Re: [cado-nfs] Supplement to the discrete logarithm problem for quadratic-extended feild
- To: ???? <1092016692@qq.com>
- Cc: cado-nfs@inria.fr
- Subject: Re: [cado-nfs] Supplement to the discrete logarithm problem for quadratic-extended feild
- Date: Wed, 16 Aug 2023 08:51:00 +0200
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@coriandre
Hi,
I cannot reproduce, I get with revision 9d69b04:
zimmerma@coriandre:~/svn/cado-nfs$ ./cado-nfs.py
191907783019725260605646959711 -dlp -ell 101538509534246169632617439 -gfpext 2
Info:Complete Factorization / Discrete logarithm: The polynomial defining the
finite field is 1,-61096303626605014149726703721,1
Please can you give us more details (version of CADO-NFS used, hardware,
operating system, compiler)?
Best regards,
Paul Zimmermann
> From: "????" <1092016692@qq.com>
> Date: Wed, 16 Aug 2023 14:25:52 +0800
> [1:text/plain Show]
> [2:text/html Hide Save:noname (2kB)]
> Dear professor:
> When i run ./cado-nfs.py 191907783019725260605646959711 -dlp -ell
> Info:Logarithms Reconstruction: Starting
> Warning:Command: Process with PID 6024 finished with return code 1
> Error:Logarithms Reconstruction: Program run on server failed with exit code
> 1
> Error:Logarithms Reconstruction: Command line was:
> /home/zp/Math/cado-nfs/build/zp-virtual-machine/filter/reconstructlog-dl
> -ell 101538509534246169632617439 -mt 4 -log
> /tmp/cado.9xqoti1e/p2dd30.bwc/K.sols0-1.0.txt -out
> /tmp/cado.9xqoti1e/p2dd30.dlog -renumber
> /tmp/cado.9xqoti1e/p2dd30.renumber.gz -poly /tmp/cado.9xqoti1e/p2dd30.poly
> -purged /tmp/cado.9xqoti1e/p2dd30.purged.gz -ideals
> /tmp/cado.9xqoti1e/p2dd30.ideal -relsdel
> /tmp/cado.9xqoti1e/p2dd30.relsdel.gz -nrels 37379 -nsms '1,0' >
> /tmp/cado.9xqoti1e/p2dd30.reconstructlog-dl.stdout.1 2>
> /tmp/cado.9xqoti1e/p2dd30.reconstructlog-dl.stderr.1
> Error:Logarithms Reconstruction: Stderr output (last 10 lines only) follow
> (stored in file /tmp/cado.9xqoti1e/p2dd30.reconstructlog-dl.stderr.1):
> Error:Logarithms Reconstruction: antebuffer set to
> /home/zp/Math/cado-nfs/build/zp-virtual-machine/utils/antebuffer
> Error:Logarithms Reconstruction: Error, no unknown log in rel 16311 and sum
> of log is not zero, sum is: 58912568217527066963920738
> Looking forward to hearing from you.
- [cado-nfs] Supplement to the discrete logarithm problem for quadratic-extended feild, ????, 08/14/2023
- <Possible follow-up(s)>
- [cado-nfs] Supplement to the discrete logarithm problem for quadratic-extended feild, ????, 08/15/2023
- [cado-nfs] Supplement to the discrete logarithm problem for quadratic-extended feild, ????, 08/16/2023
- Re: [cado-nfs] Supplement to the discrete logarithm problem for quadratic-extended feild, Paul Zimmermann, 08/16/2023
- Re: [cado-nfs] Supplement to the discrete logarithm problem for quadratic-extended feild, Pierrick Gaudry, 08/21/2023
- [cado-nfs] Supplement to the discrete logarithm problem for quadratic-extended feild, ????, 08/25/2023
- Re: [cado-nfs] Supplement to the discrete logarithm problem for quadratic-extended feild, Pierrick Gaudry, 08/25/2023
