- To: Robert Duchateau <rjd1212@yahoo.com>
- Cc: "cado-nfs@inria.fr" <cado-nfs@inria.fr>
- Subject: Re: [cado-nfs] Linalg bug has resurfaced.
- Date: Mon, 29 Nov 2021 09:03:29 -0800
- Ironport-data: A9a23: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
- Ironport-hdrordr: A9a23:yjNMUauKhze6AwD1AgFdnIBI7skDeNV00zEX/kB9WHVpmwKj9vxG/c5rsiMc7Qx9ZJhOo7y90cW7L080lqQFhbX5X43SPzUO0VHAROpfBODZowEIdReQygb0uJ0LT0EHMqyUMbEAt7eZ3DWF
Hi,
Thanks for your feedback.
What is the output of
ls -lR /opt/c180.bwc
Apparently, the linear generator program has failed, and the likely cause
is that some of the output files of the earlier step are corrupt.
Depending on what there is in the directory, you may be able to run
some of the offline checking tools in cado-nfs, to determine what part of
the computation needs to be redone. I'll guide you through that.
E.
On Mon, Nov 29, 2021 at 03:05:12PM +0000, Robert Duchateau wrote:
> To Emmanuel Thome.
> I recently tried to factor C180 on an AMD 24 core, threadripper - the same
> C180 as I previously did on my Intel 18 core, server, which thanks to your
> help, successfully fixed the Linalg memory issue around 2 weeks ago.
> Unfortunately, I now have a somewhat similar issue with my other server,
> specifically the lingen phase. In this case, the F vector files are somehow
> missing, thus crashing the remainder of the post-processing, e.g. mysol,
> sqr root phase.
> While I have tried numerous workarounds, such as running directly the
> lingen program & even the mysol routine, I always get the same crash
> errors. Any suggestions for a fix would be much appreciated.
> Best regards,
> Robert Duchateau
- [cado-nfs] Linalg bug has resurfaced., Robert Duchateau, 11/29/2021
- Re: [cado-nfs] Linalg bug has resurfaced., Emmanuel Thomé, 11/29/2021
