- From: Saeid ZafarVahedian <zafarvahedian@gmail.com>
- To: paul zimmermann <Paul.Zimmermann@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Distributed Cado-nfs
- Date: Mon, 30 Sep 2019 11:36:39 +0330
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=zafarvahedian@gmail.com; spf=Pass smtp.mailfrom=zafarvahedian@gmail.com; spf=None smtp.helo=postmaster@mail-qk1-f182.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul,
Thanks for your answer.
I want to tuning bandwidth parameters and traffic controlling between tow or more nodes on the network.
If possible, please guide me so I can do it.
Thanks a lot,
Best regards,
Saeid.
On Mon, Sep 30, 2019 at 11:15 AM paul zimmermann <Paul.Zimmermann@inria.fr> wrote:
Dear Saeid,
I'm not sure to understand your question, if any.
Cado-nfs already uses distributed programming,
and everything is publicly available.
You can start with the README file.
Best regards,
Paul Zimmermann
> Date: Sun, 29 Sep 2019 16:36:37 +0330
> [1:multipart/alternative Hide]
> [1/1:text/plain Show]
> [1/2:text/html Hide Save:noname (2kB)]
> Hi Dears,
> I became very happy when I found you and your programs in the field of
> parallel processing.
> One field of my interests is Distributed Parallel Programming . I want to
> compare speed up of your code on two CPU base computers with two GPU base
> computers.
> There for, please let me to have your distributed version of your code for
> CPU base Computers.That is very nice for me to use your code in my project.
> I graduated with Master degree. in Computer Science.
> This is my paper link:
> [PDF] GPU-acceleration of parallel unconditionally stable group explicit
> finite difference method - Semantic Scholar
> Thanks a lot,
> Best regards,
> Saeid.
> [2:text/plain Hide]
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] Distributed Cado-nfs, Saeid ZafarVahedian, 09/29/2019
- Re: [Cado-nfs-discuss] Distributed Cado-nfs, paul zimmermann, 09/30/2019
- Re: [Cado-nfs-discuss] Distributed Cado-nfs, Saeid ZafarVahedian, 09/30/2019
