- To: Paul Zimmermann <Paul.Zimmermann@inria.fr>
- Cc: cado-nfs@inria.fr
- Subject: Re: [cado-nfs] Same polynomial being found hundreds of times
- Date: Fri, 10 Sep 2021 17:49:50 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=rhb11931@gmail.com; spf=Pass smtp.mailfrom=rhb11931@gmail.com; spf=None smtp.helo=postmaster@mail-yb1-f181.google.com
- Ironport-hdrordr: A9a23:+KDek6EE9fmE+TOSpLqE3ceALOsnbusQ8zAXPiFKJyC9F/bzqynAppsmPGDP+VAssR0b6LW90YO7MAvhHOdOkPAs1NSZPTUO2lHFEGgK1+KL/9SHIU3DH4VmpMRdmsZFZeEZ8jBB/KTHCQODYrEdKYm8m5xBLI/lvhNQcT0=
- Ironport-phdr: A9a23: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
Dear Paul,
Yes, looks like it's fixed now. Thank you!
Best regards,
Robert
On Thu, Sep 9, 2021 at 1:44 PM Paul Zimmermann <Paul.Zimmermann@inria.fr> wrote:
Dear Robert,
thank you for the bug report. This was a nice bug (see the commit log).
Fixed in commit 271ad1f. Please can you confirm?
It could happen with degree 5 too, as long as you use a large value of nq.
Best regards,
Paul
> From: Robert Balfour <rhb11931@gmail.com>
> Date: Wed, 25 Aug 2021 15:34:27 +0100
> [1:text/plain Show]
> [2:text/html Hide Save:noname (6kB)]
> Dear all,
> While running polynomial selection on a 220-digit composite, I've noticed
> that polyselect will very occasionally find the same polynomial hundreds of
> times. The number of times the polynomial appears is always a number of the
> form 2 mod 14, most commonly 268, though perhaps this is an artefact of the
> parameters I used. I imagine this could be problematic if the polynomial in
> question was high-scoring, as copies of it might take up a large part of the
> priority queue.
> The issue may be related to the use of degree 6, as I've run many degree 5
> searches and have never seen this happen before.
> An example command is
> polyselect -P 12000000 -N
> 5272066026958413205513021090082556639441277154855572268239336980532402881465013381219738819137405617219594641652778228990107677072837959240400905630530715435664638237254654768053674178165309345879869729405448588458952991
> -degree 6 -t 2 -admin 15748320 -admax 15751680 -incr 420 -nq 46656
> -sopteffort 10
> which produces 282 copies of the polynomial
> # Raw polynomial:
> # n:
> # Y1: 596510255164295958340450487
> # Y0: -263512688394977973691376832079085729
> # c6: 15748320
> # c5: 13551643
> # c4: -218061793231947823187578164
> # c3: 96330167362975118135560741138283790
> # c2: -24487764364517858671372756757420673
> # c1: -120000488463888088109792094537878702
> # c0: -10924560535761233666606096354806377
> # raw exp_E 75.68, lognorm 77.22, skew 2.03, 6 rroots
> n:
> Y0: -262594493282429186537214460134357343
> c6: 182916736800
> c5: 1689358410130515845
> c4: 1316019719459862805924492
> c3: -169471667881071512508976351466
> c2: -31518096396680244263016200886784920
> c1: 1010006169143670592909109654997712502443
> c0: 42583239321072135934692647075740426314870055
> # exp_E 56.48, lognorm 64.31, skew 145018.07, 6 rroots
> Best regards,
> Robert Balfour
- Re: [cado-nfs] Same polynomial being found hundreds of times, Paul Zimmermann, 09/09/2021
- Re: [cado-nfs] Same polynomial being found hundreds of times, Robert Balfour, 09/10/2021
