cado-nfs - Re: [cado-nfs] Some Problems with cado-nfs-3.0.0
  • To: lunaluan9555 <lunaluan9555@gmail.com>
  • Cc: Emmanuel.Thome@inria.fr, cado-nfs@inria.fr
  • Subject: Re: [cado-nfs] Some Problems with cado-nfs-3.0.0
  • Date: Tue, 12 Apr 2022 18:54:26 +0200
  • Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@tomate
Hi,
> Can you confirm that this is what you observe? If yes, I would need some
> more diagnostics from config/gmpecm.cmake ; I want to make sure that it
> correctly computes the test C code in the end, and correctly sets the
> HAVE_GMPECM variable.
please send us the file build/<your_machine_name>/CMakeFiles/CMakeOutput.log.
It contains log information about compiling the test C code with GMP-ECM.
Paul Zimmermann
