cgal-discuss - Re: Problem with regular triangulation
  • To: CGAL Mailinglist <>
  • Subject: Re: Problem with regular triangulation
  • Date: Tue, 17 Oct 2006 16:59:59 +0200
Hi Tom,
I am trying the new list
tom wrote:
I see nobody is reacting,
the only non answered question I can remember was about cgal 3.1
so I`ll try to write it more straightly:
I`m inserting points into regular triangulation and when I run the program it
stops whith this announcement:
CGAL error: precondition violation!
Expr: orientation(p0, p1, p2, p3) == POSITIVE
File: /home/xskoupi1/CGAL/include/CGAL/Regular_triangulation_3.h
Line: 745
And in this file on this exact line (745) is some precondition about
orientation.
Why is it testing orientation, when I`m inserting points into regular
triangulation?
Or why is it executing function side_of_oriented_power_sphere (in which this
line and so this precondition is) when I`m inserting points into regular
triangulation?
The algorithm is building a correct regular triangulation, so it checks at each insertion that new points are tested against valid cells (for instance in case users build cells 'by hand'). Valid cells must be well oriented and must satisfy the 'empty sphere' condition.
These preconditions should not fail if the triangulation is valid.
I might be an arithmetic problem, if you are using a non exact kernel (typically Cartesian<double>). You can have a look at the FAQ.
Please, at least tell me this is a stupid question, but tell me something. I
really don`t know what to do.
I will not dare say so ;)
best
Monique
  • Re: Problem with regular triangulation, Monique Teillaud, 10/17/2006
