- To:
- Subject: Re: [cgal-discuss] Creating facet
- Date: Wed, 27 Dec 2006 15:53:27 +0100
hi,
If you project your points on the horizontal plane (provided they don't lie in a vertical plane) and compute the 2d convex hull of the projected points with cgal, it gives you the sequence you are looking for.
Monique Teillaud
wrote:
Hi, i have a problem.
I have points (in 3D), which are coplanar and they makes a convex polygon. I
want to use this points to create facet by using Incremental polyhedral
builder, but i don`t have the right sequence of those points, hwich is (the
sequence) needed by the Inc. polyh. builder. Is there any easy way to get the
right sequence of those points in CGAL?
I don`t know if my question is understandable so I`ll try to showw it on an
2-dimensional example:
lets have a polygon made by points: A=(-2, 1), B=(-1, -1), C=(0, 2), D=(1,
-1) and E=(2, 1).
I can see that the right sexuence is B, A, C, E, D. (or ACEDB, or CEDBA, ...)
but how do i get this sequence by programing? Is there any way to get the
sequence
by using CGAL (whith the coplanar points in 3D)?
I hope it`s understandable.
Tom
--- You are currently subscribed to cgal-discuss.
- Creating facet, felator . vembloudu, 12/27/2006
- Re: [cgal-discuss] Creating facet, Arnaud Krust, 12/27/2006
- Re: [cgal-discuss] Creating facet, Monique Teillaud, 12/27/2006
- Re: [cgal-discuss] Creating facet, Camille . Wormser, 12/27/2006
