- To:
- Subject: operator '<' overloaded
- Date: Mon, 4 Dec 2006 12:39:04 +0100
Hello,
I use a std::map<,> in my code,
and received a message as follows.
< Error message
c:/NAGAI/MinGW/bin/../lib/gcc/mingw32/3.4.2/../../../../include/c++/3.4.2/bits/stl_function.h:227:
error: no match for 'operator<' in '__x < __y'
C:/NAGAI/CGAL/CGAL-3.2.1/include/CGAL/Gmpz.h:151: note: candidates are: bool
CGAL::operator<(const CGAL::Gmpz&, int)
C:/NAGAI/CGAL/CGAL-3.2.1/include/CGAL/Gmpz.h:139: note: bool
CGAL::operator<(const CGAL::Gmpz&, const CGAL::Gmpz&)
C:/NAGAI/CGAL/CGAL-3.2.1/include/CGAL/MP_Float.h:269: note:
bool CGAL::operator<(const CGAL::MP_Float&, const CGAL::MP_Float&)
I think this error is related to overloading the operator '<' in CGAL.
All of the code is long, so I'll show a part of it.
I skipped many parts of code which I consider they mean nothing to this
problem.
< A part of codes
struct ControlPointsOfFacet{
Point p[ 10 ];
class Surface{
public:
Polyhedron surfaceMesh;
std::map< FacetIterator, ControlPointsOfFacet > controlPoint;
...( in another member function of class Surface )
Surface surface;
FacetIterator fit = surface.surfaceMesh.facets_begin();
ControlPointsOfFacet cp;
cp.p[0]=Point(...);
cp.p[9]=Point(...);
controlPoint.insert( std::make_pair( fit, cp ) );
How can I fix this problem?
Regards,
Yukie NAGAI
- operator '<' overloaded, ueberweise, 12/04/2006
- Re: [cgal-discuss] operator '<' overloaded, Andreas Fabri, 12/04/2006
- Re: [cgal-discuss] operator '<' overloaded, Yajun Wang, 12/04/2006
- Re: [cgal-discuss] operator '<' overloaded, NAGAI, Yukie, 12/05/2006
