cado-nfs - Re: [Cado-nfs-discuss] Starting Point in Sieving
  • To: Elena Wilson <elena225318@gmail.com>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Starting Point in Sieving
  • Date: Thu, 09 Jul 2020 14:04:54 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Elena,
> Why did not the qmin parameter set to a much smaller value in all parameters
> files?
> It is true that sieving in these intervals takes a longer time but on the
> other hand, it will find much more relations. Is this statement true that
> the
> found relations in the regions around 0 will be removed in the filtering?
when you decrease qmin, you get more duplicate relations. In previous versions
of cado-nfs, we started at qmin = lim1, where lim1 is the algebraic factor
base bound. Now we start at qmin = lim1/2, which seems better, but might not
be optimal. Please tell us if you find some better value of qmin for some
params.cxxx file.
> One more question, In params.c120, it is mentioned that the BWC is about
> WN+CN^2 where W is weight, N is size of matrix and C is a constant 17.2 It
> seems this relation is a very helpful for finding the best values of
> max_level merging and target_density to have a good tradeoff between W and
> N.
> The question is whether C is 17.2 for all numbers? If not, how can I
> calculate it for other numbers such as RSA-512bit?
This "constant" is maybe valid for a fixed size (and for a given machine),
but I'm not sure you can use it for other sizes. For example, for RSA-250
we did three filtering tries, with target densities 200, 225 and 250:
N W WN CN^2 WN+CN^2
200 435137414 87535677490 3.81e19 3.26e18 4.13e19
225 418993015 94485091257 3.96e19 3.02e18 4.26e19
250 404711409 101961355931 4.13e19 2.82e18 4.41e19
In the end, after some initial testing with bwc (after a few minutes or hours
you can get a precise idea of the total bwc time, extrapolating from the bwc
output), we decided to use the "250" matrix. This would mean C > 142.
In conclusion, the best method is to launch bwc.pl, and to extrapolate the
total time after a few iterations.
Best regards,
Paul
