- To:
- Subject: Re: [cgal-discuss] How do I get polygon intersection to work?
- Date: Wed, 31 Jan 2007 17:23:06 +0100
Thank you. It worked! However I have a problem I don't seem to be able to work around. Using Exact_predicates_exact_constructions_kernel slows don't the code so much that it becomes almost unusable. Is there a way around this? I don't really care for accuracy. What I need is the code to not crash/ fail. I would prefer if I could use double for the intersection test but that it didn't give assertion failures in the degenerate cases. E.g. it would be ok if the code just chose not to treat those cases.
On 20 Jan 2007, at 10:30 AM, Efi Fogel wrote:
Sounds like a classic case of limited precision problem.
Try to use an exact number type. For example:
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
Erik Engheim wrote:
I am using the Polygon_2 class. But I don't seem to get intersection tests with "do_intersect" from "Boolean_set_operations_2.h" to work properly. Most of the time it works but it doesn't seem to handle degenerate cases. In my case when the corner of a polygon intersects a line segment on another polygon.
I get the following assertion failure:
CGAL error: assertion violation!
Expr: *slIter == curve
File: /Users/Shared/CGAL-3.2.1/include/CGAL/Basic_sweep_line_2.h
Line: 591
Sometimes I have gotten this failure:
CGAL error: precondition violation!
Expr: Segment_assertions::_assert_is_point_on (p, cv, Has_exact_division()) && compare_xy(cv.left(), p) == SMALLER && compare_xy(cv.right(), p) == LARGER
File: /Users/Shared/CGAL-3.2.1/include/CGAL/Arr_segment_traits_2.h
Line: 730
The program below demonstrates the problem. When run I get the first assertion failure. Any suggestions to what is causing this? Am I using the library wrong or is this a bug in CGAL?
Cheers,
Erik
#include <CGAL/Cartesian.h>
#include <CGAL/basic.h>
#include <CGAL/Point_2.h>
#include <CGAL/Boolean_set_operations_2.h>
#include <iostream>
using namespace std;
using namespace CGAL;
typedef Cartesian<double> K;
typedef Point_2<K> Point2;
typedef Polygon_2<K> Polygon2;
int main()
Point2 small[] = {
Point2(3.0721924234843 , -1.0673205240039),
Point2(5.067320524004, -0.9278075765157),
Point2(4.9278075765157, 1.0673205240039),
Point2(2.9326794759961, 0.9278075765157)};
Point2 large[] = {Point2(-3,-3),
Point2(3,-3),
Point2(3,3),
Point2(-3,3)};
Polygon2 smallPoly(small, small+4);
Polygon2 largePoly(large, large+4);
cout << "do intersect? " << do_intersect(smallPoly, largePoly) << endl;
return 0;
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- How do I get polygon intersection to work?, Erik Engheim, 01/19/2007
- Re: [cgal-discuss] How do I get polygon intersection to work?, Efi Fogel, 01/20/2007
- Re: [cgal-discuss] How do I get polygon intersection to work?, ordovician . cenozoic, 01/31/2007
