1653: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1602: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1603: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1604: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1606: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1607: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1608: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1609: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1610: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1379: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1380: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1589: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1590: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1591: undefined reference to `__gmpz_sub'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `poly_from_sets_V':
/home/rjd/ecm-7.0.4/pm1fs2.c:1828: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1860: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `list_mul_reciprocal':
/home/rjd/ecm-7.0.4/pm1fs2.c:1009: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1011: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1016: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1018: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1022: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1025: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1035: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1045: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1050: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1057: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1064: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1065: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1068: undefined reference to `__gmpz_set'
/home/rjd/ecm-7.0.4/pm1fs2.c:1813: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:1816: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `build_F_ntt':
/home/rjd/ecm-7.0.4/pm1fs2.c:1958: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `pp1_sequence_h':
/home/rjd/ecm-7.0.4/pm1fs2.c:3776: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3994: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4002: undefined reference to `__gmp_printf'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3724: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3735: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `__ecm_choose_P':
/home/rjd/ecm-7.0.4/pm1fs2.c:602: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:615: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:616: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:617: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:618: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:619: undefined reference to `__gmpz_init'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o):/home/rjd/ecm-7.0.4/pm1fs2.c:620: more undefined references to `__gmpz_init' follow
/home/rjd/ecm-7.0.4/pm1fs2.c:622: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:623: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:652: undefined reference to `__gmpz_cdiv_q_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:653: undefined reference to `__gmpz_cdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:655: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:670: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:739: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:740: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:741: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:742: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:743: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o):/home/rjd/ecm-7.0.4/pm1fs2.c:744: more undefined references to `__gmpz_clear' follow
/home/rjd/ecm-7.0.4/pm1fs2.c:704: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:714: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:731: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:734: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:736: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `__ecm_pm1fs2':
/home/rjd/ecm-7.0.4/pm1fs2.c:2663: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2725: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2842: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2864: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2844: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `__ecm_pm1fs2_ntt':
/home/rjd/ecm-7.0.4/pm1fs2.c:2930: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2996: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3050: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3067: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3052: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3061: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:3018: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:2984: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `__ecm_pp1fs2':
/home/rjd/ecm-7.0.4/pm1fs2.c:4045: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4184: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4208: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4216: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4210: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1fs2.o): in function `__ecm_pp1fs2_ntt':
/home/rjd/ecm-7.0.4/pm1fs2.c:4283: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4292: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4500: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4521: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4290: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4502: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4511: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4403: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4329: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1fs2.c:4300: undefined reference to `__gmpz_clear'
/home/rjd/ecm-7.0.4/pm1fs2.c:2436: undefined reference to `__gmpz_mod'
/home/rjd/ecm-7.0.4/pm1fs2.c:903: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-sets_long.o): in function `sets_max_recurse':
/home/rjd/ecm-7.0.4/sets_long.c:176: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-sets_long.o): in function `__ecm_sets_max':
/home/rjd/ecm-7.0.4/sets_long.c:192: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-sets_long.o): in function `__ecm_sets_sumset_minmax':
/home/rjd/ecm-7.0.4/sets_long.c:251: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/sets_long.c:264: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/sets_long.c:266: undefined reference to `__gmpz_sub_ui'
/home/rjd/ecm-7.0.4/sets_long.c:184: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm.o): in function `__ecm_ecm_mul':
/home/rjd/ecm-7.0.4/ecm.c:208: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:219: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:221: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:222: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:229: undefined reference to `__gmpz_tstbit'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:241: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:242: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:208: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:195: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:196: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm.o): in function `__ecm_choose_S':
/home/rjd/ecm-7.0.4/ecm.c:828: undefined reference to `__gmpz_cmp_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:830: undefined reference to `__gmpz_cmp_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:832: undefined reference to `__gmpz_cmp_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:834: undefined reference to `__gmpz_cmp_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:836: undefined reference to `__gmpz_cmp_d'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm.o): in function `__ecm_print_expcurves':
/home/rjd/ecm-7.0.4/ecm.c:874: undefined reference to `pow'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:872: undefined reference to `__gmpz_get_d'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm.o): in function `__ecm_print_exptime':
/home/rjd/ecm-7.0.4/ecm.c:920: undefined reference to `pow'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:918: undefined reference to `__gmpz_get_d'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm.o): in function `__ecm_print_B1_B2_poly':
/home/rjd/ecm-7.0.4/ecm.c:987: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:989: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm.o): in function `__ecm_set_stage_2_params':
/home/rjd/ecm-7.0.4/ecm.c:1018: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1019: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1021: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1037: undefined reference to `__gmpz_cmp_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1038: undefined reference to `pow'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1038: undefined reference to `__gmpz_set_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1042: undefined reference to `__gmpz_set_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1073: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1074: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1076: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm.o): in function `ecm':
/home/rjd/ecm-7.0.4/ecm.c:1214: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1263: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1264: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1270: undefined reference to `__gmpz_cmp_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1400: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1405: undefined reference to `__gmpz_cmp_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1435: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1557: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1574: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1586: undefined reference to `__gmpz_cmp_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1604: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1605: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1606: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1222: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1229: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1385: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1397: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1271: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1186: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm.o): in function `prac':
/home/rjd/ecm-7.0.4/ecm.c:396: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:397: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:398: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:399: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:486: undefined reference to `__gmpz_swap'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:487: undefined reference to `__gmpz_swap'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:408: undefined reference to `__gmpz_swap'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:409: undefined reference to `__gmpz_swap'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:419: undefined reference to `__gmpz_swap'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm.o):/home/rjd/ecm-7.0.4/ecm.c:420: more undefined references to `__gmpz_swap' follow
/home/rjd/ecm-7.0.4/ecm.c:1494: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1504: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1518: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1519: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1520: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1522: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1523: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1524: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1537: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1538: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1539: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1561: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm.c:1569: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm.o): in function `__ecm_add3':
/home/rjd/ecm-7.0.4/ecm.c:153: undefined reference to `__gmpz_swap'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-factor.o): in function `ecm_init':
/home/rjd/ecm-7.0.4/factor.c:42: undefined reference to `__gmpz_init_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:43: undefined reference to `__gmpz_init_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:44: undefined reference to `__gmpz_init_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:46: undefined reference to `__gmpz_init_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:47: undefined reference to `__gmpz_init_set_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-factor.o):/home/rjd/ecm-7.0.4/factor.c:48: more undefined references to `__gmpz_init_set_ui' follow
/home/rjd/ecm-7.0.4/factor.c:58: undefined reference to `__gmpz_init_set_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:59: undefined reference to `__gmpz_init_set_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:71: undefined reference to `__gmp_randinit_default'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:72: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:77: undefined reference to `__gmpz_init_set_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-factor.o): in function `ecm_clear':
/home/rjd/ecm-7.0.4/factor.c:91: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:92: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:93: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:94: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:95: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-factor.o):/home/rjd/ecm-7.0.4/factor.c:96: more undefined references to `__gmpz_clear' follow
/home/rjd/ecm-7.0.4/factor.c:97: undefined reference to `__gmp_randclear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:98: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:99: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:100: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:101: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:102: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-factor.o):/home/rjd/ecm-7.0.4/factor.c:103: more undefined references to `__gmpz_clear' follow
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-factor.o): in function `ecm_factor':
/home/rjd/ecm-7.0.4/factor.c:122: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:127: undefined reference to `__gmpz_divisible_2exp_p'
/usr/bin/ld: /home/rjd/ecm-7.0.4/factor.c:129: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1.o): in function `mulcascade_mul_d':
/home/rjd/ecm-7.0.4/pm1.c:84: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:98: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:99: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:92: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:108: undefined reference to `__gmpz_init'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1.o): in function `pm1':
/home/rjd/ecm-7.0.4/pm1.c:382: undefined reference to `__gmpz_divisible_2exp_p'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:393: undefined reference to `__gmpz_init_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:394: undefined reference to `__gmpz_init_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:397: undefined reference to `__gmpz_cmp_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:421: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:423: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:425: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:427: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:428: undefined reference to `__gmpz_init'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1.o):/home/rjd/ecm-7.0.4/pm1.c:429: more undefined references to `__gmpz_init' follow
/home/rjd/ecm-7.0.4/pm1.c:485: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:486: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:487: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:398: undefined reference to `pow'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:398: undefined reference to `__gmpz_set_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:384: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:402: undefined reference to `__gmpz_set_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:497: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:498: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:513: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:517: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:518: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:519: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:520: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:521: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1.o):/home/rjd/ecm-7.0.4/pm1.c:522: more undefined references to `__gmpz_clear' follow
/home/rjd/ecm-7.0.4/pm1.c:535: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:564: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1.o): in function `pm1_stage1':
/home/rjd/ecm-7.0.4/pm1.c:162: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:163: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:165: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:172: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1.o): in function `mulcascade_init':
/home/rjd/ecm-7.0.4/pm1.c:57: undefined reference to `__gmpz_init'
/home/rjd/ecm-7.0.4/pm1.c:203: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1.o): in function `mulcascade_set':
/home/rjd/ecm-7.0.4/pm1.c:118: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1.o): in function `mulcascade_get_z':
/home/rjd/ecm-7.0.4/pm1.c:128: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:132: undefined reference to `__gmpz_mul'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1.o): in function `mulcascade_free':
/home/rjd/ecm-7.0.4/pm1.c:68: undefined reference to `__gmpz_clear'
/home/rjd/ecm-7.0.4/pm1.c:230: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:242: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:250: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:251: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:254: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:276: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:277: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:280: undefined reference to `__gmpz_set_ui'
/home/rjd/ecm-7.0.4/pm1.c:504: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:505: undefined reference to `__gmpz_set'
/home/rjd/ecm-7.0.4/pm1.c:310: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:318: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:319: undefined reference to `__gmpz_clear'
/home/rjd/ecm-7.0.4/pm1.c:582: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:600: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:601: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:602: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:573: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:576: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pm1.o): in function `print_prob':
/home/rjd/ecm-7.0.4/pm1.c:338: undefined reference to `pow'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:338: undefined reference to `__gmpz_get_d'
/home/rjd/ecm-7.0.4/pm1.c:159: undefined reference to `sqrt'
/home/rjd/ecm-7.0.4/pm1.c:93: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:80: undefined reference to `__gmpz_set_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pm1.c:109: undefined reference to `__gmpz_swap'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pp1.o): in function `pp1_mul':
/home/rjd/ecm-7.0.4/pp1.c:69: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:76: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:79: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:82: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:85: undefined reference to `__gmpz_tstbit'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:107: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pp1.o): in function `pp1':
/home/rjd/ecm-7.0.4/pp1.c:302: undefined reference to `__gmpz_init_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:303: undefined reference to `__gmpz_init_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:306: undefined reference to `__gmpz_cmp_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:320: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:401: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:425: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pp1.o): in function `pp1_stage1':
/home/rjd/ecm-7.0.4/pp1.c:135: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:144: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:147: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:160: undefined reference to `__gmpz_probab_prime_p'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:167: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:177: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:178: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:181: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:228: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:238: undefined reference to `__gmpz_clear'
/home/rjd/ecm-7.0.4/pp1.c:440: undefined reference to `__gmpz_init_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:448: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:459: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:464: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:465: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:466: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:307: undefined reference to `pow'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:307: undefined reference to `__gmpz_set_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:311: undefined reference to `__gmpz_set_d'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:434: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:437: undefined reference to `__gmpz_clear'
/home/rjd/ecm-7.0.4/pp1.c:162: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:163: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-pp1.o): in function `pp1_check_factor':
/home/rjd/ecm-7.0.4/pp1.c:250: undefined reference to `__gmpz_probab_prime_p'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:252: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:253: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:254: undefined reference to `__gmpz_jacobi'
/home/rjd/ecm-7.0.4/pp1.c:370: undefined reference to `__gmpz_clear'
/home/rjd/ecm-7.0.4/pp1.c:142: undefined reference to `sqrt'
/home/rjd/ecm-7.0.4/pp1.c:108: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/pp1.c:71: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-lucas.o): in function `__ecm_pp1_mul_prac':
/home/rjd/ecm-7.0.4/lucas.c:74: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/lucas.c:75: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/lucas.c:144: undefined reference to `__gmpz_swap'
/usr/bin/ld: /home/rjd/ecm-7.0.4/lucas.c:84: undefined reference to `__gmpz_swap'
/usr/bin/ld: /home/rjd/ecm-7.0.4/lucas.c:106: undefined reference to `__gmpz_swap'
/usr/bin/ld: /home/rjd/ecm-7.0.4/lucas.c:94: undefined reference to `__gmpz_swap'
/usr/bin/ld: /home/rjd/ecm-7.0.4/lucas.c:129: undefined reference to `__gmpz_swap'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-stage2.o): in function `__ecm_init_progression_coeffs':
/home/rjd/ecm-7.0.4/stage2.c:169: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:171: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:173: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:182: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:183: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:188: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:189: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:190: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:191: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:193: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:194: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:195: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:215: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:199: undefined reference to `__gmpz_gcd_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-stage2.o): in function `fin_diff_coeff':
/home/rjd/ecm-7.0.4/stage2.c:113: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:114: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-stage2.o): in function `dickson':
/home/rjd/ecm-7.0.4/stage2.c:53: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:55: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:56: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:78: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:79: undefined reference to `__gmpz_ui_pow_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:82: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:83: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:87: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:88: undefined reference to `__gmpz_clear'
/home/rjd/ecm-7.0.4/stage2.c:122: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:127: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:121: undefined reference to `__gmpz_pow_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:60: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:61: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:65: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:69: undefined reference to `__gmpz_mul_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:70: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:71: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:72: undefined reference to `__gmpz_sub'
/home/rjd/ecm-7.0.4/stage2.c:129: undefined reference to `__gmpz_clear'
/home/rjd/ecm-7.0.4/stage2.c:210: undefined reference to `__gmpz_gcd_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:218: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:219: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:220: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-stage2.o): in function `__ecm_init_roots_params':
/home/rjd/ecm-7.0.4/stage2.c:250: undefined reference to `log'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:258: undefined reference to `log'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-stage2.o): in function `__ecm_stage2':
/home/rjd/ecm-7.0.4/stage2.c:380: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:387: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:435: undefined reference to `__gmpz_init_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:758: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:423: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:497: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:550: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:730: undefined reference to `__gmpz_gcd'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:731: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:512: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/stage2.c:562: undefined reference to `__gmpz_cmp_si'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-median.o): in function `list_sub_safe':
/home/rjd/ecm-7.0.4/median.c:321: undefined reference to `__gmpz_sub'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-median.o): in function `__gmpz_neg':
/home/rjd/ecm-7.0.4/median.c:323: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:330: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-median.o): in function `TKarMul':
/home/rjd/ecm-7.0.4/median.c:123: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:125: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:108: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:110: undefined reference to `__gmpz_addmul'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-median.o): in function `TToomCookMul':
/home/rjd/ecm-7.0.4/median.c:463: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:516: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:517: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:521: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:545: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:547: undefined reference to `__gmpz_addmul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:561: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:563: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:568: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:569: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-median.o): in function `list_add_safe':
/home/rjd/ecm-7.0.4/median.c:356: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:363: undefined reference to `__gmpz_set'
/home/rjd/ecm-7.0.4/median.c:630: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:643: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:649: undefined reference to `__gmpz_tdiv_q_2exp'
/home/rjd/ecm-7.0.4/median.c:358: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/median.c:365: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-median.o): in function `__ecm_TMulGen':
/home/rjd/ecm-7.0.4/median.c:747: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `F_mul_sqrt2exp':
/home/rjd/ecm-7.0.4/schoen_strass.c:355: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:356: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:357: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:358: undefined reference to `__gmpz_tdiv_r_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:359: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:360: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:376: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:377: undefined reference to `__gmpz_tdiv_r_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:379: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:380: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:364: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `mpz_absadd_2exp':
/home/rjd/ecm-7.0.4/schoen_strass.c:186: undefined reference to `__gmpz_realloc2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:204: undefined reference to `__gmpz_realloc2'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `F_divby3_1':
/home/rjd/ecm-7.0.4/schoen_strass.c:246: undefined reference to `__gmpn_mod_34lsub1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:246: undefined reference to `__gmpn_mod_34lsub1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:264: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:253: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:262: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:255: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `F_divby2':
/home/rjd/ecm-7.0.4/schoen_strass.c:220: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:220: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `F_mul_sqrt2exp_2':
/home/rjd/ecm-7.0.4/schoen_strass.c:400: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:401: undefined reference to `__gmpz_tdiv_r_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:402: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `F_mod_1':
/home/rjd/ecm-7.0.4/schoen_strass.c:94: undefined reference to `__gmpz_tdiv_r_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:99: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:94: undefined reference to `__gmpz_tdiv_r_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `F_mulmod':
/home/rjd/ecm-7.0.4/schoen_strass.c:153: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:156: undefined reference to `__gmpn_fft_best_k'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:159: undefined reference to `__gmpn_mul_fft'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `F_mod_gt':
/home/rjd/ecm-7.0.4/schoen_strass.c:119: undefined reference to `__gmpz_tdiv_r_2exp'
/home/rjd/ecm-7.0.4/schoen_strass.c:165: undefined reference to `__gmpz_mul'
/home/rjd/ecm-7.0.4/schoen_strass.c:127: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:128: undefined reference to `__gmpz_tdiv_r_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:97: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:119: undefined reference to `__gmpz_tdiv_r_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o):/home/rjd/ecm-7.0.4/schoen_strass.c:119: more undefined references to `__gmpz_tdiv_r_2exp' follow
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `F_fft_dif':
/home/rjd/ecm-7.0.4/schoen_strass.c:436: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:437: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:440: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:441: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:443: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:444: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:445: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:446: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:450: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:451: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:454: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:455: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:457: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:458: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:459: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:460: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:430: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:430: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:129: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:123: undefined reference to `__gmpz_sub_ui'
/home/rjd/ecm-7.0.4/schoen_strass.c:132: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:121: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `F_fft_dit':
/home/rjd/ecm-7.0.4/schoen_strass.c:509: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:510: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:513: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:514: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:516: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:517: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:518: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:509: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:519: undefined reference to `__gmpz_sub'
/home/rjd/ecm-7.0.4/schoen_strass.c:534: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:535: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:538: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:539: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:541: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:542: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:543: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:544: undefined reference to `__gmpz_sub'
/home/rjd/ecm-7.0.4/schoen_strass.c:495: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:495: undefined reference to `__gmpz_add'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `F_toomcook4':
/home/rjd/ecm-7.0.4/schoen_strass.c:601: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:602: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:603: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:605: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:606: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:607: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:608: undefined reference to `__gmpz_add'
/home/rjd/ecm-7.0.4/schoen_strass.c:613: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:614: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:615: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:616: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:617: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:618: undefined reference to `__gmpz_add'
/home/rjd/ecm-7.0.4/schoen_strass.c:621: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:622: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:623: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:625: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:626: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:627: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:628: undefined reference to `__gmpz_add'
/home/rjd/ecm-7.0.4/schoen_strass.c:633: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:635: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:636: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:638: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:640: undefined reference to `__gmpz_add'
/home/rjd/ecm-7.0.4/schoen_strass.c:645: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:646: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:648: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:650: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:652: undefined reference to `__gmpz_add'
/home/rjd/ecm-7.0.4/schoen_strass.c:593: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:594: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:595: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:596: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:597: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:598: undefined reference to `__gmpz_add'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `__ecm_F_mul':
/home/rjd/ecm-7.0.4/schoen_strass.c:868: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:886: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:972: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:976: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:984: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:988: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:1009: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `F_karatsuba':
/home/rjd/ecm-7.0.4/schoen_strass.c:785: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:786: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:833: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:834: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:835: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:836: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:838: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:839: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:841: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:842: undefined reference to `__gmpz_sub'
/home/rjd/ecm-7.0.4/schoen_strass.c:1036: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:1037: undefined reference to `__gmpz_add'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o):/home/rjd/ecm-7.0.4/schoen_strass.c:94: more undefined references to `__gmpz_tdiv_r_2exp' follow
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `F_divby5_1':
/home/rjd/ecm-7.0.4/schoen_strass.c:277: undefined reference to `__gmpn_mod_34lsub1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:318: undefined reference to `__gmpz_divexact_ui'
/home/rjd/ecm-7.0.4/schoen_strass.c:714: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:716: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:720: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:721: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:723: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:725: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:681: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:683: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:684: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:687: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:689: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:694: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:695: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:696: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:698: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:699: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:700: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:701: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:703: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:704: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:707: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:708: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:709: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:710: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:711: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:314: undefined reference to `__gmpz_sub_ui'
/home/rjd/ecm-7.0.4/schoen_strass.c:730: undefined reference to `__gmpz_add'
/home/rjd/ecm-7.0.4/schoen_strass.c:733: undefined reference to `__gmpz_set'
/home/rjd/ecm-7.0.4/schoen_strass.c:737: undefined reference to `__gmpz_add'
/home/rjd/ecm-7.0.4/schoen_strass.c:743: undefined reference to `__gmpz_add'
/home/rjd/ecm-7.0.4/schoen_strass.c:746: undefined reference to `__gmpz_set'
/home/rjd/ecm-7.0.4/schoen_strass.c:750: undefined reference to `__gmpz_add'
/home/rjd/ecm-7.0.4/schoen_strass.c:756: undefined reference to `__gmpz_add'
/home/rjd/ecm-7.0.4/schoen_strass.c:759: undefined reference to `__gmpz_set'
/home/rjd/ecm-7.0.4/schoen_strass.c:763: undefined reference to `__gmpz_add'
/home/rjd/ecm-7.0.4/schoen_strass.c:284: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:286: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:293: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:295: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:302: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:304: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:312: undefined reference to `__gmpz_add_ui'
/home/rjd/ecm-7.0.4/schoen_strass.c:811: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:812: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:813: undefined reference to `__gmpz_set'
/home/rjd/ecm-7.0.4/schoen_strass.c:877: undefined reference to `__gmpz_add'
/home/rjd/ecm-7.0.4/schoen_strass.c:880: undefined reference to `__gmpz_set'
/home/rjd/ecm-7.0.4/schoen_strass.c:986: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:132: undefined reference to `__gmpz_set'
/home/rjd/ecm-7.0.4/schoen_strass.c:974: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `__ecm_F_mul_trans':
/home/rjd/ecm-7.0.4/schoen_strass.c:1163: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:1169: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:1171: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:1190: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:1217: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:1225: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:1230: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:1234: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:1239: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:1139: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:1219: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-schoen_strass.o): in function `__ecm_F_clear':
/home/rjd/ecm-7.0.4/schoen_strass.c:1248: undefined reference to `__gmpz_clear'
/home/rjd/ecm-7.0.4/schoen_strass.c:232: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/schoen_strass.c:230: undefined reference to `__gmpz_sub_ui'
/home/rjd/ecm-7.0.4/schoen_strass.c:403: undefined reference to `__gmpz_sub'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ks-multiply.o): in function `list_mul_n_kara2':
/home/rjd/ecm-7.0.4/ks-multiply.c:93: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:94: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:95: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:96: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:97: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:98: undefined reference to `__gmpz_sub'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ks-multiply.o): in function `list_mul_n_karatsuba_aux':
/home/rjd/ecm-7.0.4/ks-multiply.c:165: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:153: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:154: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ks-multiply.o): in function `list_mul_n_kara3':
/home/rjd/ecm-7.0.4/ks-multiply.c:106: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:107: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:108: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:109: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:110: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:111: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:113: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:114: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:115: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:116: undefined reference to `__gmpz_swap'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:117: undefined reference to `__gmpz_swap'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:118: undefined reference to `__gmpz_mul'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ks-multiply.o): in function `unpack':
/home/rjd/ecm-7.0.4/ks-multiply.c:61: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ks-multiply.o): in function `__ecm_list_mul_n_basecase':
/home/rjd/ecm-7.0.4/ks-multiply.c:86: undefined reference to `__gmpz_addmul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:84: undefined reference to `__gmpz_mul'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ks-multiply.o): in function `__ecm_list_mul_n_KS1':
/home/rjd/ecm-7.0.4/ks-multiply.c:210: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:212: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:242: undefined reference to `__gmpn_mul_n'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ks-multiply.o): in function `__ecm_list_mul_n_KS2':
/home/rjd/ecm-7.0.4/ks-multiply.c:274: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:276: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:323: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:326: undefined reference to `__gmpn_add_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:333: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:336: undefined reference to `__gmpn_add_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:339: undefined reference to `__gmpn_mul_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:340: undefined reference to `__gmpn_mul_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:344: undefined reference to `__gmpn_add_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:345: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:352: undefined reference to `__gmpn_rshift'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:335: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:349: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:350: undefined reference to `__gmpn_add_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:325: undefined reference to `__gmpn_sub_n'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ks-multiply.o): in function `__ecm_TMulKS':
/home/rjd/ecm-7.0.4/ks-multiply.c:428: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:427: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:435: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:434: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:483: undefined reference to `__gmpn_mulmod_bnm1_next_size'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:503: undefined reference to `__gmpn_mulmod_bnm1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:501: undefined reference to `__gmpn_mulmod_bnm1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:525: undefined reference to `__gmpz_realloc'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ks-multiply.o): in function `__ecm_ks_wrapmul_m':
/home/rjd/ecm-7.0.4/ks-multiply.c:554: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:558: undefined reference to `__gmpn_mulmod_bnm1_next_size'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ks-multiply.o): in function `__ecm_ks_wrapmul':
/home/rjd/ecm-7.0.4/ks-multiply.c:591: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:593: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:594: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:596: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:597: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:628: undefined reference to `__gmpn_mulmod_bnm1_next_size'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:632: undefined reference to `__gmpn_mulmod_bnm1_next_size'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:653: undefined reference to `__gmpn_mulmod_bnm1'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:663: undefined reference to `__gmpz_realloc'
/home/rjd/ecm-7.0.4/ks-multiply.c:99: undefined reference to `__gmpz_sub'
/home/rjd/ecm-7.0.4/ks-multiply.c:119: undefined reference to `__gmpz_sub'
/home/rjd/ecm-7.0.4/ks-multiply.c:76: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ks-multiply.c:76: undefined reference to `__gmpz_mul'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-bestd.o): in function `__ecm_bestD':
/home/rjd/ecm-7.0.4/bestd.c:124: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:132: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:133: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:134: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:135: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:153: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:192: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:193: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:194: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:195: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:196: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:197: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:198: undefined reference to `__gmpz_cdiv_q_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:199: undefined reference to `__gmpz_fdiv_q_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:202: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:203: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:215: undefined reference to `__gmpz_cdiv_q_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:217: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:218: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:208: undefined reference to `__gmpz_fdiv_q_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:209: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:210: undefined reference to `__gmpz_fdiv_q_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:211: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:268: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:269: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:277: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:278: undefined reference to `__gmpz_cdiv_q_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:279: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:280: undefined reference to `__gmpz_fdiv_qr_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:281: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:282: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:287: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:301: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:302: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:303: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:306: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:307: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:308: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:309: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:272: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/bestd.c:273: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-auxlib.o): in function `__ecm_mpz_divby3_1op':
/home/rjd/ecm-7.0.4/auxlib.c:87: undefined reference to `__gmpn_divexact_by3c'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-auxlib.o): in function `__ecm_outputf':
/home/rjd/ecm-7.0.4/auxlib.c:207: undefined reference to `__gmp_vfprintf'
/usr/bin/ld: /home/rjd/ecm-7.0.4/auxlib.c:211: undefined reference to `__gmp_vfprintf'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-auxlib.o): in function `__ecm_writechkfile':
/home/rjd/ecm-7.0.4/auxlib.c:243: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/auxlib.c:245: undefined reference to `__gmp_fprintf'
/usr/bin/ld: /home/rjd/ecm-7.0.4/auxlib.c:248: undefined reference to `__gmp_fprintf'
/usr/bin/ld: /home/rjd/ecm-7.0.4/auxlib.c:255: undefined reference to `__gmp_fprintf'
/usr/bin/ld: /home/rjd/ecm-7.0.4/auxlib.c:264: undefined reference to `__gmp_fprintf'
/usr/bin/ld: /home/rjd/ecm-7.0.4/auxlib.c:267: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/auxlib.c:261: undefined reference to `__gmp_fprintf'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-auxlib.o): in function `__ecm_mpz_add_si':
/home/rjd/ecm-7.0.4/auxlib.c:64: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/auxlib.c:66: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-auxlib.o): in function `__ecm_mpz_sub_si':
/home/rjd/ecm-7.0.4/auxlib.c:73: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/auxlib.c:75: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-random.o): in function `__ecm_pm1_random_seed':
/home/rjd/ecm-7.0.4/random.c:62: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/random.c:65: undefined reference to `__gmpz_urandomb'
/usr/bin/ld: /home/rjd/ecm-7.0.4/random.c:66: undefined reference to `__gmpz_gcd'
/usr/bin/ld: /home/rjd/ecm-7.0.4/random.c:68: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/random.c:69: undefined reference to `__gmpz_cmp_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/random.c:70: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-random.o): in function `__ecm_pp1_random_seed':
/home/rjd/ecm-7.0.4/random.c:81: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/random.c:84: undefined reference to `__gmpz_urandomb'
/usr/bin/ld: /home/rjd/ecm-7.0.4/random.c:85: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/random.c:86: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/random.c:87: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/random.c:88: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/random.c:89: undefined reference to `__gmpz_gcd'
/usr/bin/ld: /home/rjd/ecm-7.0.4/random.c:91: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/random.c:92: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-random.o): in function `__ecm_init_randstate':
/home/rjd/ecm-7.0.4/random.c:52: undefined reference to `__gmp_randseed_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpzspm.o): in function `mpzspm_max_len':
/home/rjd/ecm-7.0.4/mpzspm.c:97: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpzspm.o): in function `mpzspm_init':
/home/rjd/ecm-7.0.4/mpzspm.c:196: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:205: undefined reference to `__gmpz_init_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:207: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:210: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:211: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:212: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:213: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:214: undefined reference to `__gmpz_init'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpzspm.o): in function `mpz_set_uint64':
/home/rjd/ecm-7.0.4/ecm-gmp.h:190: undefined reference to `__gmpz_set_ui'
/home/rjd/ecm-7.0.4/mpzspm.c:241: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:242: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:246: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:247: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:248: undefined reference to `__gmpz_mul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:249: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:253: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:261: undefined reference to `__gmpz_init_set'
/home/rjd/ecm-7.0.4/mpzspm.c:289: undefined reference to `__gmpz_fdiv_q'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:290: undefined reference to `__gmpz_fdiv_r'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:295: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:296: undefined reference to `__gmpz_mod'
/home/rjd/ecm-7.0.4/mpzspm.c:302: undefined reference to `__gmpz_fdiv_r'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:307: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:308: undefined reference to `__gmpz_sub'
/home/rjd/ecm-7.0.4/mpzspm.c:310: undefined reference to `__gmpz_fdiv_r'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:314: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:319: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:320: undefined reference to `__gmpz_init_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:321: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:324: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:325: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:326: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:327: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:328: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpzspm.o): in function `mpzspm_product_tree_init':
/home/rjd/ecm-7.0.4/mpzspm.c:139: undefined reference to `__gmpz_init'
/home/rjd/ecm-7.0.4/mpzspm.c:151: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:149: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:153: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpzspm.o): in function `mpzspm_product_tree_clear':
/home/rjd/ecm-7.0.4/mpzspm.c:372: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpzspm.o): in function `mpzspm_clear':
/home/rjd/ecm-7.0.4/mpzspm.c:387: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:393: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspm.c:401: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpzspv.o): in function `mpzspv_from_mpzv_fast':
/home/rjd/ecm-7.0.4/mpzspv.c:278: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspv.c:279: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspv.c:285: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspv.c:286: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspv.c:295: undefined reference to `__gmpn_mod_1'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpzspv.o): in function `ecm_mod_1':
/home/rjd/ecm-7.0.4/mpzspv.c:200: undefined reference to `__gmpn_mod_1'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpzspv.o): in function `mpzspv_to_mpzv':
/home/rjd/ecm-7.0.4/mpzspv.c:406: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspv.c:415: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspv.c:445: undefined reference to `__gmpz_addmul_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspv.c:461: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspv.c:464: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-mpzspv.o): in function `mpzspv_normalise':
/home/rjd/ecm-7.0.4/mpzspv.c:583: undefined reference to `__gmpn_add_n'
/usr/bin/ld: /home/rjd/ecm-7.0.4/mpzspv.c:588: undefined reference to `__gmpn_mod_1'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm_ntt.o): in function `__ecm_ntt_polyevalT':
/home/rjd/ecm-7.0.4/ecm_ntt.c:379: undefined reference to `__gmpz_mod'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-batch.o): in function `__ecm_compute_s':
/home/rjd/ecm-7.0.4/batch.c:73: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:74: undefined reference to `__gmpz_init'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-batch.o): in function `mpz_set_uint64':
/home/rjd/ecm-7.0.4/batch.c:112: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:137: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:138: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:143: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:144: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:114: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:126: undefined reference to `__gmpz_swap'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:129: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:128: undefined reference to `__gmpz_mul'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-batch.o): in function `__ecm_ecm_stage1_batch':
/home/rjd/ecm-7.0.4/batch.c:302: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:309: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:310: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:359: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:361: undefined reference to `__gmpz_tstbit'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:395: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:396: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:397: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:398: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:399: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-batch.o):/home/rjd/ecm-7.0.4/batch.c:400: more undefined references to `__gmpz_clear' follow
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:343: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/batch.c:372: undefined reference to `__gmpz_sizeinbase'
/home/rjd/ecm-7.0.4/batch.c:374: undefined reference to `__gmpz_tstbit'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-parametrizations.o): in function `addchain_param':
/home/rjd/ecm-7.0.4/parametrizations.c:116: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:122: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:128: undefined reference to `__gmpz_divisible_2exp_p'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:134: undefined reference to `__gmpz_congruent_ui_p'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:124: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:142: undefined reference to `__gmpz_add_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:130: undefined reference to `__gmpz_tdiv_q_2exp'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-parametrizations.o): in function `__ecm_get_curve_from_param0':
/home/rjd/ecm-7.0.4/parametrizations.c:173: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:175: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:177: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:178: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:209: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:210: undefined reference to `__gmpz_cmp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:228: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-parametrizations.o): in function `__ecm_get_curve_from_param1':
/home/rjd/ecm-7.0.4/parametrizations.c:241: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:245: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:253: undefined reference to `__gmpz_fdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:251: undefined reference to `__gmpz_tstbit'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:252: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:256: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:258: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:261: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:262: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:267: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-parametrizations.o): in function `__ecm_get_curve_from_param2':
/home/rjd/ecm-7.0.4/parametrizations.c:306: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:308: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:310: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:368: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:380: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-parametrizations.o): in function `__ecm_get_curve_from_param3':
/home/rjd/ecm-7.0.4/parametrizations.c:393: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:394: undefined reference to `__gmpz_ui_pow_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:395: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:400: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:410: undefined reference to `__gmpz_fdiv_q_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:408: undefined reference to `__gmpz_tstbit'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:409: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:413: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:415: undefined reference to `__gmpz_cmp_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:418: undefined reference to `__gmpz_mul_2exp'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:419: undefined reference to `__gmpz_sub_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:424: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:425: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-parametrizations.o): in function `__ecm_get_curve_from_random_parameter':
/home/rjd/ecm-7.0.4/parametrizations.c:456: undefined reference to `__gmpz_urandomb'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:441: undefined reference to `__gmpz_urandomb'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:446: undefined reference to `__gmpz_urandomb'
/usr/bin/ld: /home/rjd/ecm-7.0.4/parametrizations.c:451: undefined reference to `__gmpz_urandomb'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm2.o): in function `multiplyW2n':
/home/rjd/ecm-7.0.4/ecm2.c:57: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:58: undefined reference to `__gmpz_init2'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:61: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:62: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:86: undefined reference to `__gmpz_sizeinbase'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:72: undefined reference to `__gmpz_setbit'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:107: undefined reference to `__gmpz_tstbit'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:108: undefined reference to `__gmpz_tstbit'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:141: undefined reference to `__gmpz_tstbit'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:143: undefined reference to `__gmpz_tstbit'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:156: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:217: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:224: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:233: undefined reference to `__gmpz_tstbit'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:239: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:185: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:186: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:187: undefined reference to `__gmpz_setbit'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm2.o): in function `addWnm':
/home/rjd/ecm-7.0.4/ecm2.c:366: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:339: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:340: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm2.o): in function `__ecm_ecm_rootsF':
/home/rjd/ecm-7.0.4/ecm2.c:458: undefined reference to `__gmpz_init'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:461: undefined reference to `__gmpz_clear'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:475: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:515: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:516: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-ecm2.o): in function `__ecm_ecm_rootsG_init':
/home/rjd/ecm-7.0.4/ecm2.c:643: undefined reference to `log'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:645: undefined reference to `log'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:716: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:730: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:731: undefined reference to `__gmpz_set'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:726: undefined reference to `__gmpz_set_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:689: undefined reference to `__gmpz_set_si'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:642: undefined reference to `sqrt'
/usr/bin/ld: /home/rjd/ecm-7.0.4/ecm2.c:625: undefined reference to `__gmpz_set_si'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_init_list':
/home/rjd/ecm-7.0.4/listz.c:52: undefined reference to `__gmpz_init'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_init_list2':
/home/rjd/ecm-7.0.4/listz.c:68: undefined reference to `__gmpz_init2'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_clear_list':
/home/rjd/ecm-7.0.4/listz.c:81: undefined reference to `__gmpz_clear'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_list_inp_raw':
/home/rjd/ecm-7.0.4/listz.c:127: undefined reference to `__gmpz_inp_raw'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_list_out_raw':
/home/rjd/ecm-7.0.4/listz.c:141: undefined reference to `__gmpz_out_raw'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_list_set':
/home/rjd/ecm-7.0.4/listz.c:154: undefined reference to `__gmpz_set'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_list_revert':
/home/rjd/ecm-7.0.4/listz.c:164: undefined reference to `__gmpz_swap'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_list_swap':
/home/rjd/ecm-7.0.4/listz.c:173: undefined reference to `__gmpz_swap'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_list_neg':
/home/rjd/ecm-7.0.4/listz.c:185: undefined reference to `__gmpz_sub'
/usr/bin/ld: /home/rjd/ecm-7.0.4/listz.c:187: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_list_mod':
/home/rjd/ecm-7.0.4/listz.c:198: undefined reference to `__gmpz_mod'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_list_add':
/home/rjd/ecm-7.0.4/listz.c:208: undefined reference to `__gmpz_add'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_list_sub':
/home/rjd/ecm-7.0.4/listz.c:218: undefined reference to `__gmpz_sub'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_list_mulup':
/home/rjd/ecm-7.0.4/listz.c:231: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/listz.c:232: undefined reference to `__gmpz_mod'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_list_zero':
/home/rjd/ecm-7.0.4/listz.c:243: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_list_mul':
/home/rjd/ecm-7.0.4/listz.c:297: undefined reference to `__gmpz_addmul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/listz.c:298: undefined reference to `__gmpz_mul'
/usr/bin/ld: /home/rjd/ecm-7.0.4/listz.c:304: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /home/rjd/ecm-7.0.4/listz.c:311: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/listz.c:314: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/listz.c:315: undefined reference to `__gmpz_add'
/usr/bin/ld: /home/rjd/ecm-7.0.4/listz.c:198: undefined reference to `__gmpz_mod'
/usr/bin/ld: /home/rjd/ecm-7.0.4/listz.c:141: undefined reference to `__gmpz_out_raw'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_PolyFromRoots_Tree':
/home/rjd/ecm-7.0.4/listz.c:404: undefined reference to `__gmpz_mod'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_PrerevertDivision':
/home/rjd/ecm-7.0.4/listz.c:572: undefined reference to `__gmpz_set_ui'
/home/rjd/ecm-7.0.4/listz.c:561: undefined reference to `__gmpz_sizeinbase'
/home/rjd/ecm-7.0.4/listz.c:542: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_PolyFromRoots':
/home/rjd/ecm-7.0.4/listz.c:362: undefined reference to `__gmpz_mod'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-listz.o): in function `__ecm_PolyInvert':
/home/rjd/ecm-7.0.4/listz.c:456: undefined reference to `__gmpz_set_ui'
/usr/bin/ld: /usr/local/lib/libecm.a(libecm_la-spv.o): in function `spv_random':
/home/rjd/ecm-7.0.4/spv.c:446: undefined reference to `__gmpn_random'
collect2: error: ld returned 1 exit status
make[2]: *** [CMakeFiles/cmTC_3a227.dir/build.make:87: cmTC_3a227] Error 1
make[2]: Leaving directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
make[1]: *** [Makefile:121: cmTC_3a227/fast] Error 2
make[1]: Leaving directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
Source file was:
    #include <ecm.h>
    #include <stdlib.h>
    #include <stdio.h>
    int main(void)
      printf("ECM version: %s", ecm_version());
      return EXIT_SUCCESS;
Determining if the function pthread_create exists failed with the following output:
Change Dir: /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp
Run Build Command(s):make cmTC_47e14/fast
make[1]: Entering directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
make -f CMakeFiles/cmTC_47e14.dir/build.make CMakeFiles/cmTC_47e14.dir/build
make[2]: Entering directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
Building C object CMakeFiles/cmTC_47e14.dir/CheckFunctionExists.c.o
/usr/bin/cc   -std=c99 -g -W -Wall -O2  -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=pthread_create   -o CMakeFiles/cmTC_47e14.dir/CheckFunctionExists.c.o   -c /usr/share/cmake/Modules/CheckFunctionExists.c
Linking C executable cmTC_47e14
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_47e14.dir/link.txt --verbose=1
/usr/bin/cc -std=c99 -g -W -Wall -O2  -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=pthread_create    -rdynamic CMakeFiles/cmTC_47e14.dir/CheckFunctionExists.c.o  -o cmTC_47e14
/usr/bin/ld: CMakeFiles/cmTC_47e14.dir/CheckFunctionExists.c.o: in function `main':
/usr/share/cmake/Modules/CheckFunctionExists.c:17: undefined reference to `pthread_create'
make[2]: *** [CMakeFiles/cmTC_47e14.dir/build.make:87: cmTC_47e14] Error 1
make[1]: *** [Makefile:121: cmTC_47e14/fast] Error 2
  • [Cado-nfs-discuss] CmakeError.log, ROBERT DUCHATEAU, 06/10/2019
