- To:
- Subject: Re: spacial search on mesh vertices
- Date: Fri, 20 Oct 2006 19:12:29 -0400
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=beta; d=gmail.com; h=received:message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references:x-google-sender-auth; b=APzZiLIAk5EyLid4YWCSq+nK3wRxbGK15b96eiqLtZi5/jq5H3EXbgHvG+BALwkbMhfMPOE215V1jikipBYB4EaaRY4ACizDmRK/SuWNJySm3hJ+Aqu3PJHtaQfFtM9HpZAlRtwoe8ZDK4/FZKUlIz93IXYV3DDTZBYlBmto52Y=
I should clarify that I would like a reference to an actual vertex
object, not a point (which has lost the rest of the vertex
information.)
On 10/20/06, Patricio D. Simari
wrote:
Hi,
Can someone give me a short example showing how to perform a range
search or k-nearest neighbour search on the vertices of a mesh stored
in a half edge structure?
Cheers,
Patricio
- spacial search on mesh vertices, Patricio D. Simari, 10/21/2006
- Re: spacial search on mesh vertices, Patricio D. Simari, 10/21/2006
- Re: [cgal-discuss] Re: spacial search on mesh vertices, Sylvain Pion, 10/21/2006
- Re: [cgal-discuss] Re: spacial search on mesh vertices, Patricio D. Simari, 10/22/2006
