cgal-discuss - Errors in compiling a source code
  • To: <>
  • Subject: Errors in compiling a source code
  • Date: Tue, 20 Feb 2007 13:42:41 +0900
Hello.
Im implementing a segment Voronoi diagram using CGAL. Here is my source :
// examples/Voronoi_diagram_2/point_location.C
#include <CGAL/basic.h>
// standard includes
#include <iostream>
#include <fstream>
#include <cassert>
// define the kernel
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Filtered_kernel.h>
typedef CGAL::Simple_cartesian<double>    CK;
typedef CGAL::Filtered_kernel<CK>         Kernel;
//#include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
// typedefs for the traits and the algorithm
#include <CGAL/Segment_Delaunay_graph_traits_2.h>
#include <CGAL/Segment_Delaunay_graph_2.h>
typedef CGAL::Segment_Delaunay_graph_traits_2<Kernel>  Gt;
typedef CGAL::Segment_Delaunay_graph_2<Gt>             SDG2;
#include <CGAL/Voronoi_diagram_2.h>
#include <CGAL/Segment_Delaunay_graph_adaptation_traits_2.h>
#include <CGAL/Segment_Delaunay_graph_adaptation_policies_2.h>
// includes for defining the Voronoi diagram adaptor
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/Delaunay_triangulation_adaptation_traits_2.h>
#include <CGAL/Delaunay_triangulation_adaptation_policies_2.h>
typedef CGAL::Segment_Delaunay_graph_adaptation_traits_2<SDG2>                 AT;
typedef CGAL::Segment_Delaunay_graph_caching_degeneracy_removal_policy_2<SDG2> AP;
typedef CGAL::Voronoi_diagram_2<SDG2,AT,AP>                                    VD;
// typedef for the result type of the point location
typedef AT::Site_2                    Site_2;
typedef AT::Point_2                   Point_2;
typedef VD::Locate_result             Locate_result;
typedef VD::Vertex_handle             Vertex_handle;
typedef VD::Face_handle               Face_handle;
typedef VD::Halfedge_handle           Halfedge_handle;
typedef VD::Ccb_halfedge_circulator   Ccb_halfedge_circulator;
void print_endpoint(Halfedge_handle e, bool is_src) {
  std::cout << "\t";
  if ( is_src ) {
    if ( e->has_source() )  std::cout << e->source()->point() << std::endl;
    else  std::cout << "point at infinity" << std::endl;
  } else {
    if ( e->has_target() )  std::cout << e->target()->point() << std::endl;
int main()
  std::ifstream ifs("data/data1.dt.cin");
  assert( ifs );
  VD vd;
  Site_2 t;
  while ( ifs >> t ) { vd.insert(t); }
  ifs.close();
  assert( vd.is_valid() );
  std::ifstream ifq("data/queries1.dt.cin");
  assert( ifq );
  Point_2 p;
  while ( ifq >> p ) {
    std::cout << "Query point (" << p.x() << "," << p.y()
              << ") lies on a Voronoi " << std::flush;
    Locate_result lr = vd.locate(p);
    if ( Vertex_handle* v = boost::get<Vertex_handle>(&lr) ) {
      std::cout << "vertex." << std::endl;
      std::cout << "The Voronoi vertex is:" << std::endl;
      std::cout << "\t" << (*v)->point() << std::endl;
    } else if ( Halfedge_handle* e = boost::get<Halfedge_handle>(&lr) ) {
      std::cout << "edge." << std::endl;
      std::cout << "The source and target vertices "
                << "of the Voronoi edge are:" << std::endl;
      print_endpoint(*e, true);
      print_endpoint(*e, false);
    } else if ( Face_handle* f = boost::get<Face_handle>(&lr) ) {
      std::cout << "face." << std::endl;
      std::cout << "The vertices of the Voronoi face are"
                << " (in counterclockwise order):" << std::endl;
      Ccb_halfedge_circulator ec_start = (*f)->outer_ccb();
      Ccb_halfedge_circulator ec = ec_start;
      do {
        print_endpoint(ec, false);
      } while ( ++ec != ec_start );
    std::cout << std::endl;
  ifq.close();
  return 0;
I modified the example of Voronoi adaptor by replacing Delaunay_Triangulation class with Segment_Delaunay_Graph.
But, several linking errors occur in compiling the source code with Visual Studio 2003. The following is error message :
C:\Program Files\CGAL-3.2.1\include\CGAL\Voronoi_diagram_2.h(748): error C3861: 'INSERT_IS_NOT_SUPPORTED': identifier not found, even with argument-dependent lookup
What is wrong in my source code?
Thank you in advance.
  • Errors in compiling a source code, 박정현, 02/20/2007
