- To: Bernardo Boncompagni <bernardo.boncompagni@gmail.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Bug report
- Date: Sat, 22 Aug 2020 19:41:25 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
This should be fixed now.
https://gitlab.inria.fr/cado-nfs/cado-nfs/-/issues/30003
please tell us if you encounter other issues.
E.
On Fri, Aug 21, 2020 at 05:45:12PM +0200, Emmanuel Thomé wrote:
> ok thanks. At this point we have enough data to reproduce the problem and
> hopefully fix it quickly. I'll get back to you soon.
> E.
> On Fri, Aug 21, 2020 at 05:18:18PM +0200, Bernardo Boncompagni wrote:
> > I am perfectly fine with the gitlab thing. I tried to accept your
> > invitation, but the system literally says "To accept this invitation, sign
> > in." I thought being able to sign in was the reason I was invited in the
> > first place and the input file is 120+ MB, so I'm stuck for the moment.
> > Maybe someone needs to manually create my account first? Anyway, for the
> > moment you can download the files cited in the error line (dup1, renumber,
> > stdout and stderr) at http://redgolpe.com/cado.zip . Please let me know if
> > I can be of further help, and feel free to send me further instructions to
> > reach GitLab if that's of any use.
> > On Fri, Aug 21, 2020 at 3:55 PM Emmanuel Thomé <Emmanuel.Thome@inria.fr>
> > wrote:
> > > Hi,
> > > Thanks for your report.
> > > There are indeed recent changes in cado-nfs that could be related to the
> > > difficulties that you encounter.
> > > However, I can't find the error stack trace in your log file:
> > > > When they failed, all tests did with the same "corrupted table" error,
> > > see
> > > > attached log (c105.log.zip).
> > > I do see that the dup2 program crashed, but no such thing as an
> > > informative stack trace.
> > > In order to best diagnose your problem, the files that are most relevant
> > > are the input and output files of the following command.
> > > PID28397 2020-08-21 14:54:14,619 Error:Filtering - Duplicate Removal,
> > > removal pass: Command line was:
> > > /home/redgolpe/cado-nfs/build/c2018/filter/dup2 -poly nfsdata/c105.poly
> > > -nrels 2300838 -renumber nfsdata/c105.renumber.gz -t 12
> > > nfsdata/c105.dup1//0/dup1.0.0000.gz > nfsdata/c105.dup2.slice0.stdout.1
> > > 2>
> > > nfsdata/c105.dup2.slice0.stderr.1
> > > Could you please send us these files ? It would be best if you could
> > > post
> > > them in the gitlab issue there:
> > > but you might be blocked (not sure) by a counter-intuitive thing that
> > > requires you to request sponsorship for an account (which we're happy to
> > > do, but OTOH I fully inderstand if you don't want to go through this
> > > maze
> > > of weird things). Data files by e-mail or from an URL is also fine, if
> > > you don't want to bother.
> > > Best,
> > > E.
> > > On Fri, Aug 21, 2020 at 03:41:07PM +0200, Bernardo Boncompagni wrote:
> > > > Hi all,
> > > > within the scope of the aliquot sequence project at mersenneforum.org
> > > > I
> > > > have been running several factorizations in the past few weeks with
> > > > CADO-NFS and everything went smoothly until I encountered a bug
> > > preventing
> > > > a factorization to complete. I first encountered it on a C114 and
> > > > then on
> > > > the C107
> > > 54022122323205311359700529131254845253584832080092810873601245077747279904751944559089001546838958178759103
> > > > = 6892192422790360694669529583587636497846216763819494386433 *
> > > > 7838162228984026472885414974266767581580262988991
> > > > So i ran some tests on two machines with the following specifications:
> > > > - "EC2": an Amazon EC2 instance with 3.3 GHz AMD EPYC processors, 4
> > > cores,
> > > > 8 threads, 16 GiB RAM, Ubuntu 18.04 fully updated
> > > > - "WSL": a Windows 10 PC with Intel Core i7-7800X processors, 6
> > > > cores, 12
> > > > threads, 32 GiB RAM, WSL Ubuntu 18.04 fully updated
> > > > All versions of CADO-NFS were installed with git clone
> > > > https://gitlab.inria.fr/cado-nfs/cado-nfs.git.
> > > > All tests were run with the default command line cado-nfs.py <N>
> > > > workdir=<workdir> unless specified.
> > > see
> > > > When failed, the error seems reproducible with the same command line
> > > > on
> > > the
> > > > same machine.
> > > > Test results follow.
> > > > *Failed* on EC2, CADO-NFS with timestamp July 22 (two runs).
> > > > *Failed* on EC2, CADO-NFS with timestamp August 18.
> > > > *Failed* on EC2, CADO-NFS with timestamp August 18, parameters -t 6.
> > > > *Passed* on WSL, CADO-NFS with timestamp March 17.
> > > > *Failed* on WSL, CADO-NFS with timestamp August 18.
> > > > *Failed* on WSL, CADO-NFS with timestamp August 18, parameters -t 8.
> > > > So it looks like whatever it is, it does not depend on the processor
> > > type,
> > > > on the number of cores and on the actual cores used, and was
> > > > introduced
> > > > some time between March 17 and July 22.
> > > > I also attach the requested make cmake output (cmake.log.zip) and gcc
> > > > -v
> > > > (gcc.log.zip) for the WSL machine. Let me know if you also need those
> > > > of
> > > > EC2.
> > > > Thank you for your time.
> > > > _______________________________________________
> > > > Cado-nfs-discuss mailing list
> > > > Cado-nfs-discuss@lists.gforge.inria.fr
> > > > https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] Bug report, Bernardo Boncompagni, 08/21/2020
- Re: [Cado-nfs-discuss] Bug report, Emmanuel Thomé, 08/21/2020
- Re: [Cado-nfs-discuss] Bug report, Bernardo Boncompagni, 08/21/2020
- Re: [Cado-nfs-discuss] Bug report, Emmanuel Thomé, 08/22/2020
- Re: [Cado-nfs-discuss] Bug report, Bernardo Boncompagni, 08/22/2020
