- To: <>
- Subject: RE: [cgal-discuss] a bug in DeluanayTriangulation_3?
- Date: Fri, 1 Dec 2006 12:42:08 +0800
Thanks for replying.
After correcting the typos, I find that it I need to use release version of
cgal.lib instead of the debug version, then I can go through.
-----Original Message-----
[mailto:]
Sent: Friday, December 01, 2006 4:45 AM
To:
Subject: Re: [cgal-discuss] a bug in DeluanayTriangulation_3?
Hello,
I can't reproduce it, neither in debug nor in release mode.
It also worked with or without -D_HAS_ITERATOR_DEBUGGING=0
to switch off the stronger checking in the new STL
of VC8.
Note that you do not insert translated points
Instead of
Point (pi->x() + x, pi->y() + y, pi->z() + z);
dt.insert(*pi);
you probably want this:
Point point(pi->x() + x, pi->y() + y, pi->z() + z);
dt.insert(point);
andreas
lihw wrote:
> Hi, all
> I came across a confusing problem when I try to construct a Delaunay
> Triangulation 3D.
> I have about 256 points distributed in [0,1] x [0,1] x [0,1]. First I
> construct an Delaunay triangulation using these points. Then I add an
> offset that is [0, 0, 1] to these points and insert the new points to
> the initial triangulation. A memory exception comes out in every deep
> call stack, "memcpy.dll".
> I compile the source in VC2005. Is there anyone once seeing the same
> problem? Please leave me a hint.
> I attached the source file and data to the email. They are plain text
> and I promise it is free of virus. Please take a look at it and help me.
> Thanks in advance.
> lihw
> // mr.cpp
> // lihw
> //#include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
> #include <CGAL/Exact_predicates_exact_constructions_kernel.h>
> #include <CGAL/assertions.h>
> #include <CGAL/Delaunay_Triangulation_3.h>
> // Typedefs
> typedef CGAL::Exact_predicates_exact_constructions_kernel K;
> typedef CGAL::Point_3<K> Point;
> typedef std::vector<Point> Point_container;
> typedef Point_container::iterator Point_iterator;
> typedef std::back_insert_iterator<Point_container> Point_inserter;
> typedef CGAL::Delaunay_triangulation_3<K> Dt;
> void load(const char* file, Point_inserter output_iterator)
> FILE* fp;
> if (fopen_s(&fp, file, "r")) {
> printf("can't open %s. Exiting...\n", file);
> exit(1);
> char buffer[1024];
> while (fgets(buffer, 1024, fp)) {
> // One line contains 4 numbers.
> // The first three are coordinates of the point,
> // and the last one is a flag indicating continuing
> // or not
> double x, y, z;
> int flag;
> sscanf_s(buffer, "%lf %lf %lf %d", &x, &y, &z, &flag);
> assert(x <= 1.0f && x >= 0.0f);
> assert(y <= 1.0f && y >= 0.0f);
> assert(z <= 1.0f && z >= 0.0f);
> switch (flag) {
> case 2: // ball tensor
> *output_iterator++ = Point(x, y, z);
> break;
> default:
> assert(!"not implemented");
> break;
> if (ferror(fp)) {
> printf("reading %s error. Exiting...\n");
> exit(1);
> fclose(fp);
> void construct_dt(Point_container& points)
> Dt dt;
> int x, y, z;
> x = 0; y = 0; z = 0;
> Point_iterator pi, pb = points.begin(), pe = points.end();
> for (pi = pb; pi != pe; ++pi) {
> dt.insert(*pi);
> x = 0; y = 0; z = 1;
> pb = points.begin(); pe = points.end();
> dt.insert(*pi);
> void main(int argc, char* argv[])
> Point_container points;
> points.reserve(256);
> if (argc < 2)
> exit(1);
> load(argv[1], std::back_inserter(points));
> construct_dt(points);
- RE: [cgal-discuss] a bug in DeluanayTriangulation_3?, lihw, 12/01/2006
