- To:
- Subject: Re: [cgal-discuss] problem creating Nef_polyhedron_3 from ".off" files
- Date: Fri, 01 Dec 2006 14:01:50 +0100
Hello,
The coordinates must be integers. In your case they are
all rounded to 0 or 1.
andreas
wrote:
Hello,
I'm unsuccessfully trying to create Nef_Polyhedron_3 object from Polyhedron_3, which is in turn read form cube.off file.
It turns out that when the coordinates of the vertices (by abs value) are
smaller than one, I receive segmentation fault, or some other kind of error,
which depends on Kernel that is used.
Same problem appears when I start nef_3 demo. Using following syntax:
$./nef_3 loadoff cube01.off
I receive the following error:
Error !!!!!!!!!!!!!!!!!!!!!!!
wrong cycle
PointH3(0, 0, 0, 1)
PointH3(0, 0, 0, 1)
PointH3(0, 0, 0, 1)
PointH3(0, 0, 0, 1)
CGAL error: assertion violation!
Expr: !pe_prev->facet()->plane().is_degenerate()
File: /usr/local/CGAL/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h
Line: 149
Aborted
The file cube01.off is same as cube.off, found in demo/Nef_3 directory,
except for the scaled coordinates of vertices:
OFF
8 6 0
# vertices
-0.1 -0.1 0.1
-0.1 0.1 0.1
0.1 0.1 0.1
0.1 -0.1 0.1
-0.1 -0.1 -0.1
-0.1 0.1 -0.1
0.1 0.1 -0.1
0.1 -0.1 -0.1
# facets
4 3 2 1 0
4 0 1 5 4
4 6 5 1 2
4 3 7 6 2
4 4 7 3 0
4 4 5 6 7
Program that triggers same behavior is modified version from users manual:
//----------------------cut-----------------
// *read Polyhedron_3 from std::cin, // *convert it into Nef_Polyhedron_3
#include <CGAL/Gmpz.h>
#include <CGAL/Cartesian.h>
#include <CGAL/Homogeneous.h>
#include <CGAL/Extended_homogeneous.h>
#include <CGAL/Nef_polyhedron_3.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/IO/Nef_polyhedron_iostream_3.h>
#include <fstream>
typedef CGAL::Gmpz NT;
//typedef CGAL::Homogeneous<NT> SK;
typedef CGAL::Cartesian<double> SK;
typedef CGAL::Extended_homogeneous<NT> EK;
typedef CGAL::Nef_polyhedron_3<SK> Nef_polyhedron_S;
//typedef CGAL::Nef_polyhedron_3<EK> Nef_polyhedron_E;
typedef CGAL::Polyhedron_3<SK> Polyhedron;
int main() {
// debugthread=29;
Polyhedron P;
std::cin >> P;
Nef_polyhedron_S S(P);
std::cout << S;
//----------------cut--------------
Am I missing something?
Thanks in advance,
Gordan Sikic
- problem creating Nef_polyhedron_3 from ".off" files, gordan . sikic, 12/01/2006
- Re: [cgal-discuss] problem creating Nef_polyhedron_3 from ".off" files, Andreas Fabri, 12/01/2006
- Re: [cgal-discuss] problem creating Nef_polyhedron_3 from ".off"files, Gordan Sikic, 12/01/2006
- Re: [cgal-discuss] problem creating Nef_polyhedron_3 from ".off"files, Peter Hachenberger, 12/04/2006
