cgal-discuss - Stack overflow in Point_set_2.h::range_search()
  • To:
  • Subject: Stack overflow in Point_set_2.h::range_search()
  • Date: Fri, 02 Feb 2007 15:12:20 +0100
Hi,
when calling the function range_search from the file "Point_set_2.h" for
triangulations containing many vertices (> 105) it is very likely that a
segmentation fault occurs because of a stack overflow. The reason for this
problem is the function dfs, which calls frequently itself recursively.
Therefore, i would propose to change the implicit use of
the runtime stack by means of recursion by the use of an explicit stack (and
making the function non-recursive). That solved the problem in my case.
Greetz,
Jan
Dipl. Inf. Jan Hendrik Metzen
Robotics Lab
FB3 - Mathematics and Computer Science Department
University of Bremen
Email:
Tel.: +49- (421)- 218- 64123
Fax : +49- (421)-
Room: 114
Postal address:
AG Robotik
Jan Hendrik Metzen
Robert-Hooke-Straße 5
28359 Bremen
Further informations:
http://www.informatik.uni-bremen.de/robotik
  • Stack overflow in Point_set_2.h::range_search(), Jan Hendrik Metzen, 02/02/2007
