- To: Robert Balfour <rhb11931@gmail.com>
- Cc: Paul Zimmermann <Paul.Zimmermann@inria.fr>, cado-nfs@inria.fr
- Subject: Re: [cado-nfs] dup1 bug when processing over 2^26 relations
- Date: Thu, 5 Aug 2021 17:27:31 +0200
- Ironport-hdrordr: A9a23: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
Hi Robert,
I've pushed a fix (commit e140378940c). Can you give it a try ?
Regards,
Pierrick
On Thu, Aug 05, 2021 at 02:01:18PM +0100, Robert Balfour wrote:
> Dear Paul et al,
> Any progress on finding the source of this bug?
> Best regards,
> Robert
> On Mon, Jul 26, 2021 at 3:32 PM Paul Zimmermann <Paul.Zimmermann@inria.fr>
> wrote:
> > Hi,
> > I am able to reproduce the issue. It seems to happen since the following
> > commit:
> > commit c3079ff3ce67dd801915dbd335b210e8570bea68
> > Author: Emmanuel Thomé <Emmanuel.Thome@inria.fr>
> > Date: Sat Apr 3 15:58:22 2021 +0200
> > fopen_maybe_compressed: always use a temp file when writing
> > Emmanuel, do you have any clue?
> > Paul
> > > From: Robert Balfour <rhb11931@gmail.com>
> > > Date: Mon, 26 Jul 2021 03:06:11 +0100
> > > [1:multipart/alternative Hide]
> > > [1/1:text/plain Show]
> > > [1/2:text/html Hide Save:noname (3kB)]
> > > Dear all,
> > > In recent revisions of CADO (revision 4ef6307d and the latest revision)
> > I am
> > > seeing a bug, on at least some numbers, when dup1 tries to process more
> > than
> > > 2^26 = 67108864 relations. dup1.stdout.1 ends abruptly with
> > > # Read 67108864 relations in 135.7s -- 62.5 MB/s -- 494715.5 rels/s
> > > while dup1.stderr.1 ends with the following:
> > > code BUG() : condition rc == 0 failed in split_iter_open_next_file at
> > > /store/charybdis/cado_4ef6307d/cado-nfs/filter/dup1.c:111 -- Abort
> > > I tried altering the contents of dup1.filelist.1 and found that the bug
> > > appears precisely when the files contain more than 2^26 relations. So
> > that
> > > you can attempt to reproduce this, I have attached a parameter file that
> > > produces the bug when run with the 149-digit number
> > > N =
> > 30451074702779672217829979074588808155199316436755065947683534426904549869449262327316787277317820182752090699957549708141192736670950500076802512839
> > > I have also heard from another user who has experienced the same bug
> > > with
> > > revision 90dd8db3.
> > > Best regards,
> > > Robert Balfour
> > > [2:application/octet-stream Show Save:c150.params (2kB)]
- Re: [cado-nfs] dup1 bug when processing over 2^26 relations, Robert Balfour, 08/05/2021
- Re: [cado-nfs] dup1 bug when processing over 2^26 relations, Pierrick Gaudry, 08/05/2021
