- To: Oliver Kruse <oliver@ouoag.de>
- Cc: cado-nfs@inria.fr
- Subject: Re: [cado-nfs] convert_rels does not build anymore
- Date: Thu, 14 Sep 2023 22:55:46 +0200
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@coriandre
Hi Oliver,
> The target convert_rels does not build on the master branch, currently. I
> tried on current native Debian and Debian WSL2. I will attach the output in
> the end of this mail. Thanks in advance!
I tried to fix a few things, but some C++ remaining errors are out of my
competence.
If you really need this program, my advice is to use a version before commit
a63ecbb, where convert_rels moved to C++.
Best regards,
Paul
- [cado-nfs] convert_rels does not build anymore, Oliver Kruse, 09/11/2023
- Re: [cado-nfs] convert_rels does not build anymore, Paul Zimmermann, 09/14/2023
