cado-nfs - [Cado-nfs-discuss] More of the Same Error -6 Trouble
  • To: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
  • Subject: [Cado-nfs-discuss] More of the Same Error -6 Trouble
  • Date: Thu, 27 Aug 2020 01:34:41 +0000 (UTC)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=ed_ka2fwj@yahoo.com; spf=Pass smtp.mailfrom=ed_ka2fwj@yahoo.com; spf=None smtp.helo=postmaster@sonic310-15.consmr.mail.bf2.yahoo.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello Team,
I have the latest commit running on all my machines and all looked good, but I have experienced the Error -6 trouble again.  This time I have kept the entire working directory and am attempting to attach the files I "think" you wanted before.  Forgive me if I have the wrong ones. Let me know which else you may require.
The terminal output was:
Warning:Command: Process with PID 7229 finished with return code -6
Error:Filtering - Duplicate Removal, removal pass: Program run on server failed with exit code -6
Error:Filtering - Duplicate Removal, removal pass: Command line was: /home/math99/Math/cado-nfs/build/math99/filter/dup2 -poly /home/math99/Math/GamAli/alicado/alicado.poly -nrels 75014423 -renumber /home/math99/Math/GamAli/alicado/alicado.renumber.gz -t 24 /home/math99/Math/GamAli/alicado/alicado.dup1//0/dup1.0.0001.gz /home/math99/Math/GamAli/alicado/alicado.dup1//0/dup1.0.0000.gz /home/math99/Math/GamAli/alicado/alicado.dup1//0/dup1.0.0002.gz > /home/math99/Math/GamAli/alicado/alicado.dup2.slice0.stdout.1 2> /home/math99/Math/GamAli/alicado/alicado.dup2.slice0.stderr.1
Error:Filtering - Duplicate Removal, removal pass: Stderr output (last 10 lines only) follow (stored in file /home/math99/Math/GamAli/alicado/alicado.dup2.slice0.stderr.1):
Error:Filtering - Duplicate Removal, removal pass:     Allocated hash table of 90017413 entries (343Mb)
Error:Filtering - Duplicate Removal, removal pass:     Constructing the two filelists...
Error:Filtering - Duplicate Removal, removal pass:     3 files (3 new and 0 already renumbered)
Error:Filtering - Duplicate Removal, removal pass:     Reading files already renumbered:
Error:Filtering - Duplicate Removal, removal pass:     Reading new files (using 24 auxiliary threads for roots mod p):
Error:Filtering - Duplicate Removal, removal pass:     terminate called recursively
Error:Filtering - Duplicate Removal, removal pass:     terminate called after throwing an instance of 'terminate called recursively
Traceback (most recent call last):
  File "./cado-nfs.py", line 122, in <module>
    factors = factorjob.run()
  File "./scripts/cadofactor/cadotask.py", line 5957, in run
    last_status, last_task = self.run_next_task()
  File "./scripts/cadofactor/cadotask.py", line 6049, in run_next_task
    return [task.run(), task.title]
  File "./scripts/cadofactor/cadotask.py", line 3758, in run
    raise Exception("Program failed")
Exception: Program failed
Thank you for any help and all the work.
Sincerely,
Edwin Hall
Attachment: cado-nfsError-6.tar.gz
Description: application/gzip
  • [Cado-nfs-discuss] More of the Same Error -6 Trouble, Ed Hall, 08/27/2020
