cgal-discuss - Re: [cgal-discuss] Using Arrangement Observer
  • To: "Naomi Fox" <>
  • Cc:
  • Subject: Re: [cgal-discuss] Using Arrangement Observer
  • Date: Wed, 7 Feb 2007 15:42:48 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:sender:to:subject:cc:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references:x-google-sender-auth; b=uSZidDcXlOhop39NWVGZSeY4AMj3M7Jzvrnua8PV8pFek8OZkwDImTeGg18yTxBle690oaXNLMriajwHoaKb1Swq3RunMEbG+z9qVJZ3gyOi2K1JHgcpsmJxXuSJ4ugo82HuTGHFS6eYQJI6+FAbgoKF9ug6XB+8fpD//r3PqXY=
thanks for the reply
here is my example code:
//! \file examples/Arrangement_2/ex_observer.cpp extended
// Using a simple arrangement observer.
#include <CGAL/Cartesian.h>
#include <CGAL/Quotient.h>
#include <CGAL/MP_Float.h>
#include <CGAL/Arr_segment_traits_2.h>
#include <CGAL/Arrangement_2.h>
#include <CGAL/Arr_observer.h>
typedef CGAL::Quotient<CGAL::MP_Float> Number_type;
typedef CGAL::Cartesian<Number_type> Kernel;
typedef CGAL::Arr_segment_traits_2<Kernel> Traits_2;
typedef Traits_2::Point_2 Point_2;
typedef Traits_2::X_monotone_curve_2 Segment_2;
typedef CGAL::Arrangement_2<Traits_2> Arrangement_2;
// An arrangement observer, used to receive notifications of face splits and
// face mergers.
class My_observer : public CGAL::Arr_observer<Arrangement_2>
public:
My_observer (Arrangement_2& arr) :
CGAL::Arr_observer<Arrangement_2> (arr)
virtual void before_split_face (Face_handle,
Halfedge_handle e)
std::cout << "-> The insertion of : [ " << e->curve()
<< " ] causes a face to split." << std::endl;
virtual void before_merge_face (Face_handle,
Face_handle,
Halfedge_handle e)
std::cout << "-> The removal of : [ " << e->curve()
<< " ] causes two faces to merge." << std::endl;
virtual void after_create_edge( Halfedge_handle e ) {
std::cout << "-> after create edge: [ " << e->curve()
<< " ]." << std::endl;
virtual void before_split_edge ( Halfedge_handle e,
Vertex_handle v,
X_monotone_curve_2 c1,
X_monotone_curve_2 c2) {
std::cout << "-> before split edge: [ " << e->curve()
<< " ] at " << v->point() << std::endl;
virtual void after_split_edge( Halfedge_handle e1, Halfedge_handle e2 ) {
std::cout << "-> after split edge: [ " << e1->curve() << " ][ " <<
e2->curve() << " ]" << std::endl;
int main ()
// Construct the arrangement containing one diamond-shaped face.
Arrangement_2 arr;
My_observer obs (arr);
Segment_2 s1 (Point_2(-1, 0), Point_2(0, 1));
Segment_2 s2 (Point_2(0, 1), Point_2(1, 0));
Segment_2 s3 (Point_2(1, 0), Point_2(0, -1));
Segment_2 s4 (Point_2(0, -1), Point_2(-1, 0));
insert_non_intersecting_curve (arr, s1);
insert_non_intersecting_curve (arr, s2);
insert_non_intersecting_curve (arr, s3);
insert_non_intersecting_curve (arr, s4);
// Insert a vertical segment dividing the diamond into two, and a
// a horizontal segment further dividing the diamond into four:
Segment_2 s_vert (Point_2(0, -1), Point_2(0, 1));
Arrangement_2::Halfedge_handle
e_vert = insert_non_intersecting_curve (arr, s_vert);
Segment_2 s_horiz (Point_2(-1, 0), Point_2(1, 0));
insert_curve (arr, s_horiz);
std::cout << "The initial arrangement size:" << std::endl
<< " V = " << arr.number_of_vertices()
<< ", E = " << arr.number_of_edges()
<< ", F = " << arr.number_of_faces() << std::endl;
// Now remove a portion of the vertical segment.
remove_edge (arr, e_vert);
std::cout << "The final arrangement size:" << std::endl
return (0);
