cado-nfs - Re: [cado-nfs] A couple of bugs (sopt + lingen)
  • To: cado-nfs@inria.fr
  • Subject: Re: [cado-nfs] A couple of bugs (sopt + lingen)
  • Date: Tue, 30 Aug 2022 18:21:49 +0200
  • Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Emmanuel.Thome@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
Hi,
Thanks for your feedback.
On Mon, Aug 15, 2022 at 12:44:43AM +0100, Robert Balfour wrote:
> Dear all,
> I have two potential bugs to report.
> Bug 1: as of the latest revision of CADO, running "sopt" on a file of
> polynomials will run size-optimization repeatedly on the first polynomial
> in the file, instead of progressing through the file. This bug was
> introduced at some point since last November.
Ooops. I filed it as
https://gitlab.inria.fr/cado-nfs/cado-nfs/-/issues/30046 (which is now
fixed). This kind of bug should never have been let through with proper
testing, but as it turns out sopt had no testing...
> Bug 2: running the latest revision on RSA-100 with the default parameters
> (and -t 2, not sure if that is important) results in a crash at the end of
> lingen. This crash doesn't seem to occur on every number or matrix. The
> command line used was
This one sounds really annoying.
It might be related to #30041, but it's really just a random guess.
Could you please post the c100.sparse.bin file somewhere where I can
download it? Our tests here didn't yield a reproducer.
> The first obvious sign that something has gone wrong is the line
> Number of lucky columns: 0 (64 wanted)
> near the end of c100.bwc.stdout.1.
Yes indeed. This should really not happen, and the fact that the rest
crashes is just a consequence.
Best,
E.
> ./cado-nfs.py
> 1522605027922533360535618378132637429718068114961380688657908494580122963258952897654000350692006139
> workdir=/store/charybdis/cadojobs/tests/c100test_3ab6a478_tryagain -t 2
> This then produces
> ## [01;31mCheck for mksol [0m: Lingen output files missing
> ## [01;31mCheck for mksol [0m: can't find any F file, cannot infer the
> mksol max iteration at
> /store/charybdis/cado_3ab6a478/cado-nfs/build/tantalum/linalg/bwc/bwc.pl
> line 1499.
> ## [01;31mCheck for mksol [0m: Please run lingen first.
> in c100.bwc.stderr.1, at which point CADO quits.
> Strangely enough, if CADO is resumed then it finds the 64 lucky columns
> it needs and the factorization completes successfully.
> The relevant log files are attached: stdout.1 and stderr.1 are from the
> original run that crashed, stdout.2 and stderr.2 are from the resumption.
> Best regards,
> Robert
