- To: David Willmore <davidwillmore@gmail.com>
- Cc: Cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Help starting out using two machines
- Date: Mon, 9 Mar 2020 09:42:05 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
On Sun, Mar 08, 2020 at 08:46:11PM -0400, David Willmore wrote:
> When built from git and run on the example from the make file, I run
> into a problem:
> [willmore@blade1 cado-nfs]$ ./cado-nfs.py
> 90377629292003121684002147101760858109247336549001090677693
> Info:HTTP server: serving at https://blade1:38715 (0.0.0.0)
> And there it sits. Nothing is running. There are ten instances of
> cado_nfs_client.py on the machine in a sleep state--clearly waiting
> for something on their network sockets. Hmm, okay, it's not using port
> 8001 for some reason. I wonder if the firewall is that strict. .....
> Yes, yes it is. It's blocking the seemingly random port that the
> script now picks. Updating the firewall after the script runs isn't
> enough. Is there a way to tell the script to stop picking random
> ports?
./cado-nfs.py 90377629292003121684002147101760858109247336549001090677693
server.port=8001
And then if you want to take care of running the clients by yourself, run
the server with
server.port=8001 --server
As per ./scripts/cadofactor/README.md , if you supply a parameter file,
there's no default behaviour that starts clients. E.g. this is equivalent
to the former:
server.port=8001 ./parameters/factor/params.c60
Best,
E.
- [Cado-nfs-discuss] Help starting out using two machines, David Willmore, 03/05/2020
- Re: [Cado-nfs-discuss] Help starting out using two machines, Emmanuel Thomé, 03/06/2020
- Re: [Cado-nfs-discuss] Help starting out using two machines, David Willmore, 03/07/2020
- Re: [Cado-nfs-discuss] Help starting out using two machines, Emmanuel Thomé, 03/07/2020
- Re: [Cado-nfs-discuss] Help starting out using two machines, David Willmore, 03/09/2020
- Re: [Cado-nfs-discuss] Help starting out using two machines, Emmanuel Thomé, 03/09/2020
- Re: [Cado-nfs-discuss] Help starting out using two machines, Paul Leyland, 03/10/2020
- Re: [Cado-nfs-discuss] Help starting out using two machines, Emmanuel Thomé, 03/10/2020
