- To: "cado-nfs@inria.fr" <cado-nfs@inria.fr>
- Subject: [cado-nfs] Linalg program crashing
- Date: Fri, 12 Nov 2021 00:50:54 +0000 (UTC)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=rjd1212@yahoo.com; spf=Pass smtp.mailfrom=rjd1212@yahoo.com; spf=None smtp.helo=postmaster@sonic309-15.consmr.mail.bf2.yahoo.com
- Ironport-data: A9a23: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
- Ironport-hdrordr: A9a23:tQmxFKiDQ7UOIuMSkY/ZTYOW3XBQXgkji2hC6mlwRA09T+WzkceykPMHkTr5jzgNWRgb6Km90ci7MBfhHPtOirX5Uo3NYOCLggqVxeJZnO7fKl/bak7DH4dmvM8OT0E9MqyWMbEQt7eZ3ODXKbYdKaG8gcaVrNab9VFLbSsvRoNBy0NCKii9e3cdeCB2QaA+E5qXou5pzgDNRZxCBv7XOkU4
- Ironport-phdr: A9a23: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
In several instances in running the latest version of CADO-NFS, I've been encountering a consistent program crash at the completion of Krylov. This occurs on both Intel & AMD threadripper platforms. The factor I'm running is C180. Any number less than that, e.g. C170, C160, C150.....etc, always factors to completion, but not C180. (and possibly larger) Any suggestions on why this is happening? Currently I'm running Fedora 35 with GCC ver 11.2.1-1
Regards,
Robert J Duchateau
linalg C180
Description: Binary data
- [cado-nfs] Linalg program crashing, Robert Duchateau, 11/12/2021
- Re: [cado-nfs] Linalg program crashing, Emmanuel Thomé, 11/12/2021
