cado-nfs - Re: [cado-nfs] ???????????? [cado-nfs] Supplement to the discrete logarithm problem for quadratic-extended feild
  • To: ???? <1092016692@qq.com>
  • Cc: cado-nfs@inria.fr,
  • Subject: Re: [cado-nfs] ???????????? [cado-nfs] Supplement to the discrete logarithm problem for quadratic-extended feild
  • Date: Mon, 09 Oct 2023 10:14:46 +0200
  • Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@coriandre
Hi,
I cannot reproduce what you get:
zimmerma@coriandre:~/svn/cado-nfs$ ./cado-nfs.py
100000000000000000000000000000000000000001087 -dlp -ell
5343950341598815341459838431296083 -gfpext 2
RuntimeError: no parameter file found for p2dd45 (tried p2dd45)
Feel free to submit one!
Best regards,
Paul Zimmermann
> From: "????" <1092016692@qq.com>
> Date: Mon, 9 Oct 2023 15:40:38 +0800
> [1:text/plain Show]
> [2:text/html Hide Save:noname (8kB)]
> ??????: "????" <1092016692@qq.com>;
> ????????: 2023??10??9??(??????) ????3:38
> ??????: "Pierrick Gaudry"<pierrick.gaudry@loria.fr>;
> ????: ?????? [cado-nfs] Supplement to the discrete logarithm problem for
> Dear professor:
> I'm solving the discrete logarithm problem on a quadratic extended field
> with characteristic 45 bits, The parameters of params.p2dd45 I used directly
> from params.p90, the same goes for p2dd45.hint.
> When i run ./cado-nfs.py 100000000000000000000000000000000000000001087 -dlp
> ell 5343950341598815341459838431296083 -gfpext 2.
> ell is a large factor of p+1.
> The following error occurred.
> Is there a problem with the parameters inside? How to adjust lpb, lim, mfb0,
> qrange, rels_wanted and other parameters? What is the meaning of the
> parameters in.hint and how to adjust them?
> Error:Logarithms Reconstruction: Command line was:
> /home/zp/Math/cado-nfs/build/zp-virtual-machine/filter/reconstructlog-dl -
> ell 5343950341598815341459838431296083 -mt 16 -log
> /tmp/cado.it1vr0vl/p2dd45.bwc/K.sols0-1.0.txt -out
> /tmp/cado.it1vr0vl/p2dd45.dlog -renumber
> /tmp/cado.it1vr0vl/p2dd45.renumber.gz -poly /tmp/cado.it1vr0vl/p2dd45.poly -
> purged /tmp/cado.it1vr0vl/p2dd45.purged.gz -ideals
> /tmp/cado.it1vr0vl/p2dd45.ideal -relsdel
> /tmp/cado.it1vr0vl/p2dd45.relsdel.gz -nrels 223778 -nsms '1,0' >
> /tmp/cado.it1vr0vl/p2dd45.reconstructlog-dl.stdout.1 2>
> /tmp/cado.it1vr0vl/p2dd45.reconstructlog-dl.stderr.1
> :Logarithms Reconstruction: Stderr output (last 10 lines only) follow
> (stored in file /tmp/cado.it1vr0vl/p2dd45.reconstructlog-dl.stderr.1):
> Error:Logarithms Reconstruction: antebuffer set to
> /home/zp/Math/cado-nfs/build/zp-virtual-machine/utils/antebuffer
> Error:Logarithms Reconstruction: Warning, log is zero for h = 0
> Error:Logarithms Reconstruction: Warning, log is zero for h = 7
> Error:Logarithms Reconstruction: Warning, log is zero for h = 12
> Error:Logarithms Reconstruction: Warning, log is zero for h = 13
> Error:Logarithms Reconstruction: Warning, log is zero for h = 630
> Error:Logarithms Reconstruction: Warning, log is zero for h = 4125
> Error:Logarithms Reconstruction: Error, no unknown log in rel 84117 and sum
> of log is not zero, sum is: 2556022473720768550782411652675062
