Re: [cado-nfs] cado-nfs.py "Square Root: Creating file of (a,b) values" hang for non-semiprime
- To: cado-nfs@inria.fr
- Subject: Re: [cado-nfs] cado-nfs.py "Square Root: Creating file of (a,b) values" hang for non-semiprime
- Date: Fri, 1 Aug 2025 06:50:10 +0200
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=aurore.guillevic@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
Hi,
The strategy to get a medium-size factor is to use GMP-ECM, with the parameters at https://members.loria.fr/PZimmermann/records/ecm/params.html
The 6-th row gives:
for i in `seq 1 5208` ; do echo 122707855552185828468257427836864283300563571915184717192876562407609081222481009431414764530405548369855861509454229893234271790119941689194939718305389933643 | gmp-ecm 11000000 >> gmp-ecm-6.txt ; done
Then grep the output file for `Factor found` and you will get the 45-digit factor, with another 114 digit composite cofactor. It takes some hours too (should be parallelized).
A. Guillevic.
On 7/31/25 08:48, hermann@stamm-wilbrandt.de wrote:
On 2025-07-30 23:54, Greg Marks wrote:
Thanks,
In my experience, cado-nfs does work for non-semiprime input. In 2014
I ran cado-nfs-2.0 to successfully factor the number
122707855552185828468257427836864283300563571915184717192876562407609081222481009431414764530405548369855861509454229893234271790119941689194939718305389933643.
The final cado-nfs output was the three prime factors, separated
by spaces. (I should say that I have not tested this on more recent
versions of cado-nfs.)
Incidentally, due to the relatively small size of the smallest prime
factor of my number, ...
"relatively small size" is bigger than I thought.
What is that prime factor?
I did run this little GP script for more than 6 hours without factor found:
hermann@7950x:~$ gp -q
? o=2;forprime(p=3,,if(n%p==0,print(p);quit());if(p\10^8!=o\10^8,o=p;print1(".")))^C
*** user interrupt after 6h, 11min, 21,939 ms
I counted the number of dots printed, and the smallest factor is not smaller than
(128*114+16)*10^8 = 1460800000000
Since single threaded, the AMD 7950X CPU did run a >5.5GHz ...
Regards,
Hermann.
- Re: [cado-nfs] cado-nfs.py "Square Root: Creating file of (a,b) values" hang for non-semiprime, Greg Marks, 08/01/2025
- <Possible follow-up(s)>
- Re: [cado-nfs] cado-nfs.py "Square Root: Creating file of (a,b) values" hang for non-semiprime, Aurore Guillevic, 08/01/2025
