- To:
- Subject: Re: [cgal-discuss] coplanarity of weighted circumcenters
- Date: Thu, 04 Jan 2007 08:45:40 +0100
wrote:
I will try to explain it better:if you speak about a 3D triangulation, you have at least three tetrahedral cells around each edge
I have two neighbouring points in regular triangulation and i compute
weighted circumcenters of all cells, which have both those points as vertices
(presume that noone of this cells is infinite). Will the amount of these
weighted circumcenters be grater than 2 in every case?
--- You are currently subscribed to cgal-discuss.
and each of them has a weighted circumcenters which,
except of course in degenerated cases, are distinct weighted points
- Re: [cgal-discuss] coplanarity of weighted circumcenters, Mariette Yvinec, 01/02/2007
- <Possible follow-up(s)>
- Re: Re: [cgal-discuss] coplanarity of weighted circumcenters, felator . vembloudu, 01/03/2007
- Re: [cgal-discuss] coplanarity of weighted circumcenters, Mariette Yvinec, 01/03/2007
- Re: [cgal-discuss] coplanarity of weighted circumcenters, Mariette Yvinec, 01/04/2007
- Re: [cgal-discuss] coplanarity of weighted circumcenters, Camille . Wormser, 01/04/2007
