- To: Ross Atkins <rosstherock@gmail.com>
- Cc: cado-nfs@inria.fr
- Subject: Re: [cado-nfs] factorizing a 177-digit number
- Date: Tue, 01 Feb 2022 09:14:07 +0100
Dear Ross,
> From: Ross Atkins <rosstherock@gmail.com>
> Date: Tue, 1 Feb 2022 20:44:24 +1300
> Thanks Paul,
> I have attached the log file, (sorry it is so large). The
> scripts/cadofactor/README.md file was very helpful, I have
> c175.log
> found the polynomial file (c175.poly) but I don't know which file is my
> relations file. The readme says:
> If you want to import already computed relations, use:
> tasks.sieve.import=foo
> where `foo` is the name of the relation file to be imported (in CADO-NFS
> format).
> Is it possible that the file called "c175.purged.gz" or "c175.freerel.gz" is
> my relations file?
the relations are in the c175.upload directory. They are in the files
c175.xxx.gz. You can do:
$ ls DIR/c175*gz > foo
then you can use the file 'foo' in tasks.sieve.import=foo.
Make sure the path of the relation files is absolute in 'foo'.
Best regards,
Paul
- Re: [cado-nfs] factorizing a 177-digit number, Ross Atkins, 02/01/2022
- Re: [cado-nfs] factorizing a 177-digit number, Paul Zimmermann, 02/01/2022
- Re: [cado-nfs] factorizing a 177-digit number, Ross Atkins, 02/02/2022
- Re: [cado-nfs] factorizing a 177-digit number, Emmanuel Thomé, 02/02/2022
- <Possible follow-up(s)>
