- To:
- Subject: Problems with Alpha_shape_2
- Date: Thu, 26 Oct 2006 17:41:18 +0200
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=beta; d=gmail.com; h=received:message-id:date:from:to:subject:mime-version:content-type; b=VHkPv5rLRaSloL6xLH03fRzW4rtVUmL5eXlhS9JB39W40BfUqzKH7T+MBaof1hjqBFhljdNhh9Hl1Wd9ntti21mVirPn1fCC+NYvBxDqgp/R7roCxaTV9pOVjfKkOXHeE3FxtR4cQFHDJNsRXc7/2lM6Lup0wYWJqX818lpkcyk=
Dear CGAL users,
I've ran into some problems while using the Alpha_shape_2 class in its non-weighted form. In my problem I have a set of circles with a radius of 1. My purpose is to easily distinguish the edges that are part of the alpha-complex using this method. I get strange results (seems like errors to me) when classifying the edges of the alpha shape triangulation.
In the attached file (and below) you can see an example with 3 points : (0,0), (4,0), (0,4). I've set the alpha value to 1, hoping to discover that all edges are external (since the 3 circles are disjoint). Instead I get one interior and two exterior edges. Below is an extract from the attached file. This is, of course, a simplified example: I got similar results for multiple circles.
BTW The alpha shape edges (returned from alpha_shape_edges_begin/end()) works fine, only the classification fails.
I hope I'm doing something wrong (which means a quick remedy to my problem), thanks for you help,
Eitan Yaffe,
MSc. student, CGAL group at Tel-Aviv University
typedef CGAL::Quotient<CGAL::MP_Float> NT;
typedef CGAL::Cartesian<NT> K;
typedef K::Point_2 Point_2;
// Alpha Shape
typedef CGAL::Alpha_shape_vertex_base_2<K> Av;
typedef CGAL::Triangulation_face_base_2<K> Tf;
typedef CGAL::Alpha_shape_face_base_2<K,Tf> Af;
typedef CGAL::Triangulation_default_data_structure_2<K,Av,Af> Tds;
typedef CGAL::Delaunay_triangulation_2<K,Tds> Dt;
typedef CGAL::Alpha_shape_2<Dt> Alpha_shape_2;
typedef Alpha_shape_2::Alpha_iterator Alpha_iterator_2;
typedef Alpha_shape_2::Alpha_shape_edges_iterator Alpha_shape_edges_iterator_2;
int main(int argc, char **argv)
vector < Point_2 > points;
points.push_back(Point_2(0, 0));
points.push_back (Point_2(4, 0));
points.push_back(Point_2(0, 4));
const NT alpha_value = 1;
// construct alpha shape
Alpha_shape_2 alpha_shape(points.begin(), points.end(),
alpha_value,
Alpha_shape_2::GENERAL);
// print alpha values
for (int i = 0; i < alpha_shape.number_of_alphas(); ++i)
cout << i << " : " << alpha_shape.get_nth_alpha(i) << endl;
// classify edges
for (Alpha_shape_2::Edge_iterator eit = alpha_shape.finite_edges_begin();
eit != alpha_shape.finite_edges_end(); ++eit)
Alpha_shape_2::Edge edge = *eit;
cout << "classify result: " << classify_to_string(alpha_shape.classify(edge)) << endl;
return 0;
/* alpha_problem.C Problem in non-weighted alpha shape classification */ #include <CGAL/Delaunay_triangulation_2.h> #include <CGAL/Alpha_shape_2.h> #include <CGAL/MP_Float.h> #include <CGAL/Quotient.h> #include <CGAL/Cartesian.h> typedef CGAL::Quotient<CGAL::MP_Float> NT; typedef CGAL::Cartesian<NT> K; typedef K::Point_2 Point_2; // Alpha Shape typedef CGAL::Alpha_shape_vertex_base_2<K> Av; typedef CGAL::Triangulation_face_base_2<K> Tf; typedef CGAL::Alpha_shape_face_base_2<K,Tf> Af; typedef CGAL::Triangulation_default_data_structure_2<K,Av,Af> Tds; typedef CGAL::Delaunay_triangulation_2<K,Tds> Dt; typedef CGAL::Alpha_shape_2<Dt> Alpha_shape_2; typedef Alpha_shape_2::Alpha_iterator Alpha_iterator_2; typedef Alpha_shape_2::Alpha_shape_edges_iterator Alpha_shape_edges_iterator_2; using namespace std; string classify_to_string(Alpha_shape_2::Classification_type type) { switch (type) { case Alpha_shape_2::EXTERIOR: return "EXTERIOR"; case Alpha_shape_2::SINGULAR: return "SINGULAR"; case Alpha_shape_2::REGULAR: return "REGULAR"; case Alpha_shape_2::INTERIOR: return "INTERIOR"; default: return "unknown"; } } int main(int argc, char **argv) { vector < Point_2 > points; points.push_back(Point_2(0, 0)); points.push_back(Point_2(4, 0)); points.push_back(Point_2(0, 4)); const NT alpha_value = 1; // construct alpha shape Alpha_shape_2 alpha_shape(points.begin(), points.end(), alpha_value, Alpha_shape_2::GENERAL); // print alpha values for (int i = 0; i < alpha_shape.number_of_alphas(); ++i) cout << i << " : " << alpha_shape.get_nth_alpha(i) << endl; // classify edges for (Alpha_shape_2::Edge_iterator eit = alpha_shape.finite_edges_begin(); eit != alpha_shape.finite_edges_end(); ++eit) { Alpha_shape_2::Edge edge = *eit; cout << "classify result: " << classify_to_string(alpha_shape.classify(edge)) << endl; } return 0; }
- Problems with Alpha_shape_2, Eitan Yaffe, 10/27/2006
