- To: Emmanuel Thomé <Emmanuel.Thome@inria.fr>, cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Latest GCC 9.1.1 Mis-compiles Git Src Files
- Date: Mon, 10 Jun 2019 05:43:19 -0400 (EDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=rjd1212@cox.net; spf=Pass smtp.mailfrom=rjd1212@cox.net; spf=None smtp.helo=postmaster@omta011.uswest2.a.cloudfilter.net
- Importance: Medium
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
OK - much obliged ( commit 875f3d ) :-)
The reason for that truncated compiler output is I was afraid of sending the initial very large compile output, thus rendering it possibly too time consuming to sift over.
The next time I send files of that nature, it will be the entire non-truncated, version :-) I apologize for that oversight.
Best regards,
RJD
> On June 10, 2019 at 5:22 AM Emmanuel Thomé wrote:
> Hi,
> Should be fixed by commit 875f3d.
> > I just sent the CmakeError.log file which will give more info on the compile errors.
> Amusingly, you seem to miss the fact that the first and foremost
> diagnostic that you should look for as far as compilation is concerned is
> the compiler output...
> => CMakeError.log is completely off-topic. That this file contains error
> goes in the normal course of a compilation chain. Some tests pass, some
> don't, that's life!
> => When you pick only three lines of excerpt from the big "make" output,
> you're missing the important bit that is likely to be some hundreds of
> lines above.
> I attached one of the relevant error messages that I got while running
> "make".
> E.
> On Mon, Jun 10, 2019 at 04:48:58AM -0400, ROBERT DUCHATEAU wrote:
> > OK - thank you Emmanuel for that info. I just sent the CmakeError.log file which will give more info on the compile errors.
> > Regards,
> > RJD
> > > On June 10, 2019 at 4:25 AM Emmanuel Thomé wrote:
> > > Yes, there's a compilation issue with deprecated default operator=() --
> > > I'll look into it. Thanks for the notice. It'very probably a trivial fix.
> > > E.
> > > On Mon, Jun 10, 2019 at 03:26:34AM -0400, ROBERT DUCHATEAU wrote:
> > > > > As the title says, there is a present issue of compiling latest Cado Git source files. All files seem to be not compatible with gcc-9xx compiler. Currently using Fedora 30 distro with suspect compiler while Fedora 29 compiles all Git files without issues using gcc-8.3.1.
> > > > Wondering if there is a pending fix available?
> > > > Best regards,
> > > > RJD
> > > > > The system is: Linux - 5.1.6-300.fc30.x86_64 - x86_64
> > > > Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
> > > > Compiler: /usr/bin/cc
> > > > Build flags: -O2
> > > > Id flags:
> > > > The output was:
> > > > 0
> > > > Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "a.out"
> > > > The C compiler identification is GNU, found in "/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/3.14.4/CompilerIdC/a.out"
> > > > Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
> > > > Compiler: /usr/bin/c++
> > > > Build flags: -O2
> > > > Id flags:
> > > > The output was:
> > > > 0
> > > > Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "a.out"
> > > > The CXX compiler identification is GNU, found in "/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/3.14.4/CompilerIdCXX/a.out"
> > > > Determining if the C compiler works passed with the following output:
> > > > Change Dir: /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp
> > > > Run Build Command(s):/usr/bin/gmake cmTC_cc627/fast
> > > > gmake[1]: Entering directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
> > > > make -f CMakeFiles/cmTC_cc627.dir/build.make CMakeFiles/cmTC_cc627.dir/build
> > > > make[2]: Entering directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
> > > > Building C object CMakeFiles/cmTC_cc627.dir/testCCompiler.c.o
> > > > /usr/bin/cc -O2 -o CMakeFiles/cmTC_cc627.dir/testCCompiler.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/testCCompiler.c
> > > > Linking C executable cmTC_cc627
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_cc627.dir/link.txt --verbose=1
> > > > /usr/bin/cc -O2 -rdynamic CMakeFiles/cmTC_cc627.dir/testCCompiler.c.o -o cmTC_cc627
> > > > make[2]: Leaving directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
> > > > gmake[1]: Leaving directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
> > > > Detecting C compiler ABI info compiled with the following output:
> > > > Run Build Command(s):/usr/bin/gmake cmTC_2da53/fast
> > > > make -f CMakeFiles/cmTC_2da53.dir/build.make CMakeFiles/cmTC_2da53.dir/build
> > > > Building C object CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o
> > > > /usr/bin/cc -O2 -v -o CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o -c /usr/share/cmake/Modules/CMakeCCompilerABI.c
> > > > Using built-in specs.
> > > > COLLECT_GCC=/usr/bin/cc
> > > > OFFLOAD_TARGET_NAMES=nvptx-none
> > > > OFFLOAD_TARGET_DEFAULT=1
> > > > Target: x86_64-redhat-linux
> > > > Configured with: ../configure --enable-bootstrap --enable-languages=c,c++,fortran,objc,obj-c++,ada,go,d,lto --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-shared --enable-threads=posix --enable-checking=release --enable-multilib --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-gcc-major-version-only --with-linker-hash-style=gnu --enable-plugin --enable-initfini-array --with-isl --enable-offload-targets=nvptx-none --without-cuda-driver --enable-gnu-indirect-function --enable-cet --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux
> > > > Thread model: posix
> > > > gcc version 9.1.1 20190503 (Red Hat 9.1.1-1) (GCC)
> > > > COLLECT_GCC_OPTIONS='-O2' '-v' '-o' 'CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o' '-c' '-mtune=generic' '-march=x86-64'
> > > > /usr/libexec/gcc/x86_64-redhat-linux/9/cc1 -quiet -v /usr/share/cmake/Modules/CMakeCCompilerABI.c -quiet -dumpbase CMakeCCompilerABI.c -mtune=generic -march=x86-64 -auxbase-strip CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o -O2 -version -o /tmp/ccilphQl.s
> > > > GNU C17 (GCC) version 9.1.1 20190503 (Red Hat 9.1.1-1) (x86_64-redhat-linux)
> > > > compiled by GNU C version 9.1.1 20190503 (Red Hat 9.1.1-1), GMP version 6.1.2, MPFR version 3.1.6-p2, MPC version 1.1.0, isl version isl-0.16.1-GMP
> > > > GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
> > > > ignoring nonexistent directory "/usr/lib/gcc/x86_64-redhat-linux/9/include-fixed"
> > > > ignoring nonexistent directory "/usr/lib/gcc/x86_64-redhat-linux/9/../../../../x86_64-redhat-linux/include"
> > > > #include "..." search starts here:
> > > > #include <...> search starts here:
> > > > /usr/local/include
> > > > /usr/include
> > > > End of search list.
> > > > Compiler executable checksum: 4c18cb8ccf58c37e364f2f0344233b17
> > > > as -v --64 -o CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o /tmp/ccilphQl.s
> > > > GNU assembler version 2.31.1 (x86_64-redhat-linux) using BFD version version 2.31.1-29.fc30
> > > > COMPILER_PATH=/usr/libexec/gcc/x86_64-redhat-linux/9/:/usr/libexec/gcc/x86_64-redhat-linux/9/:/usr/libexec/gcc/x86_64-redhat-linux/:/usr/lib/gcc/x86_64-redhat-linux/9/:/usr/lib/gcc/x86_64-redhat-linux/
> > > > LIBRARY_PATH=/usr/lib/gcc/x86_64-redhat-linux/9/:/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/usr/lib/gcc/x86_64-redhat-linux/9/../../../:/lib/:/usr/lib/
> > > > Linking C executable cmTC_2da53
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_2da53.dir/link.txt --verbose=1
> > > > /usr/bin/cc -O2 -v -rdynamic CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o -o cmTC_2da53
> > > > COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper
> > > > Thread model: posix
> > > > COLLECT_GCC_OPTIONS='-O2' '-v' '-rdynamic' '-o' 'cmTC_2da53' '-mtune=generic' '-march=x86-64'
> > > > /usr/libexec/gcc/x86_64-redhat-linux/9/collect2 -plugin /usr/libexec/gcc/x86_64-redhat-linux/9/liblto_plugin.so -plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper -plugin-opt=-fresolution=/tmp/ccyMUcmv.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTC_2da53 /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/9/crtbegin.o -L/usr/lib/gcc/x86_64-redhat-linux/9 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../.. CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o -lgcc --push-state --as-needed -lgcc_s --pop-state -lc -lgcc --push-state --as-needed -lgcc_s --pop-state /usr/lib/gcc/x86_64-redhat-linux/9/crtend.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crtn.o
> > > > Parsed C implicit include dir info from above output: rv=done
> > > > found start of include info
> > > > found start of implicit include info
> > > > add: [/usr/lib/gcc/x86_64-redhat-linux/9/include]
> > > > add: [/usr/local/include]
> > > > add: [/usr/include]
> > > > end of search list found
> > > > collapse include dir [/usr/lib/gcc/x86_64-redhat-linux/9/include] ==> [/usr/lib/gcc/x86_64-redhat-linux/9/include]
> > > > collapse include dir [/usr/local/include] ==> [/usr/local/include]
> > > > collapse include dir [/usr/include] ==> [/usr/include]
> > > > implicit include dirs: [/usr/lib/gcc/x86_64-redhat-linux/9/include;/usr/local/include;/usr/include]
> > > > Parsed C implicit link information from above output:
> > > > link line regex: [^( *|.*[/\])(ld|CMAKE_LINK_STARTFILE-NOTFOUND|([^/\]+-)?ld|collect2)[^/\]*( |$)]
> > > > ignore line: [Change Dir: /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp]
> > > > ignore line: []
> > > > ignore line: [Run Build Command(s):/usr/bin/gmake cmTC_2da53/fast ]
> > > > ignore line: [gmake[1]: Entering directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp']
> > > > ignore line: [make -f CMakeFiles/cmTC_2da53.dir/build.make CMakeFiles/cmTC_2da53.dir/build]
> > > > ignore line: [make[2]: Entering directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp']
> > > > ignore line: [Building C object CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o]
> > > > ignore line: [/usr/bin/cc -O2 -v -o CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o -c /usr/share/cmake/Modules/CMakeCCompilerABI.c]
> > > > ignore line: [Using built-in specs.]
> > > > ignore line: [COLLECT_GCC=/usr/bin/cc]
> > > > ignore line: [OFFLOAD_TARGET_NAMES=nvptx-none]
> > > > ignore line: [OFFLOAD_TARGET_DEFAULT=1]
> > > > ignore line: [Target: x86_64-redhat-linux]
> > > > ignore line: [Configured with: ../configure --enable-bootstrap --enable-languages=c,c++,fortran,objc,obj-c++,ada,go,d,lto --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-shared --enable-threads=posix --enable-checking=release --enable-multilib --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-gcc-major-version-only --with-linker-hash-style=gnu --enable-plugin --enable-initfini-array --with-isl --enable-offload-targets=nvptx-none --without-cuda-driver --enable-gnu-indirect-function --enable-cet --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux]
> > > > ignore line: [Thread model: posix]
> > > > ignore line: [gcc version 9.1.1 20190503 (Red Hat 9.1.1-1) (GCC) ]
> > > > ignore line: [COLLECT_GCC_OPTIONS='-O2' '-v' '-o' 'CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o' '-c' '-mtune=generic' '-march=x86-64']
> > > > ignore line: [ /usr/libexec/gcc/x86_64-redhat-linux/9/cc1 -quiet -v /usr/share/cmake/Modules/CMakeCCompilerABI.c -quiet -dumpbase CMakeCCompilerABI.c -mtune=generic -march=x86-64 -auxbase-strip CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o -O2 -version -o /tmp/ccilphQl.s]
> > > > ignore line: [GNU C17 (GCC) version 9.1.1 20190503 (Red Hat 9.1.1-1) (x86_64-redhat-linux)]
> > > > ignore line: [ compiled by GNU C version 9.1.1 20190503 (Red Hat 9.1.1-1), GMP version 6.1.2, MPFR version 3.1.6-p2, MPC version 1.1.0, isl version isl-0.16.1-GMP]
> > > > ignore line: []
> > > > ignore line: [GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072]
> > > > ignore line: [ignoring nonexistent directory "/usr/lib/gcc/x86_64-redhat-linux/9/include-fixed"]
> > > > ignore line: [ignoring nonexistent directory "/usr/lib/gcc/x86_64-redhat-linux/9/../../../../x86_64-redhat-linux/include"]
> > > > ignore line: [#include "..." search starts here:]
> > > > ignore line: [#include <...> search starts here:]
> > > > ignore line: [ /usr/lib/gcc/x86_64-redhat-linux/9/include]
> > > > ignore line: [ /usr/local/include]
> > > > ignore line: [ /usr/include]
> > > > ignore line: [End of search list.]
> > > > ignore line: []
> > > > ignore line: [Compiler executable checksum: 4c18cb8ccf58c37e364f2f0344233b17]
> > > > ignore line: [ as -v --64 -o CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o /tmp/ccilphQl.s]
> > > > ignore line: [GNU assembler version 2.31.1 (x86_64-redhat-linux) using BFD version version 2.31.1-29.fc30]
> > > > ignore line: [COMPILER_PATH=/usr/libexec/gcc/x86_64-redhat-linux/9/:/usr/libexec/gcc/x86_64-redhat-linux/9/:/usr/libexec/gcc/x86_64-redhat-linux/:/usr/lib/gcc/x86_64-redhat-linux/9/:/usr/lib/gcc/x86_64-redhat-linux/]
> > > > ignore line: [LIBRARY_PATH=/usr/lib/gcc/x86_64-redhat-linux/9/:/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/usr/lib/gcc/x86_64-redhat-linux/9/../../../:/lib/:/usr/lib/]
> > > > ignore line: [Linking C executable cmTC_2da53]
> > > > ignore line: [/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_2da53.dir/link.txt --verbose=1]
> > > > ignore line: [/usr/bin/cc -O2 -v -rdynamic CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o -o cmTC_2da53 ]
> > > > ignore line: [COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper]
> > > > ignore line: [COLLECT_GCC_OPTIONS='-O2' '-v' '-rdynamic' '-o' 'cmTC_2da53' '-mtune=generic' '-march=x86-64']
> > > > link line: [ /usr/libexec/gcc/x86_64-redhat-linux/9/collect2 -plugin /usr/libexec/gcc/x86_64-redhat-linux/9/liblto_plugin.so -plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper -plugin-opt=-fresolution=/tmp/ccyMUcmv.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTC_2da53 /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/9/crtbegin.o -L/usr/lib/gcc/x86_64-redhat-linux/9 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../.. CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o -lgcc --push-state --as-needed -lgcc_s --pop-state -lc -lgcc --push-state --as-needed -lgcc_s --pop-state /usr/lib/gcc/x86_64-redhat-linux/9/crtend.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crtn.o]
> > > > arg [/usr/libexec/gcc/x86_64-redhat-linux/9/collect2] ==> ignore
> > > > arg [-plugin] ==> ignore
> > > > arg [/usr/libexec/gcc/x86_64-redhat-linux/9/liblto_plugin.so] ==> ignore
> > > > arg [-plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper] ==> ignore
> > > > arg [-plugin-opt=-fresolution=/tmp/ccyMUcmv.res] ==> ignore
> > > > arg [-plugin-opt=-pass-through=-lgcc] ==> ignore
> > > > arg [-plugin-opt=-pass-through=-lgcc_s] ==> ignore
> > > > arg [-plugin-opt=-pass-through=-lc] ==> ignore
> > > > arg [--build-id] ==> ignore
> > > > arg [--no-add-needed] ==> ignore
> > > > arg [--eh-frame-hdr] ==> ignore
> > > > arg [--hash-style=gnu] ==> ignore
> > > > arg [-m] ==> ignore
> > > > arg [elf_x86_64] ==> ignore
> > > > arg [-export-dynamic] ==> ignore
> > > > arg [-dynamic-linker] ==> ignore
> > > > arg [/lib64/ld-linux-x86-64.so.2] ==> ignore
> > > > arg [-o] ==> ignore
> > > > arg [cmTC_2da53] ==> ignore
> > > > arg [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crt1.o] ==> ignore
> > > > arg [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crti.o] ==> ignore
> > > > arg [/usr/lib/gcc/x86_64-redhat-linux/9/crtbegin.o] ==> ignore
> > > > arg [-L/usr/lib/gcc/x86_64-redhat-linux/9] ==> dir [/usr/lib/gcc/x86_64-redhat-linux/9]
> > > > arg [-L/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64] ==> dir [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64]
> > > > arg [-L/lib/../lib64] ==> dir [/lib/../lib64]
> > > > arg [-L/usr/lib/../lib64] ==> dir [/usr/lib/../lib64]
> > > > arg [-L/usr/lib/gcc/x86_64-redhat-linux/9/../../..] ==> dir [/usr/lib/gcc/x86_64-redhat-linux/9/../../..]
> > > > arg [CMakeFiles/cmTC_2da53.dir/CMakeCCompilerABI.c.o] ==> ignore
> > > > arg [-lgcc] ==> lib [gcc]
> > > > arg [--push-state] ==> ignore
> > > > arg [--as-needed] ==> ignore
> > > > arg [-lgcc_s] ==> lib [gcc_s]
> > > > arg [--pop-state] ==> ignore
> > > > arg [-lc] ==> lib [c]
> > > > arg [/usr/lib/gcc/x86_64-redhat-linux/9/crtend.o] ==> ignore
> > > > arg [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crtn.o] ==> ignore
> > > > collapse library dir [/usr/lib/gcc/x86_64-redhat-linux/9] ==> [/usr/lib/gcc/x86_64-redhat-linux/9]
> > > > collapse library dir [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64] ==> [/usr/lib64]
> > > > collapse library dir [/lib/../lib64] ==> [/lib64]
> > > > collapse library dir [/usr/lib/../lib64] ==> [/usr/lib64]
> > > > collapse library dir [/usr/lib/gcc/x86_64-redhat-linux/9/../../..] ==> [/usr/lib]
> > > > implicit libs: [gcc;gcc_s;c;gcc;gcc_s]
> > > > implicit dirs: [/usr/lib/gcc/x86_64-redhat-linux/9;/usr/lib64;/lib64;/usr/lib]
> > > > implicit fwks: []
> > > > Detecting C [-std=c11] compiler features compiled with the following output:
> > > > Run Build Command(s):/usr/bin/gmake cmTC_7c3a0/fast
> > > > make -f CMakeFiles/cmTC_7c3a0.dir/build.make CMakeFiles/cmTC_7c3a0.dir/build
> > > > Building C object CMakeFiles/cmTC_7c3a0.dir/feature_tests.c.o
> > > > /usr/bin/cc -O2 -std=c11 -o CMakeFiles/cmTC_7c3a0.dir/feature_tests.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/feature_tests.c
> > > > Linking C executable cmTC_7c3a0
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_7c3a0.dir/link.txt --verbose=1
> > > > /usr/bin/cc -O2 -rdynamic CMakeFiles/cmTC_7c3a0.dir/feature_tests.c.o -o cmTC_7c3a0
> > > > Feature record: C_FEATURE:1c_function_prototypes
> > > > Feature record: C_FEATURE:1c_restrict
> > > > Feature record: C_FEATURE:1c_static_assert
> > > > Feature record: C_FEATURE:1c_variadic_macros
> > > > Detecting C [-std=c99] compiler features compiled with the following output:
> > > > Run Build Command(s):/usr/bin/gmake cmTC_2a9b2/fast
> > > > make -f CMakeFiles/cmTC_2a9b2.dir/build.make CMakeFiles/cmTC_2a9b2.dir/build
> > > > Building C object CMakeFiles/cmTC_2a9b2.dir/feature_tests.c.o
> > > > /usr/bin/cc -O2 -std=c99 -o CMakeFiles/cmTC_2a9b2.dir/feature_tests.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/feature_tests.c
> > > > Linking C executable cmTC_2a9b2
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_2a9b2.dir/link.txt --verbose=1
> > > > /usr/bin/cc -O2 -rdynamic CMakeFiles/cmTC_2a9b2.dir/feature_tests.c.o -o cmTC_2a9b2
> > > > Feature record: C_FEATURE:0c_static_assert
> > > > Detecting C [-std=c90] compiler features compiled with the following output:
> > > > Run Build Command(s):/usr/bin/gmake cmTC_6cf42/fast
> > > > make -f CMakeFiles/cmTC_6cf42.dir/build.make CMakeFiles/cmTC_6cf42.dir/build
> > > > Building C object CMakeFiles/cmTC_6cf42.dir/feature_tests.c.o
> > > > /usr/bin/cc -O2 -std=c90 -o CMakeFiles/cmTC_6cf42.dir/feature_tests.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/feature_tests.c
> > > > Linking C executable cmTC_6cf42
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_6cf42.dir/link.txt --verbose=1
> > > > /usr/bin/cc -O2 -rdynamic CMakeFiles/cmTC_6cf42.dir/feature_tests.c.o -o cmTC_6cf42
> > > > Feature record: C_FEATURE:0c_restrict
> > > > Feature record: C_FEATURE:0c_variadic_macros
> > > > Determining if the CXX compiler works passed with the following output:
> > > > Run Build Command(s):/usr/bin/gmake cmTC_4190a/fast
> > > > make -f CMakeFiles/cmTC_4190a.dir/build.make CMakeFiles/cmTC_4190a.dir/build
> > > > Building CXX object CMakeFiles/cmTC_4190a.dir/testCXXCompiler.cxx.o
> > > > /usr/bin/c++ -O2 -o CMakeFiles/cmTC_4190a.dir/testCXXCompiler.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/testCXXCompiler.cxx
> > > > Linking CXX executable cmTC_4190a
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_4190a.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -O2 -rdynamic CMakeFiles/cmTC_4190a.dir/testCXXCompiler.cxx.o -o cmTC_4190a
> > > > Detecting CXX compiler ABI info compiled with the following output:
> > > > Run Build Command(s):/usr/bin/gmake cmTC_f39a6/fast
> > > > make -f CMakeFiles/cmTC_f39a6.dir/build.make CMakeFiles/cmTC_f39a6.dir/build
> > > > Building CXX object CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o
> > > > /usr/bin/c++ -O2 -v -o CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o -c /usr/share/cmake/Modules/CMakeCXXCompilerABI.cpp
> > > > COLLECT_GCC=/usr/bin/c++
> > > > Thread model: posix
> > > > COLLECT_GCC_OPTIONS='-O2' '-v' '-o' 'CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o' '-c' '-shared-libgcc' '-mtune=generic' '-march=x86-64'
> > > > /usr/libexec/gcc/x86_64-redhat-linux/9/cc1plus -quiet -v -D_GNU_SOURCE /usr/share/cmake/Modules/CMakeCXXCompilerABI.cpp -quiet -dumpbase CMakeCXXCompilerABI.cpp -mtune=generic -march=x86-64 -auxbase-strip CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o -O2 -version -o /tmp/ccxtKEJn.s
> > > > GNU C++14 (GCC) version 9.1.1 20190503 (Red Hat 9.1.1-1) (x86_64-redhat-linux)
> > > > /usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9
> > > > /usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9/x86_64-redhat-linux
> > > > /usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9/backward
> > > > /usr/local/include
> > > > /usr/include
> > > > End of search list.
> > > > Compiler executable checksum: a3b782be16d22698470553fc15b77082
> > > > as -v --64 -o CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o /tmp/ccxtKEJn.s
> > > > Linking CXX executable cmTC_f39a6
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_f39a6.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -O2 -v -rdynamic CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o -o cmTC_f39a6
> > > > Thread model: posix
> > > > COLLECT_GCC_OPTIONS='-O2' '-v' '-rdynamic' '-o' 'cmTC_f39a6' '-shared-libgcc' '-mtune=generic' '-march=x86-64'
> > > > /usr/libexec/gcc/x86_64-redhat-linux/9/collect2 -plugin /usr/libexec/gcc/x86_64-redhat-linux/9/liblto_plugin.so -plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper -plugin-opt=-fresolution=/tmp/ccJMVbxv.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTC_f39a6 /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/9/crtbegin.o -L/usr/lib/gcc/x86_64-redhat-linux/9 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../.. CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-redhat-linux/9/crtend.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crtn.o
> > > > Parsed CXX implicit include dir info from above output: rv=done
> > > > add: [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9]
> > > > add: [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9/x86_64-redhat-linux]
> > > > add: [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9/backward]
> > > > add: [/usr/include]
> > > > collapse include dir [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9] ==> [/usr/include/c++/9]
> > > > collapse include dir [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9/x86_64-redhat-linux] ==> [/usr/include/c++/9/x86_64-redhat-linux]
> > > > collapse include dir [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9/backward] ==> [/usr/include/c++/9/backward]
> > > > implicit include dirs: [/usr/include/c++/9;/usr/include/c++/9/x86_64-redhat-linux;/usr/include/c++/9/backward;/usr/lib/gcc/x86_64-redhat-linux/9/include;/usr/local/include;/usr/include]
> > > > Parsed CXX implicit link information from above output:
> > > > ignore line: []
> > > > ignore line: [Run Build Command(s):/usr/bin/gmake cmTC_f39a6/fast ]
> > > > ignore line: [make -f CMakeFiles/cmTC_f39a6.dir/build.make CMakeFiles/cmTC_f39a6.dir/build]
> > > > ignore line: [Building CXX object CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o]
> > > > ignore line: [/usr/bin/c++ -O2 -v -o CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o -c /usr/share/cmake/Modules/CMakeCXXCompilerABI.cpp]
> > > > ignore line: [COLLECT_GCC=/usr/bin/c++]
> > > > ignore line: [COLLECT_GCC_OPTIONS='-O2' '-v' '-o' 'CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o' '-c' '-shared-libgcc' '-mtune=generic' '-march=x86-64']
> > > > ignore line: [ /usr/libexec/gcc/x86_64-redhat-linux/9/cc1plus -quiet -v -D_GNU_SOURCE /usr/share/cmake/Modules/CMakeCXXCompilerABI.cpp -quiet -dumpbase CMakeCXXCompilerABI.cpp -mtune=generic -march=x86-64 -auxbase-strip CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o -O2 -version -o /tmp/ccxtKEJn.s]
> > > > ignore line: [GNU C++14 (GCC) version 9.1.1 20190503 (Red Hat 9.1.1-1) (x86_64-redhat-linux)]
> > > > ignore line: []
> > > > ignore line: [ /usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9]
> > > > ignore line: [ /usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9/x86_64-redhat-linux]
> > > > ignore line: [ /usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9/backward]
> > > > ignore line: []
> > > > ignore line: [Compiler executable checksum: a3b782be16d22698470553fc15b77082]
> > > > ignore line: [ as -v --64 -o CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o /tmp/ccxtKEJn.s]
> > > > ignore line: [Linking CXX executable cmTC_f39a6]
> > > > ignore line: [/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_f39a6.dir/link.txt --verbose=1]
> > > > ignore line: [/usr/bin/c++ -O2 -v -rdynamic CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o -o cmTC_f39a6 ]
> > > > ignore line: [COLLECT_GCC_OPTIONS='-O2' '-v' '-rdynamic' '-o' 'cmTC_f39a6' '-shared-libgcc' '-mtune=generic' '-march=x86-64']
> > > > link line: [ /usr/libexec/gcc/x86_64-redhat-linux/9/collect2 -plugin /usr/libexec/gcc/x86_64-redhat-linux/9/liblto_plugin.so -plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper -plugin-opt=-fresolution=/tmp/ccJMVbxv.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTC_f39a6 /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/9/crtbegin.o -L/usr/lib/gcc/x86_64-redhat-linux/9 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../.. CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-redhat-linux/9/crtend.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crtn.o]
> > > > arg [-plugin-opt=-fresolution=/tmp/ccJMVbxv.res] ==> ignore
> > > > arg [-m] ==> ignore
> > > > arg [-o] ==> ignore
> > > > arg [cmTC_f39a6] ==> ignore
> > > > arg [CMakeFiles/cmTC_f39a6.dir/CMakeCXXCompilerABI.cpp.o] ==> ignore
> > > > arg [-lstdc++] ==> lib [stdc++]
> > > > arg [-lm] ==> lib [m]
> > > > implicit libs: [stdc++;m;gcc_s;gcc;c;gcc_s;gcc]
> > > > implicit fwks: []
> > > > Detecting CXX [-std=c++2a] compiler features compiled with the following output:
> > > > Run Build Command(s):/usr/bin/gmake cmTC_efd4a/fast
> > > > make -f CMakeFiles/cmTC_efd4a.dir/build.make CMakeFiles/cmTC_efd4a.dir/build
> > > > Building CXX object CMakeFiles/cmTC_efd4a.dir/feature_tests.cxx.o
> > > > /usr/bin/c++ -O2 -std=c++2a -o CMakeFiles/cmTC_efd4a.dir/feature_tests.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/feature_tests.cxx
> > > > Linking CXX executable cmTC_efd4a
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_efd4a.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -O2 -rdynamic CMakeFiles/cmTC_efd4a.dir/feature_tests.cxx.o -o cmTC_efd4a
> > > > Feature record: CXX_FEATURE:1cxx_aggregate_default_initializers
> > > > Feature record: CXX_FEATURE:1cxx_alias_templates
> > > > Feature record: CXX_FEATURE:1cxx_alignas
> > > > Feature record: CXX_FEATURE:1cxx_alignof
> > > > Feature record: CXX_FEATURE:1cxx_attributes
> > > > Feature record: CXX_FEATURE:1cxx_attribute_deprecated
> > > > Feature record: CXX_FEATURE:1cxx_auto_type
> > > > Feature record: CXX_FEATURE:1cxx_binary_literals
> > > > Feature record: CXX_FEATURE:1cxx_constexpr
> > > > Feature record: CXX_FEATURE:1cxx_contextual_conversions
> > > > Feature record: CXX_FEATURE:1cxx_decltype
> > > > Feature record: CXX_FEATURE:1cxx_decltype_auto
> > > > Feature record: CXX_FEATURE:1cxx_decltype_incomplete_return_types
> > > > Feature record: CXX_FEATURE:1cxx_default_function_template_args
> > > > Feature record: CXX_FEATURE:1cxx_defaulted_functions
> > > > Feature record: CXX_FEATURE:1cxx_defaulted_move_initializers
> > > > Feature record: CXX_FEATURE:1cxx_delegating_constructors
> > > > Feature record: CXX_FEATURE:1cxx_deleted_functions
> > > > Feature record: CXX_FEATURE:1cxx_digit_separators
> > > > Feature record: CXX_FEATURE:1cxx_enum_forward_declarations
> > > > Feature record: CXX_FEATURE:1cxx_explicit_conversions
> > > > Feature record: CXX_FEATURE:1cxx_extended_friend_declarations
> > > > Feature record: CXX_FEATURE:1cxx_extern_templates
> > > > Feature record: CXX_FEATURE:1cxx_final
> > > > Feature record: CXX_FEATURE:1cxx_func_identifier
> > > > Feature record: CXX_FEATURE:1cxx_generalized_initializers
> > > > Feature record: CXX_FEATURE:1cxx_generic_lambdas
> > > > Feature record: CXX_FEATURE:1cxx_inheriting_constructors
> > > > Feature record: CXX_FEATURE:1cxx_inline_namespaces
> > > > Feature record: CXX_FEATURE:1cxx_lambdas
> > > > Feature record: CXX_FEATURE:1cxx_lambda_init_captures
> > > > Feature record: CXX_FEATURE:1cxx_local_type_template_args
> > > > Feature record: CXX_FEATURE:1cxx_long_long_type
> > > > Feature record: CXX_FEATURE:1cxx_noexcept
> > > > Feature record: CXX_FEATURE:1cxx_nonstatic_member_init
> > > > Feature record: CXX_FEATURE:1cxx_nullptr
> > > > Feature record: CXX_FEATURE:1cxx_override
> > > > Feature record: CXX_FEATURE:1cxx_range_for
> > > > Feature record: CXX_FEATURE:1cxx_raw_string_literals
> > > > Feature record: CXX_FEATURE:1cxx_reference_qualified_functions
> > > > Feature record: CXX_FEATURE:1cxx_relaxed_constexpr
> > > > Feature record: CXX_FEATURE:1cxx_return_type_deduction
> > > > Feature record: CXX_FEATURE:1cxx_right_angle_brackets
> > > > Feature record: CXX_FEATURE:1cxx_rvalue_references
> > > > Feature record: CXX_FEATURE:1cxx_sizeof_member
> > > > Feature record: CXX_FEATURE:1cxx_static_assert
> > > > Feature record: CXX_FEATURE:1cxx_strong_enums
> > > > Feature record: CXX_FEATURE:1cxx_template_template_parameters
> > > > Feature record: CXX_FEATURE:1cxx_thread_local
> > > > Feature record: CXX_FEATURE:1cxx_trailing_return_types
> > > > Feature record: CXX_FEATURE:1cxx_unicode_literals
> > > > Feature record: CXX_FEATURE:1cxx_uniform_initialization
> > > > Feature record: CXX_FEATURE:1cxx_unrestricted_unions
> > > > Feature record: CXX_FEATURE:1cxx_user_literals
> > > > Feature record: CXX_FEATURE:1cxx_variable_templates
> > > > Feature record: CXX_FEATURE:1cxx_variadic_macros
> > > > Feature record: CXX_FEATURE:1cxx_variadic_templates
> > > > Detecting CXX [-std=c++17] compiler features compiled with the following output:
> > > > Run Build Command(s):/usr/bin/gmake cmTC_4d5e7/fast
> > > > make -f CMakeFiles/cmTC_4d5e7.dir/build.make CMakeFiles/cmTC_4d5e7.dir/build
> > > > Building CXX object CMakeFiles/cmTC_4d5e7.dir/feature_tests.cxx.o
> > > > /usr/bin/c++ -O2 -std=c++17 -o CMakeFiles/cmTC_4d5e7.dir/feature_tests.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/feature_tests.cxx
> > > > Linking CXX executable cmTC_4d5e7
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_4d5e7.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -O2 -rdynamic CMakeFiles/cmTC_4d5e7.dir/feature_tests.cxx.o -o cmTC_4d5e7
> > > > Detecting CXX [-std=c++14] compiler features compiled with the following output:
> > > > Run Build Command(s):/usr/bin/gmake cmTC_70b17/fast
> > > > make -f CMakeFiles/cmTC_70b17.dir/build.make CMakeFiles/cmTC_70b17.dir/build
> > > > Building CXX object CMakeFiles/cmTC_70b17.dir/feature_tests.cxx.o
> > > > /usr/bin/c++ -O2 -std=c++14 -o CMakeFiles/cmTC_70b17.dir/feature_tests.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/feature_tests.cxx
> > > > Linking CXX executable cmTC_70b17
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_70b17.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -O2 -rdynamic CMakeFiles/cmTC_70b17.dir/feature_tests.cxx.o -o cmTC_70b17
> > > > Detecting CXX [-std=c++11] compiler features compiled with the following output:
> > > > Run Build Command(s):/usr/bin/gmake cmTC_f7d64/fast
> > > > make -f CMakeFiles/cmTC_f7d64.dir/build.make CMakeFiles/cmTC_f7d64.dir/build
> > > > Building CXX object CMakeFiles/cmTC_f7d64.dir/feature_tests.cxx.o
> > > > /usr/bin/c++ -O2 -std=c++11 -o CMakeFiles/cmTC_f7d64.dir/feature_tests.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/feature_tests.cxx
> > > > Linking CXX executable cmTC_f7d64
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_f7d64.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -O2 -rdynamic CMakeFiles/cmTC_f7d64.dir/feature_tests.cxx.o -o cmTC_f7d64
> > > > Feature record: CXX_FEATURE:0cxx_aggregate_default_initializers
> > > > Feature record: CXX_FEATURE:0cxx_attribute_deprecated
> > > > Feature record: CXX_FEATURE:0cxx_binary_literals
> > > > Feature record: CXX_FEATURE:0cxx_contextual_conversions
> > > > Feature record: CXX_FEATURE:0cxx_decltype_auto
> > > > Feature record: CXX_FEATURE:0cxx_digit_separators
> > > > Feature record: CXX_FEATURE:0cxx_generic_lambdas
> > > > Feature record: CXX_FEATURE:0cxx_lambda_init_captures
> > > > Feature record: CXX_FEATURE:0cxx_relaxed_constexpr
> > > > Feature record: CXX_FEATURE:0cxx_return_type_deduction
> > > > Feature record: CXX_FEATURE:0cxx_variable_templates
> > > > Detecting CXX [-std=c++98] compiler features compiled with the following output:
> > > > Run Build Command(s):/usr/bin/gmake cmTC_7b587/fast
> > > > make -f CMakeFiles/cmTC_7b587.dir/build.make CMakeFiles/cmTC_7b587.dir/build
> > > > Building CXX object CMakeFiles/cmTC_7b587.dir/feature_tests.cxx.o
> > > > /usr/bin/c++ -O2 -std=c++98 -o CMakeFiles/cmTC_7b587.dir/feature_tests.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/feature_tests.cxx
> > > > Linking CXX executable cmTC_7b587
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_7b587.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -O2 -rdynamic CMakeFiles/cmTC_7b587.dir/feature_tests.cxx.o -o cmTC_7b587
> > > > Feature record: CXX_FEATURE:0cxx_alias_templates
> > > > Feature record: CXX_FEATURE:0cxx_alignas
> > > > Feature record: CXX_FEATURE:0cxx_alignof
> > > > Feature record: CXX_FEATURE:0cxx_attributes
> > > > Feature record: CXX_FEATURE:0cxx_auto_type
> > > > Feature record: CXX_FEATURE:0cxx_constexpr
> > > > Feature record: CXX_FEATURE:0cxx_decltype_incomplete_return_types
> > > > Feature record: CXX_FEATURE:0cxx_default_function_template_args
> > > > Feature record: CXX_FEATURE:0cxx_defaulted_functions
> > > > Feature record: CXX_FEATURE:0cxx_defaulted_move_initializers
> > > > Feature record: CXX_FEATURE:0cxx_delegating_constructors
> > > > Feature record: CXX_FEATURE:0cxx_deleted_functions
> > > > Feature record: CXX_FEATURE:0cxx_enum_forward_declarations
> > > > Feature record: CXX_FEATURE:0cxx_explicit_conversions
> > > > Feature record: CXX_FEATURE:0cxx_extended_friend_declarations
> > > > Feature record: CXX_FEATURE:0cxx_extern_templates
> > > > Feature record: CXX_FEATURE:0cxx_final
> > > > Feature record: CXX_FEATURE:0cxx_func_identifier
> > > > Feature record: CXX_FEATURE:0cxx_generalized_initializers
> > > > Feature record: CXX_FEATURE:0cxx_inheriting_constructors
> > > > Feature record: CXX_FEATURE:0cxx_inline_namespaces
> > > > Feature record: CXX_FEATURE:0cxx_lambdas
> > > > Feature record: CXX_FEATURE:0cxx_local_type_template_args
> > > > Feature record: CXX_FEATURE:0cxx_long_long_type
> > > > Feature record: CXX_FEATURE:0cxx_noexcept
> > > > Feature record: CXX_FEATURE:0cxx_nonstatic_member_init
> > > > Feature record: CXX_FEATURE:0cxx_nullptr
> > > > Feature record: CXX_FEATURE:0cxx_override
> > > > Feature record: CXX_FEATURE:0cxx_range_for
> > > > Feature record: CXX_FEATURE:0cxx_raw_string_literals
> > > > Feature record: CXX_FEATURE:0cxx_reference_qualified_functions
> > > > Feature record: CXX_FEATURE:0cxx_right_angle_brackets
> > > > Feature record: CXX_FEATURE:0cxx_rvalue_references
> > > > Feature record: CXX_FEATURE:0cxx_sizeof_member
> > > > Feature record: CXX_FEATURE:0cxx_static_assert
> > > > Feature record: CXX_FEATURE:0cxx_strong_enums
> > > > Feature record: CXX_FEATURE:0cxx_thread_local
> > > > Feature record: CXX_FEATURE:0cxx_trailing_return_types
> > > > Feature record: CXX_FEATURE:0cxx_unicode_literals
> > > > Feature record: CXX_FEATURE:0cxx_uniform_initialization
> > > > Feature record: CXX_FEATURE:0cxx_unrestricted_unions
> > > > Feature record: CXX_FEATURE:0cxx_user_literals
> > > > Feature record: CXX_FEATURE:0cxx_variadic_macros
> > > > Feature record: CXX_FEATURE:0cxx_variadic_templates
> > > > Determining if the include file sys/types.h exists passed with the following output:
> > > > Run Build Command(s):make cmTC_3f6df/fast
> > > > make -f CMakeFiles/cmTC_3f6df.dir/build.make CMakeFiles/cmTC_3f6df.dir/build
> > > > Building C object CMakeFiles/cmTC_3f6df.dir/CheckIncludeFile.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -o CMakeFiles/cmTC_3f6df.dir/CheckIncludeFile.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/CheckIncludeFile.c
> > > > Linking C executable cmTC_3f6df
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_3f6df.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -rdynamic CMakeFiles/cmTC_3f6df.dir/CheckIncludeFile.c.o -o cmTC_3f6df
> > > > Determining if the include file stdint.h exists passed with the following output:
> > > > Run Build Command(s):make cmTC_851e1/fast
> > > > make -f CMakeFiles/cmTC_851e1.dir/build.make CMakeFiles/cmTC_851e1.dir/build
> > > > Building C object CMakeFiles/cmTC_851e1.dir/CheckIncludeFile.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -o CMakeFiles/cmTC_851e1.dir/CheckIncludeFile.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/CheckIncludeFile.c
> > > > Linking C executable cmTC_851e1
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_851e1.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -rdynamic CMakeFiles/cmTC_851e1.dir/CheckIncludeFile.c.o -o cmTC_851e1
> > > > Determining if the include file stddef.h exists passed with the following output:
> > > > Run Build Command(s):make cmTC_d5fd3/fast
> > > > make -f CMakeFiles/cmTC_d5fd3.dir/build.make CMakeFiles/cmTC_d5fd3.dir/build
> > > > Building C object CMakeFiles/cmTC_d5fd3.dir/CheckIncludeFile.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -o CMakeFiles/cmTC_d5fd3.dir/CheckIncludeFile.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/CheckIncludeFile.c
> > > > Linking C executable cmTC_d5fd3
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_d5fd3.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -rdynamic CMakeFiles/cmTC_d5fd3.dir/CheckIncludeFile.c.o -o cmTC_d5fd3
> > > > Determining size of unsigned long int passed with the following output:
> > > > Run Build Command(s):make cmTC_f85b7/fast
> > > > make -f CMakeFiles/cmTC_f85b7.dir/build.make CMakeFiles/cmTC_f85b7.dir/build
> > > > Building C object CMakeFiles/cmTC_f85b7.dir/ulong_size.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -o CMakeFiles/cmTC_f85b7.dir/ulong_size.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CheckTypeSize/ulong_size.c
> > > > Linking C executable cmTC_f85b7
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_f85b7.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -rdynamic CMakeFiles/cmTC_f85b7.dir/ulong_size.c.o -o cmTC_f85b7
> > > > Determining size of unsigned long long int passed with the following output:
> > > > Run Build Command(s):make cmTC_0e603/fast
> > > > make -f CMakeFiles/cmTC_0e603.dir/build.make CMakeFiles/cmTC_0e603.dir/build
> > > > Building C object CMakeFiles/cmTC_0e603.dir/ulonglong_size.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -o CMakeFiles/cmTC_0e603.dir/ulonglong_size.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CheckTypeSize/ulonglong_size.c
> > > > Linking C executable cmTC_0e603
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_0e603.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -rdynamic CMakeFiles/cmTC_0e603.dir/ulonglong_size.c.o -o cmTC_0e603
> > > > Performing C++ SOURCE FILE Test UINT64_T_IS_UNSIGNED_LONG succeeded with the following output:
> > > > Run Build Command(s):make cmTC_5d0ed/fast
> > > > make -f CMakeFiles/cmTC_5d0ed.dir/build.make CMakeFiles/cmTC_5d0ed.dir/build
> > > > Building CXX object CMakeFiles/cmTC_5d0ed.dir/src.cxx.o
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -DUINT64_T_IS_UNSIGNED_LONG -o CMakeFiles/cmTC_5d0ed.dir/src.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/src.cxx
> > > > Linking CXX executable cmTC_5d0ed
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_5d0ed.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -DUINT64_T_IS_UNSIGNED_LONG -rdynamic CMakeFiles/cmTC_5d0ed.dir/src.cxx.o -o cmTC_5d0ed
> > > > Source file was:
> > > > #include
> > > > #include
> > > > #include
> > > > int main()
> > > > static_assert(std::is_same::value, "not this type");
> > > > return 0;
> > > > Determining if the function log2 exists passed with the following output:
> > > > Run Build Command(s):make cmTC_a41f1/fast
> > > > make -f CMakeFiles/cmTC_a41f1.dir/build.make CMakeFiles/cmTC_a41f1.dir/build
> > > > Building C object CMakeFiles/cmTC_a41f1.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=log2 -o CMakeFiles/cmTC_a41f1.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > : warning: conflicting types for built-in function ‘log2’; expected ‘double(double)’ [-Wbuiltin-declaration-mismatch]
> > > > /usr/share/cmake/Modules/CheckFunctionExists.c:7:3: note: in expansion of macro ‘CHECK_FUNCTION_EXISTS’
> > > > 7 | CHECK_FUNCTION_EXISTS(void);
> > > > /usr/share/cmake/Modules/CheckFunctionExists.c:1:1: note: ‘log2’ is declared in header ‘’
> > > > +++ |+#include
> > > > 1 | #ifdef CHECK_FUNCTION_EXISTS
> > > > Linking C executable cmTC_a41f1
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_a41f1.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=log2 -rdynamic CMakeFiles/cmTC_a41f1.dir/CheckFunctionExists.c.o -o cmTC_a41f1 -lm
> > > > Determining if the function exp2 exists passed with the following output:
> > > > Run Build Command(s):make cmTC_85140/fast
> > > > make -f CMakeFiles/cmTC_85140.dir/build.make CMakeFiles/cmTC_85140.dir/build
> > > > Building C object CMakeFiles/cmTC_85140.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=exp2 -o CMakeFiles/cmTC_85140.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > : warning: conflicting types for built-in function ‘exp2’; expected ‘double(double)’ [-Wbuiltin-declaration-mismatch]
> > > > /usr/share/cmake/Modules/CheckFunctionExists.c:1:1: note: ‘exp2’ is declared in header ‘’
> > > > +++ |+#include
> > > > Linking C executable cmTC_85140
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_85140.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=exp2 -rdynamic CMakeFiles/cmTC_85140.dir/CheckFunctionExists.c.o -o cmTC_85140 -lm
> > > > Determining if the function cabsl exists passed with the following output:
> > > > Run Build Command(s):make cmTC_93771/fast
> > > > make -f CMakeFiles/cmTC_93771.dir/build.make CMakeFiles/cmTC_93771.dir/build
> > > > Building C object CMakeFiles/cmTC_93771.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=cabsl -o CMakeFiles/cmTC_93771.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > : warning: conflicting types for built-in function ‘cabsl’; expected ‘long double(_Complex long double)’ [-Wbuiltin-declaration-mismatch]
> > > > /usr/share/cmake/Modules/CheckFunctionExists.c:1:1: note: ‘cabsl’ is declared in header ‘’
> > > > +++ |+#include
> > > > Linking C executable cmTC_93771
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_93771.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=cabsl -rdynamic CMakeFiles/cmTC_93771.dir/CheckFunctionExists.c.o -o cmTC_93771 -lm
> > > > Determining if the function clog exists passed with the following output:
> > > > Run Build Command(s):make cmTC_ae670/fast
> > > > make -f CMakeFiles/cmTC_ae670.dir/build.make CMakeFiles/cmTC_ae670.dir/build
> > > > Building C object CMakeFiles/cmTC_ae670.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=clog -o CMakeFiles/cmTC_ae670.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > : warning: conflicting types for built-in function ‘clog’; expected ‘_Complex double(_Complex double)’ [-Wbuiltin-declaration-mismatch]
> > > > /usr/share/cmake/Modules/CheckFunctionExists.c:1:1: note: ‘clog’ is declared in header ‘’
> > > > +++ |+#include
> > > > Linking C executable cmTC_ae670
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_ae670.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=clog -rdynamic CMakeFiles/cmTC_ae670.dir/CheckFunctionExists.c.o -o cmTC_ae670 -lm
> > > > Performing C++ SOURCE FILE Test HAVE_STDCPP_MATH_SPEC_FUNCS succeeded with the following output:
> > > > Run Build Command(s):make cmTC_56b5c/fast
> > > > make -f CMakeFiles/cmTC_56b5c.dir/build.make CMakeFiles/cmTC_56b5c.dir/build
> > > > Building CXX object CMakeFiles/cmTC_56b5c.dir/src.cxx.o
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAVE_STDCPP_MATH_SPEC_FUNCS -o CMakeFiles/cmTC_56b5c.dir/src.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/src.cxx
> > > > Linking CXX executable cmTC_56b5c
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_56b5c.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAVE_STDCPP_MATH_SPEC_FUNCS -rdynamic CMakeFiles/cmTC_56b5c.dir/src.cxx.o -o cmTC_56b5c
> > > > Source file was:
> > > > #define __STDCPP_MATH_SPEC_FUNCS__ 201003L
> > > > #define __STDCPP_WANT_MATH_SPEC_FUNCS__ 1 /* for expint() */
> > > > #include
> > > > double foo(size_t p0, size_t p1) {
> > > > return std::expint(log(p1)) - std::expint(log(p0));
> > > > int main() {
> > > > return foo(17, 42) >= 3 ? 0 : 1;
> > > > Determining if files sys/resource.h exist passed with the following output:
> > > > Run Build Command(s):make cmTC_54067/fast
> > > > make -f CMakeFiles/cmTC_54067.dir/build.make CMakeFiles/cmTC_54067.dir/build
> > > > Building C object CMakeFiles/cmTC_54067.dir/HAVE_RESOURCE_H.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -o CMakeFiles/cmTC_54067.dir/HAVE_RESOURCE_H.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CheckIncludeFiles/HAVE_RESOURCE_H.c
> > > > Linking C executable cmTC_54067
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_54067.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -rdynamic CMakeFiles/cmTC_54067.dir/HAVE_RESOURCE_H.c.o -o cmTC_54067
> > > > Determining if files sys/utsname.h exist passed with the following output:
> > > > Run Build Command(s):make cmTC_8219d/fast
> > > > make -f CMakeFiles/cmTC_8219d.dir/build.make CMakeFiles/cmTC_8219d.dir/build
> > > > Building C object CMakeFiles/cmTC_8219d.dir/HAVE_UTSNAME_H.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -o CMakeFiles/cmTC_8219d.dir/HAVE_UTSNAME_H.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CheckIncludeFiles/HAVE_UTSNAME_H.c
> > > > Linking C executable cmTC_8219d
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_8219d.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -rdynamic CMakeFiles/cmTC_8219d.dir/HAVE_UTSNAME_H.c.o -o cmTC_8219d
> > > > Determining if files sys/statvfs.h exist passed with the following output:
> > > > Run Build Command(s):make cmTC_2d0e9/fast
> > > > make -f CMakeFiles/cmTC_2d0e9.dir/build.make CMakeFiles/cmTC_2d0e9.dir/build
> > > > Building C object CMakeFiles/cmTC_2d0e9.dir/HAVE_STATVFS_H.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -o CMakeFiles/cmTC_2d0e9.dir/HAVE_STATVFS_H.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CheckIncludeFiles/HAVE_STATVFS_H.c
> > > > Linking C executable cmTC_2d0e9
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_2d0e9.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -rdynamic CMakeFiles/cmTC_2d0e9.dir/HAVE_STATVFS_H.c.o -o cmTC_2d0e9
> > > > Determining if files sys/wait.h exist passed with the following output:
> > > > Run Build Command(s):make cmTC_cbaeb/fast
> > > > make -f CMakeFiles/cmTC_cbaeb.dir/build.make CMakeFiles/cmTC_cbaeb.dir/build
> > > > Building C object CMakeFiles/cmTC_cbaeb.dir/HAVE_WAIT_H.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -o CMakeFiles/cmTC_cbaeb.dir/HAVE_WAIT_H.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CheckIncludeFiles/HAVE_WAIT_H.c
> > > > Linking C executable cmTC_cbaeb
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_cbaeb.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -rdynamic CMakeFiles/cmTC_cbaeb.dir/HAVE_WAIT_H.c.o -o cmTC_cbaeb
> > > > Determining if files libgen.h exist passed with the following output:
> > > > Run Build Command(s):make cmTC_0df35/fast
> > > > make -f CMakeFiles/cmTC_0df35.dir/build.make CMakeFiles/cmTC_0df35.dir/build
> > > > Building C object CMakeFiles/cmTC_0df35.dir/HAVE_LIBGEN_H.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -o CMakeFiles/cmTC_0df35.dir/HAVE_LIBGEN_H.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CheckIncludeFiles/HAVE_LIBGEN_H.c
> > > > Linking C executable cmTC_0df35
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_0df35.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -rdynamic CMakeFiles/cmTC_0df35.dir/HAVE_LIBGEN_H.c.o -o cmTC_0df35
> > > > Determining if files sys/mman.h exist passed with the following output:
> > > > Run Build Command(s):make cmTC_91fc6/fast
> > > > make -f CMakeFiles/cmTC_91fc6.dir/build.make CMakeFiles/cmTC_91fc6.dir/build
> > > > Building C object CMakeFiles/cmTC_91fc6.dir/HAVE_SYS_MMAN_H.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -o CMakeFiles/cmTC_91fc6.dir/HAVE_SYS_MMAN_H.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CheckIncludeFiles/HAVE_SYS_MMAN_H.c
> > > > Linking C executable cmTC_91fc6
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_91fc6.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -rdynamic CMakeFiles/cmTC_91fc6.dir/HAVE_SYS_MMAN_H.c.o -o cmTC_91fc6
> > > > Determining if the SIGHUP exist passed with the following output:
> > > > Run Build Command(s):make cmTC_80c9b/fast
> > > > make -f CMakeFiles/cmTC_80c9b.dir/build.make CMakeFiles/cmTC_80c9b.dir/build
> > > > Building C object CMakeFiles/cmTC_80c9b.dir/CheckSymbolExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -o CMakeFiles/cmTC_80c9b.dir/CheckSymbolExists.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/CheckSymbolExists.c
> > > > Linking C executable cmTC_80c9b
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_80c9b.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -rdynamic CMakeFiles/cmTC_80c9b.dir/CheckSymbolExists.c.o -o cmTC_80c9b
> > > > File /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/CheckSymbolExists.c:
> > > > #include
> > > > int main(int argc, char** argv)
> > > > (void)argv;
> > > > #ifndef SIGHUP
> > > > return ((int*)(&SIGHUP))[argc];
> > > > #else
> > > > (void)argc;
> > > > return 0;
> > > > #endif
> > > > Determining if the function posix_memalign exists passed with the following output:
> > > > Run Build Command(s):make cmTC_94ae1/fast
> > > > make -f CMakeFiles/cmTC_94ae1.dir/build.make CMakeFiles/cmTC_94ae1.dir/build
> > > > Building C object CMakeFiles/cmTC_94ae1.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=posix_memalign -o CMakeFiles/cmTC_94ae1.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_94ae1
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_94ae1.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=posix_memalign -rdynamic CMakeFiles/cmTC_94ae1.dir/CheckFunctionExists.c.o -o cmTC_94ae1
> > > > Determining if the function nanosleep exists passed with the following output:
> > > > Run Build Command(s):make cmTC_5a27d/fast
> > > > make -f CMakeFiles/cmTC_5a27d.dir/build.make CMakeFiles/cmTC_5a27d.dir/build
> > > > Building C object CMakeFiles/cmTC_5a27d.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=nanosleep -o CMakeFiles/cmTC_5a27d.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_5a27d
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_5a27d.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=nanosleep -rdynamic CMakeFiles/cmTC_5a27d.dir/CheckFunctionExists.c.o -o cmTC_5a27d
> > > > Determining if the function usleep exists passed with the following output:
> > > > Run Build Command(s):make cmTC_acec7/fast
> > > > make -f CMakeFiles/cmTC_acec7.dir/build.make CMakeFiles/cmTC_acec7.dir/build
> > > > Building C object CMakeFiles/cmTC_acec7.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=usleep -o CMakeFiles/cmTC_acec7.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_acec7
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_acec7.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=usleep -rdynamic CMakeFiles/cmTC_acec7.dir/CheckFunctionExists.c.o -o cmTC_acec7
> > > > Determining if the function popen exists passed with the following output:
> > > > Run Build Command(s):make cmTC_e23c8/fast
> > > > make -f CMakeFiles/cmTC_e23c8.dir/build.make CMakeFiles/cmTC_e23c8.dir/build
> > > > Building C object CMakeFiles/cmTC_e23c8.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=popen -o CMakeFiles/cmTC_e23c8.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_e23c8
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_e23c8.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=popen -rdynamic CMakeFiles/cmTC_e23c8.dir/CheckFunctionExists.c.o -o cmTC_e23c8
> > > > Determining if the function pclose exists passed with the following output:
> > > > Run Build Command(s):make cmTC_277a4/fast
> > > > make -f CMakeFiles/cmTC_277a4.dir/build.make CMakeFiles/cmTC_277a4.dir/build
> > > > Building C object CMakeFiles/cmTC_277a4.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=pclose -o CMakeFiles/cmTC_277a4.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_277a4
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_277a4.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=pclose -rdynamic CMakeFiles/cmTC_277a4.dir/CheckFunctionExists.c.o -o cmTC_277a4
> > > > Determining if the function getrusage exists passed with the following output:
> > > > Run Build Command(s):make cmTC_c3686/fast
> > > > make -f CMakeFiles/cmTC_c3686.dir/build.make CMakeFiles/cmTC_c3686.dir/build
> > > > Building C object CMakeFiles/cmTC_c3686.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=getrusage -o CMakeFiles/cmTC_c3686.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_c3686
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_c3686.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=getrusage -rdynamic CMakeFiles/cmTC_c3686.dir/CheckFunctionExists.c.o -o cmTC_c3686
> > > > Determining if the function lrand48 exists passed with the following output:
> > > > Run Build Command(s):make cmTC_3155c/fast
> > > > make -f CMakeFiles/cmTC_3155c.dir/build.make CMakeFiles/cmTC_3155c.dir/build
> > > > Building C object CMakeFiles/cmTC_3155c.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=lrand48 -o CMakeFiles/cmTC_3155c.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_3155c
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_3155c.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=lrand48 -rdynamic CMakeFiles/cmTC_3155c.dir/CheckFunctionExists.c.o -o cmTC_3155c
> > > > Determining if the function strdup exists passed with the following output:
> > > > Run Build Command(s):make cmTC_fbc35/fast
> > > > make -f CMakeFiles/cmTC_fbc35.dir/build.make CMakeFiles/cmTC_fbc35.dir/build
> > > > Building C object CMakeFiles/cmTC_fbc35.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=strdup -o CMakeFiles/cmTC_fbc35.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_fbc35
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_fbc35.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=strdup -rdynamic CMakeFiles/cmTC_fbc35.dir/CheckFunctionExists.c.o -o cmTC_fbc35
> > > > Determining if the function strndup exists passed with the following output:
> > > > Run Build Command(s):make cmTC_0ab82/fast
> > > > make -f CMakeFiles/cmTC_0ab82.dir/build.make CMakeFiles/cmTC_0ab82.dir/build
> > > > Building C object CMakeFiles/cmTC_0ab82.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=strndup -o CMakeFiles/cmTC_0ab82.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_0ab82
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_0ab82.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=strndup -rdynamic CMakeFiles/cmTC_0ab82.dir/CheckFunctionExists.c.o -o cmTC_0ab82
> > > > Determining if the function sigaction exists passed with the following output:
> > > > Run Build Command(s):make cmTC_7c8ad/fast
> > > > make -f CMakeFiles/cmTC_7c8ad.dir/build.make CMakeFiles/cmTC_7c8ad.dir/build
> > > > Building C object CMakeFiles/cmTC_7c8ad.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=sigaction -o CMakeFiles/cmTC_7c8ad.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_7c8ad
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_7c8ad.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=sigaction -rdynamic CMakeFiles/cmTC_7c8ad.dir/CheckFunctionExists.c.o -o cmTC_7c8ad
> > > > Determining if the function waitpid exists passed with the following output:
> > > > Run Build Command(s):make cmTC_ff545/fast
> > > > make -f CMakeFiles/cmTC_ff545.dir/build.make CMakeFiles/cmTC_ff545.dir/build
> > > > Building C object CMakeFiles/cmTC_ff545.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=waitpid -o CMakeFiles/cmTC_ff545.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_ff545
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_ff545.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=waitpid -rdynamic CMakeFiles/cmTC_ff545.dir/CheckFunctionExists.c.o -o cmTC_ff545
> > > > Determining if the function ctime_r exists passed with the following output:
> > > > Run Build Command(s):make cmTC_fb65f/fast
> > > > make -f CMakeFiles/cmTC_fb65f.dir/build.make CMakeFiles/cmTC_fb65f.dir/build
> > > > Building C object CMakeFiles/cmTC_fb65f.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=ctime_r -o CMakeFiles/cmTC_fb65f.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_fb65f
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_fb65f.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=ctime_r -rdynamic CMakeFiles/cmTC_fb65f.dir/CheckFunctionExists.c.o -o cmTC_fb65f
> > > > Determining if the function realpath exists passed with the following output:
> > > > Run Build Command(s):make cmTC_63751/fast
> > > > make -f CMakeFiles/cmTC_63751.dir/build.make CMakeFiles/cmTC_63751.dir/build
> > > > Building C object CMakeFiles/cmTC_63751.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=realpath -o CMakeFiles/cmTC_63751.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_63751
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_63751.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=realpath -rdynamic CMakeFiles/cmTC_63751.dir/CheckFunctionExists.c.o -o cmTC_63751
> > > > Determining if the function mmap exists passed with the following output:
> > > > Run Build Command(s):make cmTC_a209c/fast
> > > > make -f CMakeFiles/cmTC_a209c.dir/build.make CMakeFiles/cmTC_a209c.dir/build
> > > > Building C object CMakeFiles/cmTC_a209c.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=mmap -o CMakeFiles/cmTC_a209c.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_a209c
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_a209c.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=mmap -rdynamic CMakeFiles/cmTC_a209c.dir/CheckFunctionExists.c.o -o cmTC_a209c
> > > > Determining if the function sysconf exists passed with the following output:
> > > > Run Build Command(s):make cmTC_b5135/fast
> > > > make -f CMakeFiles/cmTC_b5135.dir/build.make CMakeFiles/cmTC_b5135.dir/build
> > > > Building C object CMakeFiles/cmTC_b5135.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=sysconf -o CMakeFiles/cmTC_b5135.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_b5135
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_b5135.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=sysconf -rdynamic CMakeFiles/cmTC_b5135.dir/CheckFunctionExists.c.o -o cmTC_b5135
> > > > Performing C SOURCE FILE Test SRAND_CHECK succeeded with the following compile output:
> > > > Run Build Command(s):make cmTC_f3779/fast
> > > > make -f CMakeFiles/cmTC_f3779.dir/build.make CMakeFiles/cmTC_f3779.dir/build
> > > > Building C object CMakeFiles/cmTC_f3779.dir/src.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DSRAND_CHECK -o CMakeFiles/cmTC_f3779.dir/src.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/src.c
> > > > Linking C executable cmTC_f3779
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_f3779.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DSRAND_CHECK -rdynamic CMakeFiles/cmTC_f3779.dir/src.c.o -o cmTC_f3779
> > > > ...and run output:
> > > > Return value: 1
> > > > Source file was:
> > > > #include
> > > > int main()
> > > > srand(1);
> > > > unsigned long a = rand();
> > > > srand(1);
> > > > unsigned long b = rand();
> > > > return a == b ? EXIT_SUCCESS : EXIT_FAILURE;
> > > > Determining if files linux/binfmts.h exist passed with the following output:
> > > > Run Build Command(s):make cmTC_35503/fast
> > > > make -f CMakeFiles/cmTC_35503.dir/build.make CMakeFiles/cmTC_35503.dir/build
> > > > Building C object CMakeFiles/cmTC_35503.dir/HAVE_LINUX_BINFMTS_H.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -o CMakeFiles/cmTC_35503.dir/HAVE_LINUX_BINFMTS_H.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CheckIncludeFiles/HAVE_LINUX_BINFMTS_H.c
> > > > Linking C executable cmTC_35503
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_35503.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -rdynamic CMakeFiles/cmTC_35503.dir/HAVE_LINUX_BINFMTS_H.c.o -o cmTC_35503
> > > > Performing C++ SOURCE FILE Test HAVE_STD_SHARED_PTR_BASIC succeeded with the following output:
> > > > Run Build Command(s):make cmTC_0ad6c/fast
> > > > make -f CMakeFiles/cmTC_0ad6c.dir/build.make CMakeFiles/cmTC_0ad6c.dir/build
> > > > Building CXX object CMakeFiles/cmTC_0ad6c.dir/src.cxx.o
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAVE_STD_SHARED_PTR_BASIC -o CMakeFiles/cmTC_0ad6c.dir/src.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/src.cxx
> > > > Linking CXX executable cmTC_0ad6c
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_0ad6c.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAVE_STD_SHARED_PTR_BASIC -rdynamic CMakeFiles/cmTC_0ad6c.dir/src.cxx.o -o cmTC_0ad6c
> > > > make[2]: Leaving directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
> > > > make[1]: Leaving directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
> > > > Source file was:
> > > > #include
> > > > struct foo {
> > > > std::shared_ptr a;
> > > > int main()
> > > > foo f;
> > > > f.a = std::make_shared();
> > > > return 0;
> > > > Performing C++ SOURCE FILE Test HAS_NOT_BUG_21397_STD_VERSION succeeded with the following output:
> > > > Run Build Command(s):make cmTC_09fd7/fast
> > > > make -f CMakeFiles/cmTC_09fd7.dir/build.make CMakeFiles/cmTC_09fd7.dir/build
> > > > Building CXX object CMakeFiles/cmTC_09fd7.dir/src.cxx.o
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAS_NOT_BUG_21397_STD_VERSION -o CMakeFiles/cmTC_09fd7.dir/src.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/src.cxx
> > > > Linking CXX executable cmTC_09fd7
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_09fd7.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAS_NOT_BUG_21397_STD_VERSION -rdynamic CMakeFiles/cmTC_09fd7.dir/src.cxx.o -o cmTC_09fd7
> > > > Source file was:
> > > > #include
> > > > class nocopy {
> > > > protected:
> > > > nocopy() {}
> > > > ~nocopy() {}
> > > > private:
> > > > nocopy(const nocopy&);
> > > > nocopy& operator=(const nocopy&);
> > > > class foo: private nocopy {
> > > > int val;
> > > > public:
> > > > foo(int val) : val(val) {}
> > > > int value() const { return val; }
> > > > std::shared_ptr blah()
> > > > const int val = 65536;
> > > > return std::make_shared(val);
> > > > int main()
> > > > return blah()->value();
> > > > Determining if the include file cxxabi.h exists passed with the following output:
> > > > Run Build Command(s):make cmTC_2c20c/fast
> > > > make -f CMakeFiles/cmTC_2c20c.dir/build.make CMakeFiles/cmTC_2c20c.dir/build
> > > > Building CXX object CMakeFiles/cmTC_2c20c.dir/CheckIncludeFile.cxx.o
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -o CMakeFiles/cmTC_2c20c.dir/CheckIncludeFile.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
> > > > Linking CXX executable cmTC_2c20c
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_2c20c.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -rdynamic CMakeFiles/cmTC_2c20c.dir/CheckIncludeFile.cxx.o -o cmTC_2c20c
> > > > Determining if files regex.h exist passed with the following output:
> > > > Run Build Command(s):make cmTC_94d26/fast
> > > > make -f CMakeFiles/cmTC_94d26.dir/build.make CMakeFiles/cmTC_94d26.dir/build
> > > > Building C object CMakeFiles/cmTC_94d26.dir/HAVE_REGEX_H.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -o CMakeFiles/cmTC_94d26.dir/HAVE_REGEX_H.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CheckIncludeFiles/HAVE_REGEX_H.c
> > > > Linking C executable cmTC_94d26
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_94d26.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -rdynamic CMakeFiles/cmTC_94d26.dir/HAVE_REGEX_H.c.o -o cmTC_94d26
> > > > Performing C++ SOURCE FILE Test HAVE_ALIGNED_ALLOC succeeded with the following output:
> > > > Run Build Command(s):make cmTC_a1de5/fast
> > > > make -f CMakeFiles/cmTC_a1de5.dir/build.make CMakeFiles/cmTC_a1de5.dir/build
> > > > Building CXX object CMakeFiles/cmTC_a1de5.dir/src.cxx.o
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAVE_ALIGNED_ALLOC -o CMakeFiles/cmTC_a1de5.dir/src.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/src.cxx
> > > > Linking CXX executable cmTC_a1de5
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_a1de5.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAVE_ALIGNED_ALLOC -rdynamic CMakeFiles/cmTC_a1de5.dir/src.cxx.o -o cmTC_a1de5
> > > > Source file was:
> > > > #include
> > > > int main()
> > > > return aligned_alloc(64, 1024) != NULL;
> > > > Performing C++ SOURCE FILE Test HAVE_ALIGNAS succeeded with the following output:
> > > > Run Build Command(s):make cmTC_946c1/fast
> > > > make -f CMakeFiles/cmTC_946c1.dir/build.make CMakeFiles/cmTC_946c1.dir/build
> > > > Building CXX object CMakeFiles/cmTC_946c1.dir/src.cxx.o
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAVE_ALIGNAS -o CMakeFiles/cmTC_946c1.dir/src.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/src.cxx
> > > > Linking CXX executable cmTC_946c1
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_946c1.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAVE_ALIGNAS -rdynamic CMakeFiles/cmTC_946c1.dir/src.cxx.o -o cmTC_946c1
> > > > Source file was:
> > > > #include
> > > > int main()
> > > > alignas(8) uint32_t x = 0;
> > > > return x;
> > > > Performing C++ SOURCE FILE Test HAVE_GLIBC_VECTOR_INTERNALS succeeded with the following output:
> > > > Change Dir: /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp
> > > > Run Build Command(s):make cmTC_97a10/fast
> > > > make[1]: Entering directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
> > > > make -f CMakeFiles/cmTC_97a10.dir/build.make CMakeFiles/cmTC_97a10.dir/build
> > > > make[2]: Entering directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp'
> > > > Building CXX object CMakeFiles/cmTC_97a10.dir/src.cxx.o
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAVE_GLIBC_VECTOR_INTERNALS -o CMakeFiles/cmTC_97a10.dir/src.cxx.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp/src.cxx
> > > > Linking CXX executable cmTC_97a10
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_97a10.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DHAVE_GLIBC_VECTOR_INTERNALS -rdynamic CMakeFiles/cmTC_97a10.dir/src.cxx.o -o cmTC_97a10
> > > > Source file was:
> > > > #ifdef __OpenBSD__
> > > > #error "forcibly disabling mmappable vectors for openbsd"
> > > > #endif
> > > > #include
> > > > struct fred : public std::vector {
> > > > typedef std::vector Base;
> > > > fred(size_type n, int a) : Base(n, a) {}
> > > > bool foo() {
> > > > void * x = Base::_M_impl._M_start;
> > > > void * y = Base::_M_impl._M_finish;
> > > > void * z = Base::_M_impl._M_end_of_storage;
> > > > return x == y || x == z;
> > > > Base::allocator_type * bar() { return &Base::_M_get_Tp_allocator(); };
> > > > int main() {
> > > > fred F(12, 1);
> > > > Determining if the function pthread_create exists passed with the following output:
> > > > Run Build Command(s):make cmTC_0213d/fast
> > > > make -f CMakeFiles/cmTC_0213d.dir/build.make CMakeFiles/cmTC_0213d.dir/build
> > > > Building C object CMakeFiles/cmTC_0213d.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=pthread_create -o CMakeFiles/cmTC_0213d.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_0213d
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_0213d.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=pthread_create -rdynamic CMakeFiles/cmTC_0213d.dir/CheckFunctionExists.c.o -o cmTC_0213d -lpthread
> > > > Determining if the function pthread_barrier_wait exists passed with the following output:
> > > > Run Build Command(s):make cmTC_f47de/fast
> > > > make -f CMakeFiles/cmTC_f47de.dir/build.make CMakeFiles/cmTC_f47de.dir/build
> > > > Building C object CMakeFiles/cmTC_f47de.dir/CheckFunctionExists.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=pthread_barrier_wait -o CMakeFiles/cmTC_f47de.dir/CheckFunctionExists.c.o -c /usr/share/cmake/Modules/CheckFunctionExists.c
> > > > Linking C executable cmTC_f47de
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_f47de.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -DCHECK_FUNCTION_EXISTS=pthread_barrier_wait -rdynamic CMakeFiles/cmTC_f47de.dir/CheckFunctionExists.c.o -o cmTC_f47de -lpthread
> > > > Detecting C OpenMP compiler ABI info compiled with the following output:
> > > > Run Build Command(s):make cmTC_e5e93/fast
> > > > make -f CMakeFiles/cmTC_e5e93.dir/build.make CMakeFiles/cmTC_e5e93.dir/build
> > > > Building C object CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -fopenmp -v -o CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/FindOpenMP/OpenMPTryFlag.c
> > > > Using built-in specs.
> > > > COLLECT_GCC=/usr/bin/cc
> > > > OFFLOAD_TARGET_NAMES=nvptx-none
> > > > OFFLOAD_TARGET_DEFAULT=1
> > > > Target: x86_64-redhat-linux
> > > > Configured with: ../configure --enable-bootstrap --enable-languages=c,c++,fortran,objc,obj-c++,ada,go,d,lto --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-shared --enable-threads=posix --enable-checking=release --enable-multilib --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-gcc-major-version-only --with-linker-hash-style=gnu --enable-plugin --enable-initfini-array --with-isl --enable-offload-targets=nvptx-none --without-cuda-driver --enable-gnu-indirect-function --enable-cet --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux
> > > > Thread model: posix
> > > > gcc version 9.1.1 20190503 (Red Hat 9.1.1-1) (GCC)
> > > > COLLECT_GCC_OPTIONS='-std=c99' '-g' '-Wextra' '-Wall' '-O2' '-msse3' '-mssse3' '-msse4.1' '-mavx' '-mavx2' '-mpclmul' '-fopenmp' '-v' '-o' 'CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o' '-c' '-mtune=generic' '-march=x86-64' '-pthread'
> > > > /usr/libexec/gcc/x86_64-redhat-linux/9/cc1 -quiet -v -D_REENTRANT /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/FindOpenMP/OpenMPTryFlag.c -quiet -dumpbase OpenMPTryFlag.c -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -mtune=generic -march=x86-64 -auxbase-strip CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o -g -O2 -Wextra -Wall -std=c99 -version -fopenmp -o /tmp/cckofNdP.s
> > > > GNU C99 (GCC) version 9.1.1 20190503 (Red Hat 9.1.1-1) (x86_64-redhat-linux)
> > > > compiled by GNU C version 9.1.1 20190503 (Red Hat 9.1.1-1), GMP version 6.1.2, MPFR version 3.1.6-p2, MPC version 1.1.0, isl version isl-0.16.1-GMP
> > > > GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
> > > > ignoring nonexistent directory "/usr/lib/gcc/x86_64-redhat-linux/9/include-fixed"
> > > > ignoring nonexistent directory "/usr/lib/gcc/x86_64-redhat-linux/9/../../../../x86_64-redhat-linux/include"
> > > > #include "..." search starts here:
> > > > #include <...> search starts here:
> > > > /usr/local/include
> > > > /usr/include
> > > > End of search list.
> > > > Compiler executable checksum: 4c18cb8ccf58c37e364f2f0344233b17
> > > > as -v --64 -o CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o /tmp/cckofNdP.s
> > > > GNU assembler version 2.31.1 (x86_64-redhat-linux) using BFD version version 2.31.1-29.fc30
> > > > COMPILER_PATH=/usr/libexec/gcc/x86_64-redhat-linux/9/:/usr/libexec/gcc/x86_64-redhat-linux/9/:/usr/libexec/gcc/x86_64-redhat-linux/:/usr/lib/gcc/x86_64-redhat-linux/9/:/usr/lib/gcc/x86_64-redhat-linux/
> > > > LIBRARY_PATH=/usr/lib/gcc/x86_64-redhat-linux/9/:/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/usr/lib/gcc/x86_64-redhat-linux/9/../../../:/lib/:/usr/lib/
> > > > Linking C executable cmTC_e5e93
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_e5e93.dir/link.txt --verbose=1
> > > > /usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -fopenmp -v -rdynamic CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o -o cmTC_e5e93 -v
> > > > COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper
> > > > Thread model: posix
> > > > Reading specs from /usr/lib/gcc/x86_64-redhat-linux/9/libgomp.spec
> > > > COLLECT_GCC_OPTIONS='-std=c99' '-g' '-Wextra' '-Wall' '-O2' '-msse3' '-mssse3' '-msse4.1' '-mavx' '-mavx2' '-mpclmul' '-fopenmp' '-v' '-rdynamic' '-o' 'cmTC_e5e93' '-v' '-mtune=generic' '-march=x86-64' '-pthread'
> > > > /usr/libexec/gcc/x86_64-redhat-linux/9/collect2 -plugin /usr/libexec/gcc/x86_64-redhat-linux/9/liblto_plugin.so -plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper -plugin-opt=-fresolution=/tmp/cc7QQYmO.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lpthread -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTC_e5e93 /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/9/crtbegin.o /usr/lib/gcc/x86_64-redhat-linux/9/crtoffloadbegin.o -L/usr/lib/gcc/x86_64-redhat-linux/9 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../.. CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o -lgomp -lgcc --push-state --as-needed -lgcc_s --pop-state -lpthread -lc -lgcc --push-state --as-needed -lgcc_s --pop-state /usr/lib/gcc/x86_64-redhat-linux/9/crtend.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crtn.o /usr/lib/gcc/x86_64-redhat-linux/9/crtoffloadend.o
> > > > Parsed C OpenMP implicit link information from above output:
> > > > link line regex: [^( *|.*[/\])(ld|CMAKE_LINK_STARTFILE-NOTFOUND|([^/\]+-)?ld|collect2)[^/\]*( |$)]
> > > > ignore line: [Change Dir: /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp]
> > > > ignore line: []
> > > > ignore line: [Run Build Command(s):make cmTC_e5e93/fast ]
> > > > ignore line: [make[1]: Entering directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp']
> > > > ignore line: [make -f CMakeFiles/cmTC_e5e93.dir/build.make CMakeFiles/cmTC_e5e93.dir/build]
> > > > ignore line: [make[2]: Entering directory '/home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/CMakeTmp']
> > > > ignore line: [Building C object CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o]
> > > > ignore line: [/usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -fopenmp -v -o CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/FindOpenMP/OpenMPTryFlag.c]
> > > > ignore line: [Using built-in specs.]
> > > > ignore line: [COLLECT_GCC=/usr/bin/cc]
> > > > ignore line: [OFFLOAD_TARGET_NAMES=nvptx-none]
> > > > ignore line: [OFFLOAD_TARGET_DEFAULT=1]
> > > > ignore line: [Target: x86_64-redhat-linux]
> > > > ignore line: [Configured with: ../configure --enable-bootstrap --enable-languages=c,c++,fortran,objc,obj-c++,ada,go,d,lto --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-shared --enable-threads=posix --enable-checking=release --enable-multilib --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-gcc-major-version-only --with-linker-hash-style=gnu --enable-plugin --enable-initfini-array --with-isl --enable-offload-targets=nvptx-none --without-cuda-driver --enable-gnu-indirect-function --enable-cet --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux]
> > > > ignore line: [Thread model: posix]
> > > > ignore line: [gcc version 9.1.1 20190503 (Red Hat 9.1.1-1) (GCC) ]
> > > > ignore line: [COLLECT_GCC_OPTIONS='-std=c99' '-g' '-Wextra' '-Wall' '-O2' '-msse3' '-mssse3' '-msse4.1' '-mavx' '-mavx2' '-mpclmul' '-fopenmp' '-v' '-o' 'CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o' '-c' '-mtune=generic' '-march=x86-64' '-pthread']
> > > > ignore line: [ /usr/libexec/gcc/x86_64-redhat-linux/9/cc1 -quiet -v -D_REENTRANT /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/FindOpenMP/OpenMPTryFlag.c -quiet -dumpbase OpenMPTryFlag.c -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -mtune=generic -march=x86-64 -auxbase-strip CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o -g -O2 -Wextra -Wall -std=c99 -version -fopenmp -o /tmp/cckofNdP.s]
> > > > ignore line: [GNU C99 (GCC) version 9.1.1 20190503 (Red Hat 9.1.1-1) (x86_64-redhat-linux)]
> > > > ignore line: [ compiled by GNU C version 9.1.1 20190503 (Red Hat 9.1.1-1), GMP version 6.1.2, MPFR version 3.1.6-p2, MPC version 1.1.0, isl version isl-0.16.1-GMP]
> > > > ignore line: []
> > > > ignore line: [GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072]
> > > > ignore line: [ignoring nonexistent directory "/usr/lib/gcc/x86_64-redhat-linux/9/include-fixed"]
> > > > ignore line: [ignoring nonexistent directory "/usr/lib/gcc/x86_64-redhat-linux/9/../../../../x86_64-redhat-linux/include"]
> > > > ignore line: [#include "..." search starts here:]
> > > > ignore line: [#include <...> search starts here:]
> > > > ignore line: [ /usr/lib/gcc/x86_64-redhat-linux/9/include]
> > > > ignore line: [ /usr/local/include]
> > > > ignore line: [ /usr/include]
> > > > ignore line: [End of search list.]
> > > > ignore line: []
> > > > ignore line: [Compiler executable checksum: 4c18cb8ccf58c37e364f2f0344233b17]
> > > > ignore line: [ as -v --64 -o CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o /tmp/cckofNdP.s]
> > > > ignore line: [GNU assembler version 2.31.1 (x86_64-redhat-linux) using BFD version version 2.31.1-29.fc30]
> > > > ignore line: [COMPILER_PATH=/usr/libexec/gcc/x86_64-redhat-linux/9/:/usr/libexec/gcc/x86_64-redhat-linux/9/:/usr/libexec/gcc/x86_64-redhat-linux/:/usr/lib/gcc/x86_64-redhat-linux/9/:/usr/lib/gcc/x86_64-redhat-linux/]
> > > > ignore line: [LIBRARY_PATH=/usr/lib/gcc/x86_64-redhat-linux/9/:/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/usr/lib/gcc/x86_64-redhat-linux/9/../../../:/lib/:/usr/lib/]
> > > > ignore line: [Linking C executable cmTC_e5e93]
> > > > ignore line: [/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_e5e93.dir/link.txt --verbose=1]
> > > > ignore line: [/usr/bin/cc -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -fopenmp -v -rdynamic CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o -o cmTC_e5e93 -v ]
> > > > ignore line: [COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper]
> > > > ignore line: [Reading specs from /usr/lib/gcc/x86_64-redhat-linux/9/libgomp.spec]
> > > > ignore line: [COLLECT_GCC_OPTIONS='-std=c99' '-g' '-Wextra' '-Wall' '-O2' '-msse3' '-mssse3' '-msse4.1' '-mavx' '-mavx2' '-mpclmul' '-fopenmp' '-v' '-rdynamic' '-o' 'cmTC_e5e93' '-v' '-mtune=generic' '-march=x86-64' '-pthread']
> > > > link line: [ /usr/libexec/gcc/x86_64-redhat-linux/9/collect2 -plugin /usr/libexec/gcc/x86_64-redhat-linux/9/liblto_plugin.so -plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper -plugin-opt=-fresolution=/tmp/cc7QQYmO.res -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lpthread -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lgcc_s --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTC_e5e93 /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/9/crtbegin.o /usr/lib/gcc/x86_64-redhat-linux/9/crtoffloadbegin.o -L/usr/lib/gcc/x86_64-redhat-linux/9 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../.. CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o -lgomp -lgcc --push-state --as-needed -lgcc_s --pop-state -lpthread -lc -lgcc --push-state --as-needed -lgcc_s --pop-state /usr/lib/gcc/x86_64-redhat-linux/9/crtend.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crtn.o /usr/lib/gcc/x86_64-redhat-linux/9/crtoffloadend.o]
> > > > arg [/usr/libexec/gcc/x86_64-redhat-linux/9/collect2] ==> ignore
> > > > arg [-plugin] ==> ignore
> > > > arg [/usr/libexec/gcc/x86_64-redhat-linux/9/liblto_plugin.so] ==> ignore
> > > > arg [-plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper] ==> ignore
> > > > arg [-plugin-opt=-fresolution=/tmp/cc7QQYmO.res] ==> ignore
> > > > arg [-plugin-opt=-pass-through=-lgcc] ==> ignore
> > > > arg [-plugin-opt=-pass-through=-lgcc_s] ==> ignore
> > > > arg [-plugin-opt=-pass-through=-lpthread] ==> ignore
> > > > arg [-plugin-opt=-pass-through=-lc] ==> ignore
> > > > arg [--build-id] ==> ignore
> > > > arg [--no-add-needed] ==> ignore
> > > > arg [--eh-frame-hdr] ==> ignore
> > > > arg [--hash-style=gnu] ==> ignore
> > > > arg [-m] ==> ignore
> > > > arg [elf_x86_64] ==> ignore
> > > > arg [-export-dynamic] ==> ignore
> > > > arg [-dynamic-linker] ==> ignore
> > > > arg [/lib64/ld-linux-x86-64.so.2] ==> ignore
> > > > arg [-o] ==> ignore
> > > > arg [cmTC_e5e93] ==> ignore
> > > > arg [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crt1.o] ==> ignore
> > > > arg [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crti.o] ==> ignore
> > > > arg [/usr/lib/gcc/x86_64-redhat-linux/9/crtbegin.o] ==> ignore
> > > > arg [/usr/lib/gcc/x86_64-redhat-linux/9/crtoffloadbegin.o] ==> ignore
> > > > arg [-L/usr/lib/gcc/x86_64-redhat-linux/9] ==> dir [/usr/lib/gcc/x86_64-redhat-linux/9]
> > > > arg [-L/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64] ==> dir [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64]
> > > > arg [-L/lib/../lib64] ==> dir [/lib/../lib64]
> > > > arg [-L/usr/lib/../lib64] ==> dir [/usr/lib/../lib64]
> > > > arg [-L/usr/lib/gcc/x86_64-redhat-linux/9/../../..] ==> dir [/usr/lib/gcc/x86_64-redhat-linux/9/../../..]
> > > > arg [CMakeFiles/cmTC_e5e93.dir/OpenMPTryFlag.c.o] ==> ignore
> > > > arg [-lgomp] ==> lib [gomp]
> > > > arg [-lgcc] ==> lib [gcc]
> > > > arg [--push-state] ==> ignore
> > > > arg [--as-needed] ==> ignore
> > > > arg [-lgcc_s] ==> lib [gcc_s]
> > > > arg [--pop-state] ==> ignore
> > > > arg [-lpthread] ==> lib [pthread]
> > > > arg [-lc] ==> lib [c]
> > > > arg [/usr/lib/gcc/x86_64-redhat-linux/9/crtend.o] ==> ignore
> > > > arg [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crtn.o] ==> ignore
> > > > arg [/usr/lib/gcc/x86_64-redhat-linux/9/crtoffloadend.o] ==> ignore
> > > > collapse library dir [/usr/lib/gcc/x86_64-redhat-linux/9] ==> [/usr/lib/gcc/x86_64-redhat-linux/9]
> > > > collapse library dir [/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64] ==> [/usr/lib64]
> > > > collapse library dir [/lib/../lib64] ==> [/lib64]
> > > > collapse library dir [/usr/lib/../lib64] ==> [/usr/lib64]
> > > > collapse library dir [/usr/lib/gcc/x86_64-redhat-linux/9/../../..] ==> [/usr/lib]
> > > > implicit libs: [gomp;gcc;gcc_s;pthread;c;gcc;gcc_s]
> > > > implicit dirs: [/usr/lib/gcc/x86_64-redhat-linux/9;/usr/lib64;/lib64;/usr/lib]
> > > > implicit fwks: []
> > > > Detecting CXX OpenMP compiler ABI info compiled with the following output:
> > > > Run Build Command(s):make cmTC_4eac5/fast
> > > > make -f CMakeFiles/cmTC_4eac5.dir/build.make CMakeFiles/cmTC_4eac5.dir/build
> > > > Building CXX object CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -fopenmp -v -o CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/FindOpenMP/OpenMPTryFlag.cpp
> > > > COLLECT_GCC=/usr/bin/c++
> > > > Thread model: posix
> > > > COLLECT_GCC_OPTIONS='-std=c++11' '-g' '-Wextra' '-Wall' '-O2' '-Wno-literal-suffix' '-msse3' '-mssse3' '-msse4.1' '-mavx' '-mavx2' '-mpclmul' '-fopenmp' '-v' '-o' 'CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o' '-c' '-shared-libgcc' '-mtune=generic' '-march=x86-64' '-pthread'
> > > > /usr/libexec/gcc/x86_64-redhat-linux/9/cc1plus -quiet -v -D_GNU_SOURCE -D_REENTRANT /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/FindOpenMP/OpenMPTryFlag.cpp -quiet -dumpbase OpenMPTryFlag.cpp -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -mtune=generic -march=x86-64 -auxbase-strip CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o -g -O2 -Wextra -Wall -Wno-literal-suffix -std=c++11 -version -fopenmp -o /tmp/cc88uPg0.s
> > > > GNU C++11 (GCC) version 9.1.1 20190503 (Red Hat 9.1.1-1) (x86_64-redhat-linux)
> > > > /usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9
> > > > /usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9/x86_64-redhat-linux
> > > > /usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9/backward
> > > > /usr/local/include
> > > > /usr/include
> > > > End of search list.
> > > > Compiler executable checksum: a3b782be16d22698470553fc15b77082
> > > > as -v --64 -o CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o /tmp/cc88uPg0.s
> > > > Linking CXX executable cmTC_4eac5
> > > > /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_4eac5.dir/link.txt --verbose=1
> > > > /usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -fopenmp -v -rdynamic CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o -o cmTC_4eac5 -v
> > > > Thread model: posix
> > > > COLLECT_GCC_OPTIONS='-std=c++11' '-g' '-Wextra' '-Wall' '-O2' '-Wno-literal-suffix' '-msse3' '-mssse3' '-msse4.1' '-mavx' '-mavx2' '-mpclmul' '-fopenmp' '-v' '-rdynamic' '-o' 'cmTC_4eac5' '-v' '-shared-libgcc' '-mtune=generic' '-march=x86-64' '-pthread'
> > > > /usr/libexec/gcc/x86_64-redhat-linux/9/collect2 -plugin /usr/libexec/gcc/x86_64-redhat-linux/9/liblto_plugin.so -plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper -plugin-opt=-fresolution=/tmp/ccBEZCB7.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lpthread -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTC_4eac5 /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/9/crtbegin.o /usr/lib/gcc/x86_64-redhat-linux/9/crtoffloadbegin.o -L/usr/lib/gcc/x86_64-redhat-linux/9 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../.. CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o -lstdc++ -lm -lgomp -lgcc_s -lgcc -lpthread -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-redhat-linux/9/crtend.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crtn.o /usr/lib/gcc/x86_64-redhat-linux/9/crtoffloadend.o
> > > > Parsed CXX OpenMP implicit link information from above output:
> > > > ignore line: []
> > > > ignore line: [Run Build Command(s):make cmTC_4eac5/fast ]
> > > > ignore line: [make -f CMakeFiles/cmTC_4eac5.dir/build.make CMakeFiles/cmTC_4eac5.dir/build]
> > > > ignore line: [Building CXX object CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o]
> > > > ignore line: [/usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -fopenmp -v -o CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o -c /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/FindOpenMP/OpenMPTryFlag.cpp]
> > > > ignore line: [COLLECT_GCC=/usr/bin/c++]
> > > > ignore line: [COLLECT_GCC_OPTIONS='-std=c++11' '-g' '-Wextra' '-Wall' '-O2' '-Wno-literal-suffix' '-msse3' '-mssse3' '-msse4.1' '-mavx' '-mavx2' '-mpclmul' '-fopenmp' '-v' '-o' 'CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o' '-c' '-shared-libgcc' '-mtune=generic' '-march=x86-64' '-pthread']
> > > > ignore line: [ /usr/libexec/gcc/x86_64-redhat-linux/9/cc1plus -quiet -v -D_GNU_SOURCE -D_REENTRANT /home/rjd/cado-nfs-ac460da/build/home9/CMakeFiles/FindOpenMP/OpenMPTryFlag.cpp -quiet -dumpbase OpenMPTryFlag.cpp -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -mtune=generic -march=x86-64 -auxbase-strip CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o -g -O2 -Wextra -Wall -Wno-literal-suffix -std=c++11 -version -fopenmp -o /tmp/cc88uPg0.s]
> > > > ignore line: [GNU C++11 (GCC) version 9.1.1 20190503 (Red Hat 9.1.1-1) (x86_64-redhat-linux)]
> > > > ignore line: []
> > > > ignore line: [ /usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9]
> > > > ignore line: [ /usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9/x86_64-redhat-linux]
> > > > ignore line: [ /usr/lib/gcc/x86_64-redhat-linux/9/../../../../include/c++/9/backward]
> > > > ignore line: []
> > > > ignore line: [Compiler executable checksum: a3b782be16d22698470553fc15b77082]
> > > > ignore line: [ as -v --64 -o CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o /tmp/cc88uPg0.s]
> > > > ignore line: [Linking CXX executable cmTC_4eac5]
> > > > ignore line: [/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_4eac5.dir/link.txt --verbose=1]
> > > > ignore line: [/usr/bin/c++ -std=c++11 -g -W -Wall -O2 -Wno-literal-suffix -msse3 -mssse3 -msse4.1 -mavx -mavx2 -mpclmul -fopenmp -v -rdynamic CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o -o cmTC_4eac5 -v ]
> > > > ignore line: [COLLECT_GCC_OPTIONS='-std=c++11' '-g' '-Wextra' '-Wall' '-O2' '-Wno-literal-suffix' '-msse3' '-mssse3' '-msse4.1' '-mavx' '-mavx2' '-mpclmul' '-fopenmp' '-v' '-rdynamic' '-o' 'cmTC_4eac5' '-v' '-shared-libgcc' '-mtune=generic' '-march=x86-64' '-pthread']
> > > > link line: [ /usr/libexec/gcc/x86_64-redhat-linux/9/collect2 -plugin /usr/libexec/gcc/x86_64-redhat-linux/9/liblto_plugin.so -plugin-opt=/usr/libexec/gcc/x86_64-redhat-linux/9/lto-wrapper -plugin-opt=-fresolution=/tmp/ccBEZCB7.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lpthread -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTC_4eac5 /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/9/crtbegin.o /usr/lib/gcc/x86_64-redhat-linux/9/crtoffloadbegin.o -L/usr/lib/gcc/x86_64-redhat-linux/9 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/9/../../.. CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o -lstdc++ -lm -lgomp -lgcc_s -lgcc -lpthread -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-redhat-linux/9/crtend.o /usr/lib/gcc/x86_64-redhat-linux/9/../../../../lib64/crtn.o /usr/lib/gcc/x86_64-redhat-linux/9/crtoffloadend.o]
> > > > arg [-plugin-opt=-fresolution=/tmp/ccBEZCB7.res] ==> ignore
> > > > arg [-m] ==> ignore
> > > > arg [-o] ==> ignore
> > > > arg [cmTC_4eac5] ==> ignore
> > > > arg [CMakeFiles/cmTC_4eac5.dir/OpenMPTryFlag.cpp.o] ==> ignore
> > > > arg [-lstdc++] ==> lib [stdc++]
> > > > arg [-lm] ==> lib [m]
> > > > implicit libs: [stdc++;m;gomp;gcc_s;gcc;pthread;c;gcc_s;gcc]
> > > > implicit fwks: []
> > > > > _______________________________________________
> > > > Cado-nfs-discuss mailing list
> > > > Cado-nfs-discuss@lists.gforge.inria.fr mailto:Cado-nfs-discuss@lists.gforge.inria.fr
> > > > https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] Latest GCC 9.1.1 Mis-compiles Git Src Files, ROBERT DUCHATEAU, 06/10/2019
- Re: [Cado-nfs-discuss] Latest GCC 9.1.1 Mis-compiles Git Src Files, paul zimmermann, 06/10/2019
- Re: [Cado-nfs-discuss] Latest GCC 9.1.1 Mis-compiles Git Src Files, Emmanuel Thomé, 06/10/2019
- Re: [Cado-nfs-discuss] Latest GCC 9.1.1 Mis-compiles Git Src Files, ROBERT DUCHATEAU, 06/10/2019
- Re: [Cado-nfs-discuss] Latest GCC 9.1.1 Mis-compiles Git Src Files, ROBERT DUCHATEAU, 06/11/2019
