- To:
- Subject: Re: [cgal-discuss] creating new edge objects
- Date: Thu, 19 Oct 2006 09:52:23 +0200
Satyajit Sarangi wrote:
Hi All,
I have a set of points in 3d space on which I am doing a 3d delaunay triangulation. I then calculate the voronoi vertices and isolate the poles out of them. Then I am trying to iterate through each edge in the triangulation and then take each vertex of each edge.
I then want to make edges out of the pole points i have got but I am unable to do it. Can somebody tell me how to create an edge object with the information of only two vertex. I am pretty new to CGAL and haven't tinkered around with it much.
Any help will be much appreciated.
Regards
Satyajit
poles are voronoi vertices,
voronoi vertices are dual to Delaunay tetrahedra
and edges in the Voronoi diagram are dual to pair of adjacent tetrahedra
i.e tetrahedra sharing a facet.
If you keep somehow a pointer from poles to Delaunay tetrahedra, it is then easy
to use the neighbor pointers between Delaunay cells to find out the edges
of the Voronoi diagrams linking poles....
I hope this helps
- creating new edge objects, Satyajit Sarangi, 10/19/2006
- Re: [cgal-discuss] creating new edge objects, Mariette Yvinec, 10/19/2006
