- To:
- Subject: Re: [cgal-discuss] Volume of alpha shape
- Date: Mon, 29 Jan 2007 09:34:10 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=N7G/IQwimfGpU/x/UgMhaYhnDa6hWQDbe5w5i3orAroiPjD5F4C3aEr9sEZXYIpUSPbV2XlX2f83I5+n3jxz7XXpyMxJS9hWYDQ/CRKwAvSvqkAYbVTRH1HV9b1zz6XEpTbrN0ovsH1XobbVb7GHeL2jRwBDZmydObXV8r/W5zM=
Thank you.
On 25/01/07, Andreas Fabri <> wrote:
wrote:
> Hello list!
> Is it possible to calculate the volume of a constructed 3D alpha shape?
If it is watertight sum up the volumes of the tetrahedra.
If it is not watertight there is no volume.
andreas
best wishes,
Dmitry Kan
- Volume of alpha shape, dmitry . kan, 01/25/2007
- Re: [cgal-discuss] Volume of alpha shape, Andreas Fabri, 01/25/2007
- Re: [cgal-discuss] Volume of alpha shape, Dmitry Kan, 01/29/2007
