cado-nfs - [Cado-nfs-discuss] polyselect3 not found
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] polyselect3 not found
  • Date: Wed, 11 Sep 2019 01:34:08 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasonp@panix.com; spf=Pass smtp.mailfrom=jason.parker.burlingham@gmail.com; spf=None smtp.helo=postmaster@mail-ed1-f45.google.com
  • Ironport-phdr: 9a23:Zq7x5hYLq6DE6AFHcFAO+Y3/LSx+4OfEezUN459isYplN5qZr8+4bnLW6fgltlLVR4KTs6sC17ON9fi5Ej1eqdbZ6TZeKcYKD0dEwewt3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9FYHdldm42P6v8JPPfQpImCC9YbRvJxmqsAndrMYbjZZsJ6or1hfFv3REduBXyGh1IV6fgwvw6t2/8ZJ+7Shcoe4t+9JFXa7nY6k2ULtUASg8PWso/sPrrx7DTQWO5nsYTGoblwdDDhbG4h/nQJr/qzP2ueVh1iaUO832Vq00Vi+576h3Uh/oiTwIOCA//WrKl8F/lqNboBampxxi347ZZZyeOfRicq/Be94RWGxMVdtTWSNcGIOxd4QAAeoPM+hbsofzuUcBoACiBQWwHu7j1iNEimP00KA8zu8vERvG3AslH98WtHrbts71NKAUUeuo1qfH1y/Db/BI1jfn8YTFbw0hoeuIXbJxd8rRxkkvGBnAjl6NroHlPSma1v8Ks2id9+ptTvqvhHQhqwFwrTmj3Nsjio7Mho8MzF3P6CZ3wJ4tKNGmVEJ2ZcSoHZhQui2AKYd6XsAvT3tntSs6zLANpIS1czIQyJs9wh7Sc/yHfJaM4hLkTOuRJC13hHNheL6mmRm97FWsxvTyVsS70FtGtCVFkt7LtnAC0xzc9NKLRed6/kekwTqP1gbT5f9YIU0si6bXN5oszqQzm5cTq0jPADP6lUbsgKKZdkgo4u2o5P7mYrXiqJ+cLYh0igTmP6QsgMO/GuM4Mg4UU2iD4+u8zr7j8lPjQLlQlfI2j7PZsJTbJcQdqa65AxVa0oM45hawCjepytUYnX0dIF1ZfxKHipDlO0vSL/DgEfe/n1OsnS93yP/cI7LhBYzBLn7NkLf6ZLpy9k9cyBEvwtBC/JJUEaoMIPbyWk/qqNzYFQU1MwO6w+bgEtV92Z0RVXiOAq+fKqPSsEWH6vghI+mWN8cpv2P2IvQiovjgljo1mEQWYLKy9Z8Wc2yjWPtoJF+WbDzthM0AGCEEpFkQVuvv3X+LSjlVL067RaEx/HQRFZiiDIHMRomoyOiD1Ty8GIV+fmlAC0DKGnDtIdbXE8wQYT6fd5cy2gcPUqKsHtd4iEOe8TTiwr8iFdL6vy0VsZW5iYpw7uzX0Bw+rHl6U5nb3GaKQGV52GgPQm1uhfwtkQlG0l6GlJNArblAD9UKvqFRWwE7JdjXyOkoU4mjCDKERc+ATROdevvjBDgwStwrxNpXOhRyHtyjilbI2C/4WrI=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello,
I believe I have found an error, and a fix, but have not tracked down
the cause; at current git HEAD a small factorization fails at the end
of polyselect:
Info:Polynomial Selection (root optimized): Best polynomial from file
/tmp/tmp.3RjdG9A9eW/c60.upload/c60.polyselect2.0j4j51j4.opt_6 with
E=7.260e-06 is no better than current best with E=7.549e-06
E=7.392e-06 is no better than current best with E=7.549e-06
Info:Polynomial Selection (root optimized): Marking workunit
c60_polyselect2_6 as ok (100.0% => ETA Wed Sep 11 01:11:14 2019)
Info:Polynomial Selection (root optimized): Kept 9 polynomials with
MurphyE from 7.549e-06 to 6.090e-06
Traceback (most recent call last):
File "./installed/bin/cado-nfs.py", line 122, in <module>
factors = factorjob.run()
File
"/tmp/tmp.pKm0Y1lRix/cado-nfs/installed/lib/cado-nfs-3.0.0/scripts/cadofactor/cadotask.py",
line 5885, in run
last_status, last_task = self.run_next_task()
File
line 5977, in run_next_task
return [task.run(), task.title]
File
line 2300, in run
**self.progparams[0])
File
"/tmp/tmp.pKm0Y1lRix/cado-nfs/installed/lib/cado-nfs-3.0.0/scripts/cadofactor/cadoprograms.py",
line 708, in __init__
super().__init__(locals(), **kwargs)
File
line 416, in __init__
raise Exception("Binary executable file %s not found (did you run
\"make\" ?)" % execfile)
Exception: Binary executable file
/tmp/tmp.pKm0Y1lRix/cado-nfs/installed/lib/cado-nfs-3.0.0/polyselect3
not found (did you run "make" ?)
build/omega/polyselect/polyselect3 exists:
1] cado-nfs $ stat build/omega/polyselect/polyselect3
File: build/omega/polyselect/polyselect3
Size: 2428656 Blocks: 4744 IO Block: 4096 regular file
Device: fd00h/64768d Inode: 174601 Links: 1
Access: (0755/-rwxr-xr-x) Uid: ( 1000/ jasonp) Gid: ( 1000/ jasonp)
Access: 2019-09-11 01:07:26.655038200 -0400
Modify: 2019-09-11 01:04:50.221534631 -0400
Change: 2019-09-11 01:04:50.221534631 -0400
Birth: -
Copying it to the right place in the installation makes the
factorization complete successfully:
130] cado-nfs $ cp build/omega/polyselect/polyselect3
My environment was made by building GMP-6.1.2:
./configure --prefix=/tmp/tmp.pKm0Y1lRix/gmp-6.1.2/inst; make install
and then CADO-NFS:
make install GMP=${PWD}/../gmp-6.1.2/inst -j64
For now I can simply alter my Dockerfile to install polyselect3 into
the correct location, but I'm not familiar enough with the CADO-NFS
build setup to actually fix the problem.
Apologies if this is a known issue, I looked at the list archives first.
jason
My new phone number: +1 4127218459
