cado-nfs - Re: [cado-nfs] Issue with "purge" on C210 GNFS
  • To: Markus Tervooren <mail@markustervooren.de>
  • Cc: cado-nfs@inria.fr
  • Subject: Re: [cado-nfs] Issue with "purge" on C210 GNFS
  • Date: Mon, 23 Sep 2024 18:29:17 +0200
  • Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@coriandre
Hi Markus,
the message says the row number is not less than the initial number of rows,
as it should be.
Something strange happened. Please can you retry the purge command with -t 1
instead of -t 32?
Paul
> Date: Mon, 23 Sep 2024 17:39:00 +0200
> From: Markus Tervooren <mail@markustervooren.de>
> [1:multipart/mixed Hide]
> [1/1:multipart/alternative Hide]
> [1/1/1:text/plain Show]
> [1/1/2:text/html Hide Save:noname (2kB)]
> Hello,
> I'm working on a C210 GNFS using cado-nfs.
> Its a degree 5 poly, -lpb0 34 -lpb1 34 -mfb0 86 -mfb1 96
> There are 1.4B relations total, after dup2 914300734 unique relations
> remained.
> The command
> cado-nfs/build/s138/filter/purge -out purged.gz -nrels 914300734 -keep 180
> -col-min-index 254759 -
> col-max-index 1425867903 -t 32 -required_excess 0.08 dup/0/* dup/1/*
> c210.freerel.gz
> gives me this error:
> # Read 905969664 relations in 1048.8s -- 116.2 MB/s -- 863810.2 rels/s
> code BUG() : condition rel->num < mat->nrows_init failed in
> purge_matrix_set_row_from_rel at
> /home/user/cado-nfs/filter/purge_matrix.c:104 -- Abort
> Aborted (core dumped)
> What is the issue here? msieve is able to build a matrix with this many
> relations already.
> Latest version from git, commit 9f5554bf4
> n:
> 232539157261042927881941676700725188228402020535267578693205299222661644763153066254774144628187108856923616820700724331104086289032277131880916986179638998110405195457189932507201286650867813828838811210697271
> skew: 16165690.452
> c0: -5395806944141178587689202753640560650628373335
> c1: 2035537653573416150928264387299885237521
> c2: 1346760344216313548930876980069067
> c3: -25448763348639172649664385
> c4: -2620291387764513348
> c5: -20686222800
> Y0: -15630706117797680537240315141285747058132
> Y1: 1083090829201407068911
> # MurphyE (Bf=1.718e+10,Bg=1.718e+10,area=5.369e+16) = 6.196e-09
> Thank you
> [2:application/pgp-signature Show Save:OpenPGP_signature.asc (840B)]
