- To:
- Subject: Convex Hull in 6D
- Date: Tue, 24 Oct 2006 10:03:04 +0200
Hello,
I switched from QHull to CGAL it seems that CGAL is more user friendly. I
need to calculate the convex hull of a set of points in 6D, and then find the
distance between the origin and each point on the convex hull. Is this
possible in CGAL ?
Also, how can I use CGAL to find the volume of the convex hull?
Thank you very much.
Regards,
Faisal
Reasearch Assistant,
The University of Iowa
IA, USA
- Convex Hull in 6D, fasfoosxxx, 10/24/2006
