cado-nfs - Re: [cado-nfs] compile cado on a cluster
  • To: Barbulescu Razvan <razvan.barbulescu@u-bordeaux.fr>
  • Cc: cado-nfs@inria.fr
  • Subject: Re: [cado-nfs] compile cado on a cluster
  • Date: Tue, 07 Feb 2023 16:16:01 +0100
  • Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@coriandre
Dear Razvan,
> Date: Tue, 7 Feb 2023 16:07:16 +0100
> From: Barbulescu Razvan <razvan.barbulescu@u-bordeaux.fr>
> I want to use cado on a small cluster called plafrim (in Bordeaux). In
> order to use binaries like cmake, gcc and  gmp I have to load the
> modules like "module load build/cmake/3.15.3"
which version of cado-nfs are you trying to compile?
> Do I have to load a specific module for g++ ? I don't see any such
> module on my cluster. Or maybe it is included in gcc.
try g++ -v to see if g++ is available.
> How do I know that I have all the prerequisites ?
don't worry, "make" will fail if you don't have them all!
Best regards,
Paul
> Please find the output of make in "cado-bug" and the modules list in
> "modules".
> cheers,
> Razvan
> [2:text/plain Show Save:cado-bug.txt (2kB)]
> [3:text/plain Show Save:modules.txt (6kB)]
