- To: Laël Cellier <lael.cellier@grenoble-inp.org>
- Cc: cado-nfs@inria.fr
- Subject: Re: [cado-nfs] [Cado-nfs-discuss] Using GPU in Sieving Step
- Date: Sun, 10 Mar 2024 08:21:52 +0100
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@coriandre
Hi,
I'm redirecting to the new list.
Do you have a concrete example in cado-nfs where "#pragma omp for simd"
is better than "#pragma omp for" ?
Paul Zimmermann
> Date: Sat, 9 Mar 2024 16:06:29 +0100
> From: Laël Cellier <lael.cellier@grenoble-inp.org>
> Hello,
> in a similar request, why not turn the #pragma omp for
> into
> #prama omp for simd
> where it’s possible ? I’m noticing gcc tends to vectorize nothing…
> Le 20/08/2012 à 9:29 AM, Pierrick Gaudry a écrit :
> > On Tue, Aug 07, 2012 at 11:36:31AM +0430, hamid reza arkian wrote:
> >> Hi,
> >> I tried GMP-ECM project (the branch that is currently under active
> >> development for GPU devices) on a GPU cluster and got good results.
> >> I want to replace ecm part of sieving step in CADO-NFS with GMP-ECM(that
> >> support GPU), but I have the following questions:
> >> - Basically, it's a good idea or not?
> >> - Is the GMP-ECM faster than ecm part of CADO-NFS? and if so, why the
> >> developers don't do this replacement,yet?
> >> In addition, if all things is OK and it's a good idea, it would be
> >> pleasure
> >> if you give me some tips and points before doing that.
> >> Thanks in advance,
> >> Hamid
> > Hi,
> > Using GPU for the ECM step in the so-called cofactorization step of the
> > sieving phase is something to consider. However, this is not as simple as
> > pluging gmp-ecm within Cado-nfs.
> > Here are a few thoughts on the topic of ECM for NFS:
> > - the size of the numbers to be tested within NFS is small, and few
> > curves are tested. This is not the traditionnal target of GMP-ECM, and
> > therefore another version of ECM was written in CADO-NFS (mostly by
> > Alex Kruppa, who is also a developper of GMP-ECM).
> > - Kruppa's thesis contains many details on this topic.
> > http://tel.archives-ouvertes.fr/tel-00477005/en/
> > - the main question for using GPU is how to take advantage of the
> > parallelism. I think that GPU implem of GMP-ECM currently runs many
> > curves in parallel to make an optimal use of the card. But for the
> > application to NFS, only few cruves are needed, and we want a
> > parallelization at the input number level.
> > - the question of the transfers between the card and the cpu must be
> > addressed. I tend to think that it would be interesting to accumulate a
> > list of numbers to be tested and then send all of them at once, and
> > keep the CPU busy with sieving while the GPU tries to finish the
> > cofactorization. This implies some reorganization of the sieving code
> > that is not so simple.
> > Regards,
> > Pierrick
- Re: [cado-nfs] [Cado-nfs-discuss] Using GPU in Sieving Step, Paul Zimmermann, 03/10/2024
